| 1 | = tcounts.pl = |
| 2 | The url for the data is http://www.highwayengineer.co.medina.oh.us/StickeDB.pdb . |
| 3 | {{{ |
| 4 | #!perl |
| 5 | #!/usr/bin/perl |
| 6 | # |
| 7 | # Copyright (C) 2002, Lowell Filak. |
| 8 | # You may distribute this file under the terms of the Artistic |
| 9 | # License. |
| 10 | # |
| 11 | # Given the name of an existing palm database and the name |
| 12 | # of an existing point shapefile this routine will append the points |
| 13 | # in the pdb to the shapefile. |
| 14 | # Given just the name of an existing shapefile the routine will attempt |
| 15 | # to use pilot-xfer to download the pdb file and append the points to the |
| 16 | # shapefile. |
| 17 | # Given just the name of an existing pdb file this routine will create a |
| 18 | # new shapefile of the points in the pdb file. |
| 19 | # Given neither name this routine will attempt to use pilot-xfer to download |
| 20 | # the pdb file and create a new point shapefile from it. |
| 21 | # Notes: The fields in the pdb file should match the fields in the |
| 22 | # existing shapefile (dbf) or the assignments will either be |
| 23 | # wrong or will cause the routine to bomb. |
| 24 | # The pdb file for download is assumed to be StickeDB.pdb and the routine |
| 25 | # is written to read sticke style pdb files only. |
| 26 | # The pdb reading section of this routine is not complete but is setup |
| 27 | # somewhat generic and should be extendable to any sticke database |
| 28 | # schema. |
| 29 | # The pilot-xfer download line assumes the default pilot device |
| 30 | # (/dev/pilot) exists. |
| 31 | # The routine also assumes a *n*x system, please change command |
| 32 | # lines accordingly. |
| 33 | # If nad support is needed in proj.4 please verify that the ntv1_can.dat |
| 34 | # file is included before compiling. If not, grab a newer release. |
| 35 | # |
| 36 | # Required modules are mapscript (installed as part of make install |
| 37 | # http://mapserver.gis.umn.edu), |
| 38 | # Getopt (normally included with Perl), |
| 39 | # Palm (p5-Palm-1.1.5 http://theoryx5.uwinnipeg.ca/CPAN/data/p5-Palm/Palm/Raw.html), |
| 40 | # & XBase (cpan). |
| 41 | # Please download StickeDB.pdb also. |
| 42 | # |
| 43 | # Additional requirements are: a working pilot-xfer (pilot-link http://www.pilot-link.org/) |
| 44 | # installation, |
| 45 | # a working StickePad.prc and StickePlates.prc (StickeV2Programs |
| 46 | # http://www.cs.ukc.ac.uk/projects/mobicomp/Fieldwork/) on a |
| 47 | # PalmOS handheld device, & a working proj.4 install compiled with |
| 48 | # the optional nad files in place and with the cs2cs |
| 49 | # command working (www.remotesensing.org/proj/). |
| 50 | # |
| 51 | # Current GPS information: Palm IIIX-PDA, Garmin Etrex Summit-GPS, Blue |
| 52 | # Hills Innovations-Garmin2Palm cable (http://www.blue-hills-innovations.com). |
| 53 | # |
| 54 | # Suggested run line = ./tcounts.pl -pdbfile=StickeDB -sfile=traffic |
| 55 | # |
| 56 | # Syntax: tcounts.pl -pdbfile=[in_pdb_filename] -sfile=[out_shapefile_name] |
| 57 | # |
| 58 | # Include the pdb and pdb-raw modules. |
| 59 | use Palm::PDB; |
| 60 | use Palm::Raw; |
| 61 | # |
| 62 | # Include the mapscript module. |
| 63 | use mapscript; |
| 64 | # |
| 65 | # Include the xbase module for creating the dbf records. |
| 66 | use XBase; |
| 67 | # |
| 68 | # Include the getopt module to read input. |
| 69 | use Getopt::Long; |
| 70 | # |
| 71 | # Helpful definitions for StickeDB.pdb: |
| 72 | # I view the structure as very similar to an rdbms. |
| 73 | # Database - refers to the pdb file itself. |
| 74 | # Table - refers to the rdbms-like table name included on every record. |
| 75 | # Note: Each record can belong to a different table or even a different |
| 76 | # table deffinition under the same table name! |
| 77 | # Note: Tables are refered to as 'templates' inside sticke. |
| 78 | # Record - refers to the entire 'data' portion returned by the pdb->data obj. |
| 79 | # Note: Records are refered to as 'notes' inside of sticke. |
| 80 | # Field - refers to the section of the 'data' portion of the record which |
| 81 | # spans from the beginning of one field name to the beginning of the |
| 82 | # next. |
| 83 | # Note: Fields are refered to as both 'fields' and 'items' inside of sticke. |
| 84 | # Part - refers to the sections of a field that define the schema of the |
| 85 | # field (schema - data type, constraints, etc). |
| 86 | # |
| 87 | # Grab the file names from the input. |
| 88 | &GetOptions('pdbfile=s' => \$pdbfile, 'sfile=s' => \$sfile); |
| 89 | if ( !$sfile ) { |
| 90 | # |
| 91 | # Create a unique name for the shapefile based on date and process number. |
| 92 | |
| 93 | # |
| 94 | # Grab the time. |
| 95 | ($sec,$min,$hr,$mdy,$mnth,$yr,$wdy,$ydy,$isdst) = localtime; |
| 96 | # |
| 97 | # Grab the process id. |
| 98 | $spid = $$; |
| 99 | |
| 100 | # |
| 101 | # Create the name & make sure it is no longer than 8 characters. |
| 102 | $sfile = substr("$hr$min$sec$spid", -8); |
| 103 | } |
| 104 | if( !$pdbfile ) { |
| 105 | # |
| 106 | # Download the pdb file. |
| 107 | system("pilot-xfer -f StickeDB"); |
| 108 | # |
| 109 | # Set the pdb file name. |
| 110 | $pdbfile = 'StickeDB'; |
| 111 | } |
| 112 | # |
| 113 | # Create the pdb object on the pdb file. |
| 114 | my $pdb = new Palm::PDB; |
| 115 | $pdb->Load("$pdbfile.pdb"); |
| 116 | # |
| 117 | # How many pdb records are there. |
| 118 | my @records = @{$pdb->{records}}; |
| 119 | my $numrecs = scalar(@records); |
| 120 | # |
| 121 | # Create the information array for each field/data type. |
| 122 | # Note: The routine is incomplete at this time because we currently only use |
| 123 | # 7-number & 4-location but all types are here for documentation. |
| 124 | my @types = ('bearing', 'boolean', 'date', 'textline', 'location', 'unused', 'notepad', 'number', 'picklist', 'subnote', 'time'); |
| 125 | # |
| 126 | # Create the field type number-of-parts array. |
| 127 | my @parts = (0,0,0,0,23,0,0,11,0,0,0); |
| 128 | # |
| 129 | # Create the field types unpack string array. |
| 130 | # For location [offset+10]=dontno5, [offset+11]=latdegrees, |
| 131 | # [offset+12]=dontno6, [offset+13]=latminuteswhole, |
| 132 | # [offset+14]=dontno7, [offset+15]=latminutesdecimal, |
| 133 | # [offset+16]=elevation, [offset+17]=dontno8, [offset+18]=longdegrees, |
| 134 | # [offset+19]=dontno9, [offset+20]=longminuteswhole, |
| 135 | # [offset+21]=dontno10, [offset+22]=longminutesdecimal |
| 136 | # Note: At this point I can't find the NSEW/+- indication for lat/lon! |
| 137 | # For number [offset+10]=number |
| 138 | my @ustring = (' a*', ' a*', ' a*', ' a*', ' l n a2 n a2 n s a2 n a2 n a2 n', ' a*', ' a*', ' N', ' a*', ' a*', ' a*'); |
| 139 | # |
| 140 | # Create the array for the pdb-field-type to dbf-field-type conversion. |
| 141 | my @dbfftype = ('C', 'L', 'D', 'C', 'C', 'C', 'C', 'N', 'C', 'C', 'N'); |
| 142 | # |
| 143 | |
| 144 | # Create the array for the pdb-field-size to dbf-field-size conversion. |
| 145 | my @dbffsize = ('255', '1', '8', '255', '31', '0', '255', '11', '255', '255', '10'); |
| 146 | # |
| 147 | # Create the array for the pdb-field-decimal to dbf-field-decimal conversion. |
| 148 | # No need for this now. All decimals should be null going into the dbf file. |
| 149 | # |
| 150 | # Create the array for tracking field offsets. |
| 151 | # To be used later while creating dbf records for each gps point. |
| 152 | my @offsets = (); |
| 153 | # |
| 154 | # Create the initial unpack string. |
| 155 | my $unpackstr = ""; |
| 156 | # |
| 157 | # Create the initial data array. |
| 158 | my @recordinfo = (); |
| 159 | # |
| 160 | # Initialize the dbf record count to 0. |
| 161 | my $dbfreccnt = 0; |
| 162 | # |
| 163 | # Does the dbf file already exist or does it yet to exist. |
| 164 | if ( -e "$sfile.dbf" ) { |
| 165 | # |
| 166 | # Open the existing dbf file for appending to. |
| 167 | $dbh = new XBase "$sfile.dbf" or die XBase->errstr; |
| 168 | # |
| 169 | # To be able to increment the record # starting at the last existing |
| 170 | # record how many records are there. |
| 171 | $dbfreccnt = $dbh->last_record + 1; |
| 172 | } |
| 173 | else { |
| 174 | $dbfreccnt = -1; |
| 175 | } |
| 176 | |
| 177 | # |
| 178 | # Does the shapefile already exist or is it yet to exist. |
| 179 | if ( -e "$sfile.shp" ) { |
| 180 | # |
| 181 | # Move the existing shapefile to a temp name. |
| 182 | # This is done because the -1 option on shapefileObj open |
| 183 | # only allows for read not append. |
| 184 | # However as (hopefully) shown below this is not hard to |
| 185 | # implement inside mapscript. |
| 186 | system("mv $sfile.shp thistemp.shp; mv $sfile.shx thistemp.shx; touch thistemp.dbf"); |
| 187 | # |
| 188 | # Open the existing file. |
| 189 | $ecounts = new shapefileObj("thistemp",-1); |
| 190 | # |
| 191 | # Create the replacement shapefile. |
| 192 | $tcounts = new shapefileObj("$sfile",$mapscript::MS_SHAPEFILE_POINT); |
| 193 | # |
| 194 | # Create the transfer point object. |
| 195 | my $trnspnt = new pointObj(); |
| 196 | # |
| 197 | # Loop through each existing point and recreate it in the new shapefile. |
| 198 | for ($epnt=0; $epnt<$dbfreccnt; $epnt++) { |
| 199 | # |
| 200 | # Get the existing point. |
| 201 | $ecounts->getPoint($epnt,$trnspnt); |
| 202 | # |
| 203 | # Put the point into the new shapefile. |
| 204 | $tcounts->addPoint($trnspnt); |
| 205 | } |
| 206 | } |
| 207 | else { |
| 208 | # |
| 209 | # Create the new file. |
| 210 | $tcounts = new shapefileObj("$sfile",$mapscript::MS_SHAPEFILE_POINT); |
| 211 | } |
| 212 | # |
| 213 | # Create the point object for insertion into the shapefile. |
| 214 | my $pnt = new pointObj(); |
| 215 | # |
| 216 | # Loop through each record. |
| 217 | # [0]=dontno1, [1]=tablenamechars, [2]=tablename, [3]=dontno2, [4]=#offields |
| 218 | for ($recrd=1; $recrd<$numrecs; $recrd++) { |
| 219 | # |
| 220 | # Create the array for tracking field offsets. |
| 221 | # To be used later while creating dbf records for each gps point. |
| 222 | my @offsets = (); |
| 223 | # |
| 224 | # Set the initial value for unpacking table name. |
| 225 | $unpackstr = "a38 n"; |
| 226 | @recordinfo = unpack($unpackstr, $records[$recrd]->{data}); |
| 227 | # |
| 228 | # The character count returned is actual + 1. |
| 229 | $recordinfo[1] = $recordinfo[1] - 1; |
| 230 | # |
| 231 | # Unpack the dontno1 and the table name length. |
| 232 | @recordinfo = unpack($unpackstr, $records[$recrd]->{data}); |
| 233 | # |
| 234 | # The character count returned is actual + 1. |
| 235 | $recordinfo[1] = $recordinfo[1] - 1; |
| 236 | |
| 237 | # |
| 238 | # Add the remainder of the record info to the unpack string |
| 239 | # (name, dontno2, #offields). |
| 240 | $unpackstr = $unpackstr . " a$recordinfo[1] a3 n"; |
| 241 | # |
| 242 | # Add the first 10 parts of the first field info to the unpack string. |
| 243 | # All fields appear to have these in common even if they are blank |
| 244 | # for fields that do not use the particular part. |
| 245 | # (fieldname, dontno3, datatype, isrange, null, upperlimit, lowerlimit, |
| 246 | # step, dontno4, fieldsize). |
| 247 | # [offset+0]=fieldname, [offset+1]=dontno3, [offset+2]=datatype |
| 248 | # [offset+3]=isrange, [offset+4]=null, |
| 249 | # [offset+5]=uppperlimit, [offset+6]=lowerlimit, [offset+7]=step, |
| 250 | # [offset+8]=dontno4, [offset+9]=fieldsize |
| 251 | $unpackstr = $unpackstr . " A19 a10 n n a N N N a14 n"; |
| 252 | # |
| 253 | # Set the inital value for the field offset |
| 254 | # (the number of parts for the previous field(s)). |
| 255 | my $fieldoffset = 0; |
| 256 | # |
| 257 | # Grab the rest of the record info and |
| 258 | # the field info up to the data length indicator. |
| 259 | ($recordinfo[0], $recordinfo[1], $recordinfo[2], $recordinfo[3], $recordinfo[4], @fieldinfo) = unpack $unpackstr, $records[$recrd]->{data}; |
| 260 | # |
| 261 | # The character count returned is actual + 1. |
| 262 | $recordinfo[1] = $recordinfo[1] - 1; |
| 263 | # |
| 264 | # |
| 265 | # Print the record info to see if we got this right. |
| 266 | #print "\nRecord # = $recrd\nNumber of Characters in Table Name = $recordinfo[1]\nTable Name = $recordinfo[2]\nNumber of Fields = $recordinfo[4]\n"; |
| 267 | # Loop through each field. |
| 268 | for ($fld=0; $fld<$recordinfo[4]; $fld++) { |
| 269 | # |
| 270 | # The actual field number to print is fld + 1. |
| 271 | my $fldprint = $fld + 1; |
| 272 | # |
| 273 | # Grab the field info up to the data length indicator. |
| 274 | ($recordinfo[0], $recordinfo[1], $recordinfo[2], $recordinfo[3], $recordinfo[4], @fieldinfo) = unpack $unpackstr, $records[$recrd]->{data}; |
| 275 | # |
| 276 | # The character count returned is actual + 1. |
| 277 | $recordinfo[1] = $recordinfo[1] - 1; |
| 278 | # |
| 279 | # What is the length of the data. |
| 280 | |
| 281 | my $dlength = $fieldinfo[$fieldoffset+9]; |
| 282 | # |
| 283 | # The field type comes in strange sometimes so this should truncate it |
| 284 | # so it only contains values of 0-10. |
| 285 | $fieldinfo[$fieldoffset+2] = 256 * ( ( $fieldinfo[$fieldoffset+2] / 256 ) - ( int( $fieldinfo[$fieldoffset+2] / 256 ) ) ); |
| 286 | # |
| 287 | # Okay, the same thing happens with the range. |
| 288 | $fieldinfo[$fieldoffset+3] = 256 * ( ( $fieldinfo[$fieldoffset+3] / 256 ) - ( int( $fieldinfo[$fieldoffset+3] / 256 ) ) ); |
| 289 | # |
| 290 | # Add to the unpack string the unpack string for the field type. |
| 291 | $unpackstr = $unpackstr . $ustring[$fieldinfo[$fieldoffset+2]]; |
| 292 | # |
| 293 | # For some reason the type appears to be 8-bit instead if 16. So |
| 294 | # to make sure |
| 295 | # |
| 296 | # Add to the array the rest of the parts for the field. |
| 297 | ($recordinfo[0], $recordinfo[1], $recordinfo[2], $recordinfo[3], $recordinfo[4], @fieldinfo) = unpack $unpackstr, $records[$recrd]->{data}; |
| 298 | # |
| 299 | # Escape out any unprintable characters in the field name. |
| 300 | $fieldinfo[$offsets[$iname]+0] = uc($fieldinfo[$offsets[$iname]+0]); |
| 301 | $fieldinfo[$offsets[$iname]+0] =~ s/[^\x41-\x5A]//g; |
| 302 | # |
| 303 | # The field type comes in strange sometimes so this should truncate it |
| 304 | # so it only contains values of 0-10. |
| 305 | # (binary/unpack guru applications now being accepted). |
| 306 | # Note: Basically this divides by base 16 to move the number 2 decimal |
| 307 | # places left then truncates the whole number and multiplies by |
| 308 | # base 16 to move the decimal 2 places right. |
| 309 | $fieldinfo[$fieldoffset+2] = 256 * ( ( $fieldinfo[$fieldoffset+2] / 256 ) - ( int( $fieldinfo[$fieldoffset+2] / 256 ) ) ); |
| 310 | # |
| 311 | # Okay, the same thing happens with the range. |
| 312 | $fieldinfo[$fieldoffset+3] = 256 * ( ( $fieldinfo[$fieldoffset+3] / 256 ) - ( int( $fieldinfo[$fieldoffset+3] / 256 ) ) ); |
| 313 | # |
| 314 | # Print the field info to see if we got this right. |
| 315 | #print "Field Offset = $fieldoffset\nField $fldprint Name = $fieldinfo[$fieldoffset+0]\nData Type = $fieldinfo[$fieldoffset+2]\nIsRange = $fieldinfo[$fieldoffset+3]\nUpper Limit = $fieldinfo[$fieldoffset+5]\nLower Limit = $fieldinfo[$fieldoffset+6]\nStep = $fieldinfo[$fieldoffset+7]\nField Size = $fieldinfo[$fieldoffset+9]\n"; |
| 316 | # |
| 317 | # How many data parts are there. |
| 318 | # The total number of field parts - 10 is the number of data parts. |
| 319 | my $dparts = $parts[$fieldinfo[$fieldoffset+2]]; |
| 320 | # |
| 321 | # Loop through each of the field value parts. |
| 322 | for ($dpart=10; $dpart<$dparts; $dpart++) { |
| 323 | # |
| 324 | # The actual data part id is the current dpart - 9 (0 thru 9 of the |
| 325 | # field array). |
| 326 | my $dprint = $dpart - 9; |
| 327 | # |
| 328 | # Print the field info to see if we got this right. |
| 329 | #print "Data Value $dprint = $fieldinfo[$fieldoffset+$dpart]\n"; |
| 330 | } |
| 331 | # |
| 332 | # If the field is a location convert the lat/long to state plane. |
| 333 | if ( $fieldinfo[$fieldoffset+2] == 4 ) { |
| 334 | # |
| 335 | # Do the convert. |
| 336 | # Bunches of notes: The projection name is latlong but supply |
| 337 | # the coordinates as long/lat. |
| 338 | # The +to section contains units of us-ft but MUST specify |
| 339 | # false_east(x_0) in meters. |
| 340 | # An indespensible resource was: |
| 341 | # http://www.edc.uri.edu/nrs/classes/NRS522/Tools/StatePlaneZones.htm |
| 342 | # Note: If I was smart I would have used the pointObj project method. |
| 343 | system("echo \'$fieldinfo[$fieldoffset+18]d$fieldinfo[$fieldoffset+20].$fieldinfo[$fieldoffset+22]W $fieldinfo[$fieldoffset+11]d$fieldinfo[$fieldoffset+13].$fieldinfo[$fieldoffset+15]N\' | cs2cs +proj=latlong +datum=NAD83 +to +proj=lcc +datum=NAD27 +units=ft +lon_0=-82.5 +lat_0=39.666666667 +lat_1=40.433333333 +lat_2=41.433333333 +x_0=609601.21920 +y_0=0 > /tmp/coordinates"); |
| 344 | # |
| 345 | # Open the coordinate file. |
| 346 | open(COORDS,"</tmp/coordinates"); |
| 347 | # |
| 348 | # Read the coordinates in. |
| 349 | my @coords = split('\t', <COORDS>); |
| 350 | my @northelev = split(' ',$coords[1]); |
| 351 | # |
| 352 | # Print out the coordinates to see if we have this right. |
| 353 | #print "Easting = $coords[0], Northing = $northelev[0], Elevation = $fieldinfo[$fieldoffset+16]\n"; |
| 354 | # |
| 355 | # Close the coordinate file. |
| 356 | close COORDS; |
| 357 | # |
| 358 | # Set the x & y for the point object. |
| 359 | $pnt->{x} = $coords[0]; |
| 360 | $pnt->{y} = $northelev[0]; |
| 361 | # |
| 362 | # Add the point to the shapefile. |
| 363 | $tcounts->addPoint($pnt); |
| 364 | } |
| 365 | # |
| 366 | # Print the unpack string to see if we got this right. |
| 367 | #print "UnPack String = $unpackstr\n"; |
| 368 | # |
| 369 | # Add the next fields standard 10 parts to the unpack string. |
| 370 | $unpackstr = $unpackstr . " A19 a10 n n a N N N a14 n"; |
| 371 | # |
| 372 | # Record where this field started at. |
| 373 | $offsets[$fld] = $fieldoffset; |
| 374 | # |
| 375 | # Set the field offset to include the now completed field. |
| 376 | $fieldoffset = $fieldoffset + $parts[$fieldinfo[$fieldoffset+2]]; |
| 377 | } |
| 378 | # |
| 379 | # Does the dbf need created and is this the first record. |
| 380 | if ( ( $dbfreccnt == -1 ) && ( $recrd == 1 ) ) { |
| 381 | # |
| 382 | |
| 383 | # Set the record count to 0. |
| 384 | $dbfreccnt = 0; |
| 385 | # |
| 386 | # How many fields are there. |
| 387 | my $fldcnt = scalar(@offsets); |
| 388 | # |
| 389 | # Initialize the field names, type, length, & decimal strings to blank. |
| 390 | my $fldnames = ''; |
| 391 | my $fldtypes = ''; |
| 392 | my $fldlenth = ''; |
| 393 | my $flddecml = ''; |
| 394 | # |
| 395 | # Loop through each field and concatenate the name, type, length, & decimal together. |
| 396 | for ($iname=0; $iname<$fldcnt; $iname++) { |
| 397 | # |
| 398 | # Escape out any unprintable characters in the field name. |
| 399 | $fieldinfo[$offsets[$iname]+0] = uc($fieldinfo[$offsets[$iname]+0]); |
| 400 | $fieldinfo[$offsets[$iname]+0] =~ s/[^\x41-\x5A]//g; |
| 401 | # |
| 402 | # The field type comes in strange sometimes so this should truncate it |
| 403 | # so it only contains values of 0-10. |
| 404 | # (binary/unpack guru applications now being accepted). |
| 405 | # Note: Basically this divides by base 16 to move the number 2 decimal |
| 406 | # places left then truncates the whole number and multiplies by |
| 407 | # base 16 to move the decimal 2 places right. |
| 408 | $fieldinfo[$offsets[$iname]+2] = 256 * ( ( $fieldinfo[$offsets[$iname]+2] / 256 ) - ( int( $fieldinfo[$offsets[$iname]+2] / 256 ) ) ); |
| 409 | # |
| 410 | # Okay, the same thing happens with the range. |
| 411 | $fieldinfo[$offsets[$iname]+3] = 256 * ( ( $fieldinfo[$offsets[$iname]+3] / 256 ) - ( int( $fieldinfo[$offsets[$iname]+3] / 256 ) ) ); |
| 412 | # |
| 413 | # Concatenate the field name. |
| 414 | $fldnames = $fldnames . ' "' . $fieldinfo[$offsets[$iname]+0] . '"'; |
| 415 | # |
| 416 | # Concatenate the field types. |
| 417 | $fldtypes = $fldtypes . ' "' . $dbfftype[$fieldinfo[$offsets[$iname]+2]] . '"'; |
| 418 | # |
| 419 | # Concatenate the field lengths. |
| 420 | $fldlenth = $fldlenth . ' "' . $dbffsize[$fieldinfo[$offsets[$iname]+2]] . '"'; |
| 421 | # |
| 422 | # Concatenate the field decimals. |
| 423 | # All undef right now. |
| 424 | $flddecml = $flddecml . ' "undef"'; |
| 425 | # |
| 426 | # If this is not the last field throw in a comma. |
| 427 | if ( $iname != ( $fldcnt - 1 ) ) { |
| 428 | $fldnames = $fldnames . ','; |
| 429 | $fldtypes = $fldtypes . ','; |
| 430 | $fldlenth = $fldlenth . ','; |
| 431 | $flddecml = $flddecml . ','; |
| 432 | } |
| 433 | } |
| 434 | # |
| 435 | # Add the fields for the record number and error flag. |
| 436 | $fldnames = $fldnames . ', "RECORD", "ERRFLAG"'; |
| 437 | $fldtypes = $fldtypes . ', "N", "N"'; |
| 438 | $fldlenth = $fldlenth . ', "6", "2"'; |
| 439 | $flddecml = $flddecml . ', "undef", "undef"'; |
| 440 | # |
| 441 | # Create the xbase call. |
| 442 | my $xbcall = 'XBase->create(name => "' . $sfile . '.dbf", field_names => [' . $fldnames . ' ], field_types => [' . $fldtypes . ' ], field_lengths => [' . $fldlenth . ' ], field_decimals => [' . $flddecml . ' ]) or die XBase->errstr;'; |
| 443 | # |
| 444 | # Print out the create line to see if we got this right. |
| 445 | #print "Field Names = $fldnames\nField Types = $fldtypes\nField Sizes = $fldlenth\nField Decimals = $flddecml\n"; |
| 446 | # |
| 447 | # Create the dbf file. |
| 448 | $dbh = eval($xbcall); |
| 449 | } |
| 450 | # |
| 451 | # Add the data for this pdb record to the dbf file. |
| 452 | # |
| 453 | # Start the xbase add-record call. |
| 454 | my $xbadd = '$dbh->set_record($dbfreccnt,'; |
| 455 | # |
| 456 | # How many fields are there. |
| 457 | my $fldcnt = scalar(@offsets); |
| 458 | # |
| 459 | # Go through each field and concatenate the values together. |
| 460 | for ($iname=0; $iname<$fldcnt; $iname++) { |
| 461 | # |
| 462 | # The field type comes in strange sometimes so this should truncate it |
| 463 | # so it only contains values of 0-10. |
| 464 | # (binary/unpack guru applications now being accepted). |
| 465 | # Note: Basically this divides by base 16 to move the number 2 decimal |
| 466 | # places left then truncates the whole number and multiplies by |
| 467 | |
| 468 | # base 16 to move the decimal 2 places right. |
| 469 | $fieldinfo[$offsets[$iname]+2] = 256 * ( ( $fieldinfo[$offsets[$iname]+2] / 256 ) - ( int( $fieldinfo[$offsets[$iname]+2] / 256 ) ) ); |
| 470 | # |
| 471 | # Is this a number type record. |
| 472 | if ( $fieldinfo[$offsets[$iname]+2] == 7 ) { |
| 473 | $xbadd = $xbadd . $fieldinfo[$offsets[$iname]+10]; |
| 474 | } |
| 475 | # |
| 476 | # Is this a location type record. |
| 477 | if ( $fieldinfo[$offsets[$iname]+2] == 4 ) { |
| 478 | $xbadd = $xbadd . '"' . $fieldinfo[$offsets[$iname]+18] . 'd' . $fieldinfo[$offsets[$iname]+20] . '.' . $fieldinfo[$offsets[$iname]+22] . 'W,' . $fieldinfo[$offsets[$iname]+11] . 'd' . $fieldinfo[$offsets[$iname]+13] . '.' . $fieldinfo[$offsets[$iname]+15] . 'N,' . $fieldinfo[$offsets[$iname]+16] . '"'; |
| 479 | } |
| 480 | # |
| 481 | # If this is not the last field throw in a comma. |
| 482 | if ( $iname != ( $fldcnt - 1 ) ) { |
| 483 | $xbadd = $xbadd . ','; |
| 484 | |
| 485 | } |
| 486 | } |
| 487 | # |
| 488 | # Add the closer to the end of the xbase add-record call. |
| 489 | $xbadd = $xbadd . ', ' . $dbfreccnt . ', 0);'; |
| 490 | # |
| 491 | # Print the xbase add-record line to see if we got this right. |
| 492 | #print "$xbadd\n"; |
| 493 | # |
| 494 | # Add the record to the dbf file. |
| 495 | eval($xbadd); |
| 496 | # |
| 497 | # Increment the record counter. |
| 498 | $dbfreccnt = $dbfreccnt + 1; |
| 499 | } |
| 500 | # |
| 501 | # Close the new shapefile. |
| 502 | undef $tcounts; |
| 503 | # |
| 504 | # Close the dbf handle/file. |
| 505 | undef $dbh; |
| 506 | # |
| 507 | # Get rid of temporary shapefiles if needed. |
| 508 | if ( -e "thistemp.shp" ) { |
| 509 | unlink "thistemp.shp"; |
| 510 | unlink "thistemp.shx"; |
| 511 | unlink "thistemp.dbf"; |
| 512 | } |
| 513 | }}} |
