Changes between Version 11 and Version 12 of INSPIRE
- Feb 8, 2011, 6:47:39 AM (13 years ago)
INSPIRE
v11 v12 20 20 The following enhancements have to be implemented: 21 21 22 * extended getcapabilities document with inspire specific metadata23 * multi-language support for some capabilities fields24 * named layer groups22 * [#VS_GetCapabilities extended getcapabilities document with inspire specific metadata] 23 * [#VS_MultiLanguage multi-language support for some capabilities fields] 24 * [#VS_GroupedLayers named layer groups] 25 25 26 26 Tickets: … … 35 35 * http://osgeo-org.1803224.n2.nabble.com/file/n5661761/MS_RFC_INSPIRE.pdf 36 36 37 === Getcapabilities document ===37 === Extended Getcapabilities document ===#VS_GetCapabilities 38 38 39 39 1. Links to documents extracted from the reference document … … 42 42 43 43 2. Tasks 44 a. ability to specify in a map file that this is an INSPIR eView Service44 a. ability to specify in a map file that this is an INSPIRE View Service 45 45 b. add a link to the inspire schema as part of the overall schema list 46 46 c. generate an ExtendedCapabilities 47 d. include all elements by reading inspire type metadata 48 e. all other metadata outside that extended capabilities should already be part of the regular wms output ('''todo: check if WMS 1.3.0 and INSPIRE View Service have to same mandatory elements; if so remove this entry, otherwise warnings have to be adapted''') 47 d. present grouped layers with name and full metadata 48 e. include all elements by reading inspire type metadata 49 f. all other metadata outside that extended capabilities should already be part of the regular wms output ('''todo: check if WMS 1.3.0 and INSPIRE View Service have to same mandatory elements; if so remove this entry, otherwise warnings have to be adapted''') 49 50 50 51 3. Implementations … … 52 53 b. add ''xmlns:inspire_vs="http://inspire.europa.eu/networkservice/view/1.0"'' to getcapabilities document 53 54 c. ? 54 d. Parse the following metadata at top and layer lavel: inspire_resource_type_code, inspire_resource_type_value ... 55 d. [#VS_GroupedLayers independent topic] 56 e. Parse the following metadata at top and layer level: inspire_resource_type_code, inspire_resource_type_value ... 57 f. '''remove this if WMS 1.3 and VS have identical mandatory metadata''' 55 58 56 59 === Mandatory (M) and Optional (O) metadata the need to be supported === … … 77 80 * Current Language (M) 78 81 79 === Presentation of layers in a GetCapabilities document ===80 81 1. Ability to use grouped layers82 * see details in ticket:163283 82 84 83 85 84 86 85 87 === Multi-Language support === 86 === Multi-Language support ===#VS_MultiLanguage 88 87 89 === Grouped layers and DescribeLayer request ===88 === Grouped layers ===#VS_GroupedLayers 90 89 91 === Grouped layers and GetMap request === 90 see details in ticket:1632 92 91 93 === Grouped layers and SLD===92 * Grouped layers and DescribeLayer request === 94 93 95 === Grouped layers and GetFeatureInfo request === 94 * Grouped layers and GetMap request === 95 96 * Grouped layers and SLD === 97 98 * Grouped layers and GetFeatureInfo request === 96 99 97 100
