Changes between Version 15 and Version 16 of MapGuideRfc86
- Sep 24, 2009, 8:01:12 PM (15 years ago)
MapGuideRfc86
v15 v16 34 34 * MgFeatureSerive::!BeginTransaction will do something on the DRBMS serverwhen opening a transaction. This has consequences such as updates are only visible in this transaction, and data gets locked. 35 35 36 Another issue is that it may result in a whole bunch of connections are open when using MgFeatureReader, MgDataReader orMgSqlDataReader. Each reader will use an FDO connection exclusively. So in the example below, it will have all of a sudden a whole bunch of admin connections open when you open a connection with admin rights.36 Another issue is that it may result in a whole bunch of connections are open when using !MgFeatureReader, !MgDataReader or !MgSqlDataReader. Each reader will use an FDO connection exclusively. So in the example below, it will have all of a sudden a whole bunch of admin connections open when you open a connection with admin rights. 37 37 38 38 {{{ … … 46 46 } 47 47 reader2.Close(); 48 reader .Dispose();48 reader2.Dispose(); 49 49 } 50 50 reader1.Close();
