Changes between Version 1 and Version 2 of maestro/MaestroAPI/samples/RuntimeMap
- 08/26/08 01:32:37 (17 years ago)
TabularUnified maestro/MaestroAPI/samples/RuntimeMap
v1 v2 36 36 }}} 37 37 38 Having a reference to RuntimeMap enables us manipulating Library-resident map "clone" (see conn.CreateRuntimeMap) sitting in a Session. Don't forget - each MG Session may have different instance of RuntimeMap in it. When RuntimeMap is created, it's properties (including layers, layer visibility, etc.) is inherited from the original MapDefinition. Let's change visibility of PARCELS layer initially turned off:38 Having a reference to RuntimeMap enables us manipulating Library-resident map "clone" (see conn.CreateRuntimeMap) sitting in a Session. Don't forget - each MG Session may have different instance of RuntimeMap in it. When RuntimeMap is created, it's properties (including layers, layer visibility, etc.) is inherited from the original MapDefinition. Let's change visibility of PARCELS layer initially being turned off: 39 39 40 40 {{{
