Changes between Version 5 and Version 6 of MapGuideRfc45
01/27/08 20:44:59 (17 years ago)
waltweltonlair
  • TabularUnified MapGuideRfc45
    v5 v6
    4545== Implications ==
    4646
    47 When providing resource files that use the extended format, a default file that uses the basic format must also be provided.  This can simply be a copy of one of the extended versions.
    48
    49 Extended format resource files need to use the (lower)-(upper) convention (matters in Linux where filenames are case-sensitive).
     47 * There are no backwards compatibility issues: HTTP requests using the basic format will continue to work.
     48 * When providing resource files that use the extended format, a default file that uses the basic format must also be provided.  This can simply be a copy of one of the extended versions.
     49 * Extended format resource files need to use the (lower)-(upper) convention (matters in Linux where filenames are case-sensitive).
    5050
    5151
    5252== Test Plan ==
    5353
    54
     54Update the web tier test pages to make HTTP requests using both the basic and extended formats.
    5555
    5656
