Changes between Version 16 and Version 17 of Release/2.4/Notes
- Jun 18, 2012, 4:56:16 AM (12 years ago)
Release/2.4/Notes
v16 v17 112 112 FDO is compiled against the Oracle 11.2 instant client available from [http://www.oracle.com/technology/software/tech/oci/instantclient/index.html?rssid=rss_otn_soft Instant Client Downloads]. For a Linux installation, the Oracle shared library path should be included in LD_LIBRARY_PATH or ldconfig. 113 113 114 FDO is compiled against GDAL 1.9114 FDO 3.7 is compiled against GDAL 1.9. 115 115 116 116 == Installer notes == … … 125 125 * For IIS6 and below, download and install the FastCGI extension from [http://www.iis.net/download/FastCGI this link] 126 126 * For IIS7 and above, you can install FastCGI by enabling the CGI feature of your IIS installation. See [http://learn.iis.net/page.aspx/246/using-fastcgi-to-host-php-applications-on-iis/#EnableFastCGI this link] for more information. 127 * The supported .net Framework version for the MapGuide .net API is '''4.0''' 127 * The supported .net Framework version for the MapGuide .net API is '''4.0'''. You must have this version of the .net Framework installed before proceeding with installation. 128 128 * ~~For IIS6 and below, the installer will still set the ASP.net version to '''2.0.50727'''. You will have to manually change the ASP.net version to '''4.0.30319''' post-install~~ 129 130 Java configuration requires Java 6 (1.6.0) or higher. 129 131 130 132 The MgInstantSetup bundles only work with '''IIS7 or higher''' if you choose to use this web server. You must still satisfy the .net and FastCGI software requirements required for this configuration. … … 141 143 142 144 For the InstantSetup bundles, the MgInstantSetup utility requires .net Framework 3.5 to run. This is in addition to whatever existing software requirements imposed by this release of MapGuide Open Source. 145 146 For Tomcat configuration, the installer currently does not install Tomcat as a service (#953). You will have to do this manually post-installation. 147 148 Also ensure that you install the JVM of the same bitness as your installation of MapGuide. For example, you will get a {{{java.lang.UnsatisfiedLinkError}}} if you attempt to run a Tomcat from a 32-bit MapGuide installation on a 64-bit JVM. If you have both 32 and 64-bit JVMs installed, you must ensure that the Tomcat bundled with MapGuide is using the correct one. Tomcat will generally use the one indicated by the {{{JAVA_HOME}}} environment variable, so this may have to be set and/or overridden. 143 149 144 150 ~~Although Ubuntu 11.10 was the only tested platform as of this writing. The ubuntu binaries are also known to work with the latest release as well (12.04)~~
