Changes between Version 7 and Version 8 of MapGuideRfc6
- Feb 6, 2007, 11:13:06 AM (17 years ago)
MapGuideRfc6
v7 v8 78 78 == Implications == 79 79 80 If the !SupplementalSpatialContextInfo contains a spatial context with a coordinate system, then that is the coordinate system which will be used on the data. It will override any coordinate system contained in the data. This is the behaviour that will change.80 If the !SupplementalSpatialContextInfo contains a spatial context with a coordinate system, then that is the coordinate system which will be used on the data. It will override any coordinate system contained in the data. This is the behaviour that is changing. 81 81 82 If the feature source does not contain a spatial context with a coordinate system, then the coordinate system contained in the data will be used. This behaviour is the same as before.82 If the feature source does not contain a spatial context with a coordinate system, then the coordinate system contained in the data will be used. This behaviour is not changing. 83 83 84 84 == Test Plan ==
