2 | | mode shows that LabelAngle is always read as zero while text string and color are correctly read. Worse : i tried with more recent releases of GDAL and/or MS (home made or MS4W ones) but they always crash when i’m trying to use [OGR :LabelSize] (other attributes behave fine except - still - the angle). When it happens, the debug file shows that every attributes is read as empty or zero. |
3 | | The last working context was GDAL 1.5.2 with MS 5.0 .3, and only the DGN format seems to be impacted (MITAB stills behaves OK). The OGR style string seems correct, and changing the parameters order (so that it looks like MITAB’s) didn’t help. The code in mapogr.cpp seems fine and except the conditional compilation settings regarding OGR Style C API which was not used in MS 5.0.x i don’t know what could cause this behaviour, except the OGR DGN driver itself (memory handling issue ?). |
| 2 | mode shows that LabelAngle is always read as zero while text string and color are correctly read. |
| 3 | |
| 4 | Worse : i tried with more recent releases of GDAL and/or MS (home made or MS4W ones) but they always crash when i’m trying to use [OGR :LabelSize] (other attributes behave fine except - still - the angle). When it happens, the debug file shows that every attributes is read as empty or zero. |
| 5 | |
| 6 | The last working context was GDAL 1.5.2 with MS 5.0.3, and only the DGN format seems to be impacted (MITAB stills behaves OK). The OGR style string seems correct, and changing the parameters order (so that it looks like MITAB’s) didn’t help. |
| 7 | |
| 8 | The code in mapogr.cpp seems fine and except the conditional compilation settings regarding OGR Style C API which was not used in MS 5.0.x i don’t know what could cause this behaviour, except the OGR DGN driver itself (memory handling issue ?). |
