6 | | - treating class TEXT expressions as true expressions instead of just doing substitutions. Allows advanced formatting options such as rounding, adding commas to numbers, case adjustments and so on. Totally changes meaning of this attribute. |
7 | | - drop support for trailing i's to denote case-insensitive searches. Instead use case-insensitive operators for string (=*) and regex (~*). Simplifies expression syntax and lexer code significantly. Case insensitive regex has never worked. |
8 | | - drop //'s for right-hand portion of regex comparisons in logical expressions. Again, simplifies parser and is more inline with RDBMS SQL (PostgreSQL and MySQL do this). Users would just mark the expression with quotes. This would be consistent with regex use elsewhere in mapfiles and would leave regex expressions (e.g. EXPRESSION /foo/) as the only time the //'s are used. |
| 6 | - treating class TEXT expressions as true expressions instead of just doing substitutions. Allows advanced formatting options such as rounding, adding commas to numbers, case adjustments and so on. Totally changes meaning of this attribute. |
| 7 | - drop support for trailing i's to denote case-insensitive searches. Instead use case-insensitive operators for string (=*) and regex (~*). Simplifies expression syntax and lexer code significantly. Case insensitive regex has never worked. |
| 8 | - drop //'s for right-hand portion of regex comparisons in logical expressions. Again, simplifies parser and is more inline with RDBMS SQL (PostgreSQL and MySQL do this). Users would just mark the expression with quotes. This would be consistent with regex use elsewhere in mapfiles and would leave regex expressions (e.g. EXPRESSION /foo/) as the only time the //'s are used. |
