Changes between Version 2 and Version 3 of WikiPageNames
04/22/15 15:23:13 (10 years ago)
  • TabularUnified WikiPageNames
    v2 v3
    1 = Wiki Page Names =
     1= Wiki Page Names
    22[[TracGuideToc]]
    44Wiki page names commonly use the CamelCase convention. Within wiki text, any word in CamelCase automatically becomes a hyperlink to the wiki page with that name.
    6 CamelCase page names must follow these rules:
     6CamelCase page names follow these rules:
    8  1. The name must consist of '''alphabetic characters only'''. No digits, spaces, punctuation, or underscores are allowed.
    9  2. A name must have at least two capital letters.
    10  3. The first character must be capitalized.
    11  4. Every capital letter must be followed by one or more lower-case letters.
    12  5. The use of slash ( / ) is permitted in page names (possibly representing a hierarchy).
     8 1. The name must consist of '''alphabetic characters only'''; no digits, spaces, punctuation or underscores are allowed.
     9 1. A name must have at least two capital letters.
     10 1. The first character must be capitalized.
     11 1. Every capital letter must be followed by one or more lower-case letters.
     12 1. The use of slash ( / ) is permitted in page names, where it typically represents a hierarchy.
    1313
    14 If you want to create a wiki page that doesn't follow CamelCase rules you can use the following syntax:
     14If you want to create a wiki page that does not follow CamelCase rules. you can use the following syntax:
    1515{{{
    16  * [wiki:Wiki_page], [wiki:ISO9000]
    17  * [wiki:"Space Matters"] that page name embeds space characters
    18  * or simply: ["WikiPageName"]s (!MoinMoin's internal free links style)
     16 * [wiki:Wiki_page], [wiki:ISO9000],
     17   and with a label: [wiki:ISO9000 ISO 9000 standard]
     18 * [wiki:"Space Matters"]
     19   and with a label: [wiki:"Space Matters" all about white space]
     20 * or simply: ["WikiPageName"]s
     21 * even better, the new [[WikiCreole link style]]
     22   and with a label: [[WikiCreole link style|WikiCreole style links]]
    1923}}}
    2024
    2125This will be rendered as:
    22  * [wiki:Wiki_page], [wiki:ISO9000]
    23  * [wiki:"Space Matters"] that page name embeds space characters
    24  * or simply: ["WikiPageName"]s (!MoinMoin's internal free links style)
     26 * [wiki:Wiki_page], [wiki:ISO9000],
     27   and with a label: [wiki:ISO9000 ISO 9000 standard]
     28 * [wiki:"Space Matters"] ''(that page name embeds space characters)''
     29   and with a label: [wiki:"Space Matters" all about white space]
     30 * or simply: ["WikiPageName"]s
     31 * even better, the new [[WikiCreole link style]]
     32   and with a label: [[WikiCreole link style|WikiCreole style links]]
    2533
    26 Starting with Trac 0.11, it's also possible to link to a specific ''version'' of a Wiki page, as you would do for a specific version of a file, for example: WikiStart@1.
     34It is possible to link to a specific ''version'' of a Wiki page as you would do for a specific version of a file, for example: WikiStart@1.
    2735
    28 See also TracLinks#QuotingspaceinTracLinks.
     36You can also prevent a !CamelCase name from being interpreted as a [TracLinks link] by quoting it with an exclamation mark: `!CamelCase`. See TracLinks#EscapingLinks.
    2937
    30 Finally, and as exemplified in the line above, one can also append an anchor to a Wiki page name, in order to link to a specific section within that page. The anchor can easily be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it's also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading.
     38As in the example above, you can also append an anchor to a Wiki page name to link to a specific section within that page. The anchor can be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it is also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading.
     39
    3140----
    3241See also: WikiNewPage, WikiFormatting, TracWiki, TracLinks
