Changes between Version 24 and Version 25 of MapGuideRfc29
11/07/07 08:26:52 (17 years ago)
waltweltonlair
  • TabularUnified MapGuideRfc29
    v24 v25
    314314
    315315Supplied by Autodesk.
     316
     317
     318== Addendum, November 7, 2007 ==
     319
     320The following additional schema change has been made:
     321
     322 * the default value for !LineUsage.!VertexControl has been changed to '!OverlapWrap' in version 1.1.0 of the !SymbolDefinition schema.
     323
     324The default value for !VertexControl in schema version 1.0.0 is '!OverlapNone'.  With this setting symbols are distributed along the polyline according to the offset / repeat parameters, but no symbols are drawn so that they overlap a vertex where the feature geometry changes by more than the !VertexAngleLimit.  In the case of dense data (not uncommon in a mapping context) it means portions of many features will be drawn with a default solid line style instead of with the symbol defining a custom line style.
     325
     326Also, in the old stylization the behavior of line styles is effectively the same as with wrapping enabled.
     327
     328Based on these two items we feel that a default !VertexControl value of '!OverlapWrap' is a better choice, and is the value that gives the line style behavior most users are expecting.
