| 1 | = ref_to_map_ext.pl = |
| 2 | |
| 3 | A perl mapscript 3.6.4 sub-routine which converts a reference map mouse click into new map extents for main map. Really just a code snippet. Very little error checking. |
| 4 | |
| 5 | Author: Eric Bridger eric@gomoos.org, eric@maine.com |
| 6 | ---- |
| 7 | {{{ |
| 8 | #!perl |
| 9 | # This is based entirely on the code in mapserver3.6.4 maptemplate.c::setExtent() case FROMREFPT |
| 10 | # calculate new map extents from mouse click in reference map. |
| 11 | # assumes CGI Form with: |
| 12 | # <input type="image" name="ref_map" src="mapserver_reference_map"> |
| 13 | # <input type="hidden" name="imgext" value="MINX MINY MAXX MAXY" |
| 14 | |
| 15 | use mapscript; |
| 16 | use CGI ":cgi"; |
| 17 | my $q = new CGI; |
| 18 | |
| 19 | $map = new mapscript::mapObj("mapfile.map"); |
| 20 | |
| 21 | # This routine sets $map->{extent}{minx}, etc. and returns the new map extent as a string, which can be |
| 22 | # set in the html form as your current hidden imgext variable. |
| 23 | |
| 24 | sub ref_to_map_ext { |
| 25 | my ($q, $map) = @_; |
| 26 | |
| 27 | # as default just return current map extent |
| 28 | my $mapext = join(' ', $map->{extent}->{minx},$map->{extent}->{miny},$map->{extent}->{maxx},$map->{extent}->{maxy}); |
| 29 | if(!$q->param('imgext')){ |
| 30 | return $mapext; |
| 31 | } |
| 32 | if(!$q->param('ref_map.x')){ |
| 33 | return $mapext; |
| 34 | } |
| 35 | |
| 36 | # get the current map extent from form imgext variable. |
| 37 | my @imgext = split(' ', $q->param('imgext')); |
| 38 | |
| 39 | # get mouse click x, y from ref_map image. |
| 40 | my $refx = $q->param('ref_map.x'); |
| 41 | my $refy = $q->param('ref_map.y'); |
| 42 | |
| 43 | # reference map vars from the map file |
| 44 | # These never change unless the map file changes. |
| 45 | my $ref_width = $map->{reference}{width}; |
| 46 | my $ref_height = $map->{reference}{height}; |
| 47 | my $ref_minx = $map->{reference}{extent}{minx}; |
| 48 | my $ref_maxx = $map->{reference}{extent}{maxx}; |
| 49 | my $ref_miny = $map->{reference}{extent}{miny}; |
| 50 | my $ref_maxy = $map->{reference}{extent}{maxy}; |
| 51 | |
| 52 | my $map_width = $map->{width}; |
| 53 | my $map_height = $map->{height}; |
| 54 | |
| 55 | my $cellx = ($ref_maxx - $ref_minx) / $ref_width; |
| 56 | my $celly = ($ref_maxy - $ref_miny)/ $ref_height; |
| 57 | my $map_x = $ref_minx + $cellx*$refx; |
| 58 | my $map_y = $ref_maxy - $celly*$refy; |
| 59 | |
| 60 | # set $map to new extent |
| 61 | $map->{extent}->{minx} = $map_x - .5*($imgext[2] - $imgext[0]); # calculate new extent |
| 62 | $map->{extent}->{miny} = $map_y - .5*($imgext[3] - $imgext[1]); |
| 63 | $map->{extent}->{maxx} = $map_x + .5*($imgext[2] - $imgext[0]); |
| 64 | $map->{extent}->{maxy} = $map_y + .5*($imgext[3] - $imgext[1]); |
| 65 | |
| 66 | # reset $mapext to new value |
| 67 | $mapext = join(' ', $map->{extent}->{minx},$map->{extent}->{miny},$map->{extent}->{maxx},$map->{extent}->{maxy}); |
| 68 | |
| 69 | return($mapext); |
| 70 | } |
| 71 | }}} |
| 72 | = Partial map file = |
| 73 | {{{ |
| 74 | ############################################################ |
| 75 | # A patial map file. |
| 76 | ####################### |
| 77 | MAP |
| 78 | STATUS ON |
| 79 | EXTENT -71.50 39.5 -63.0 46.0 # MINX MINY MAXX MAXY |
| 80 | SIZE 504 385 |
| 81 | UNITS DD |
| 82 | IMAGETYPE PNG |
| 83 | |
| 84 | # reference map |
| 85 | REFERENCE |
| 86 | STATUS ON |
| 87 | IMAGE "../../data/mapserver/raster/gom/ref_gom30b.png" |
| 88 | SIZE 150 115 |
| 89 | EXTENT -71.5 39.5 -63.0 46.0 # MINX MINY MAXX MAXY |
| 90 | COLOR -1 -1 -1 |
| 91 | OUTLINECOLOR 255 0 0 |
| 92 | END |
| 93 | }}} |
| 94 | ---- |
| 95 | back to PerlMapScript |
