Changes between Version 9 and Version 10 of MapGuideRfc60
04/16/09 16:52:47 (16 years ago)
uvlite
moved color collection into VectorScaleRange object
  • TabularUnified MapGuideRfc60
    v9 v10
    6161The interesting task is how to feed the base colors of the map to the Image Renderer making the image.
    6262The base colors of a map can be extracted most efficiently during map generation in MapingUtil::StylizeLayers().
    63 To do this the VectorLayerDefiniton gets an additional method called VectorLayerDefiniton::ComputeUsedColors(scaleRange).
    64 At the end of the stylization this method is called and the resulting color list is stored in the runtime map object MgMap.
    65 (Map->SetColorPalette(pStringColorList))
     63To do this the VectorScaleRange gets an additional method called VectorScaleRange::GetUsedColorList().
     64This is a computed property implemented as a singleton which creates the list upon access. Subsequent requests from other threads read the same list.
     65At the end of the stylization GetUsedColorList is called and the resulting color list is stored in the runtime map object MgMap.
     66(Map->SetColorPalette(pStringColorList)) This method sorts and uniquifies the color list upon storage.
    6667
    67 The RenderingService reads the color list from the map object, sorts and uniquifies it, and converts it into a more appropriate Colortype.
     68The colors from the MdfMModel are MdfStrings and the algorithm simply collects all different strings. So in order to support expressions for those colors the list simply needs to be interpreted when read from the MgMap object.
     69
     70The RenderingService reads the color list from the map object, and converts it into a list of RsColor objects.
    6871This color palette is then passed down via the AGGRenderer to the AGGImageIO objects Save method. Here the png color quantification
    6972algorithm is included to force the provided palette into the rendered image - this way making sure that the correct base colors survive the compression and/or color quantization.
    7275== Implications ==
    7376
    74 No Implications are intended as this behaviour is desired by default. We just get better looking maps. The cost of extracting the colors from the in-memory representation of the XML data describing the map are presumed to be negligable.
     77No Implications are intended as this behaviour is desired by default. We just get better looking maps. The cost of extracting the colors from the in-memory representation of the XML data describing the map are presumed to be negligable. However, the color quantification can be costly.
    7578
    7679== Test Plan ==
    1081115. Possible memory issues: I think the current approach follows an easy producer consumer style regarding the color tables. [[BR]]
    109112My insight into the server architecture is limited and I am not 100% sure if all possible memory leaks have been avoided.
     113
     1146. The algorithm parsing the MdfModel simply collects all different MdfStrings from the color fields. In order to support expressions for those colors the list simply needs to be reinterpreted when read from the MgMap object. Lacking useful test cases this has not been done as yet.
