Changes between Version 13 and Version 14 of Release/3.1/Notes
07/27/16 07:20:38 (9 years ago)
jng
  • TabularUnified Release/3.1/Notes
    v13 v14
    220220Note that upgrading Apache from 2.2.x to 2.4.x has introduced changes to some configuration directives. If you have any custom httpd directives defined in your current MapGuide installation, please consult the [https://httpd.apache.org/docs/2.4/upgrading.html upgrade notes] for any changes you have to do when migrating/upgrading your Apache-based MapGuide installation to this release.
    221221
    222 If you have PHP-based MapGuide applications, consult the [http://php.net/manual/en/migration54.php 5.3 to 5.4 migration guide] and [http://php.net/manual/en/migration55.php 5.4 to 5.5 migration guide] for any API and compatibility issues that may be present in your MapGuide application as a result of moving to PHP 5.5
     222If you have PHP-based MapGuide applications, consult the [http://php.net/manual/en/migration54.php 5.3 to 5.4 migration guide],[http://php.net/manual/en/migration55.php 5.4 to 5.5 migration guide] and [http://php.net/manual/en/migration56.php 5.5 to 5.6 migration guide] for any API and compatibility issues that may be present in your MapGuide application as a result of moving to PHP 5.5
    223223
    224224Should you choose to uninstall the Linux build of this release at any time, download and the respective uninstaller script. This ensures that any proper service un-registration is also performed.
