Changes between Version 7 and Version 8 of MapGuideRfc25
08/09/07 13:49:40 (18 years ago)
jasonchen
  • TabularUnified MapGuideRfc25
    v7 v8
    3535== Proposed Solution ==
    3636
    37 An additioanl OEM component has been added to the source -- jsoncpp. Jsoncpp is a C++ implementation of the JSON specification (http://sourceforge.net/projects/jsoncpp/).
     37An additioanl OEM component has been added to the source -- jsoncpp. Jsoncpp is a C++ implementation of the JSON specification ([http://sourceforge.net/projects/jsoncpp/]).
     38
     39----
    3840
    3941Two additional classes have been added to assist the JSON implementation in !MapGuide:
    4042
    41 1) The !MgJsonDoc Class
    42
     431) The !MgJsonDoc Class [[BR]]
    4344- !MgJsonDoc is a wrapper over the jsoncpp implementation. !MgJsonDoc provides many easy-to-use interfaces, such as Begin* and End*, for creating JSON documents from an XML perspective. For example, to create as JSON document for the corresponding XML content---<Node>Text</Node>---, one would call !BeginObject("Node"), !SetValue("Text"), and !EndObject() subsequently.
    4445
    45 2) The !MgXmlJsonConvert Class
     462) The !MgXmlJsonConvert Class [[BR]]
     47- !MgXmlJsonConvert converts an XML document into a JSON formatted document.
    4648
    47 - !MgXmlJsonConvert converts an XML document into a JSON formatted document.
     49----
    4850
    4951The following Web-tier to Server APIs are affected:
    5153Coordinate System
    5254
    53 # !EnumerateCategories (1)
    54
    55 # !EnumerateCoordinateSystems (1)
     55# !EnumerateCategories (1) [[BR]]
     56# !EnumerateCoordinateSystems (1) [[BR]]
    5657
    5758Resource
    5859
    59 # !EnumerateResourceReferences (3)
    60
    61 # !EnumerateResources (3)
    62
    63 # !GetResourceContent (3)
    64
    65 # !GetResourceHeader (3)
    66
    67 # !EnumerateResourceData (3)
    68
    69 # !GetResourceData (3)
    70
    71 # !EnumerateUnmanagedData (3)
     60# !EnumerateResourceReferences (3) [[BR]]
     61# !EnumerateResources (3) [[BR]]
     62# !GetResourceContent (3) [[BR]]
     63# !GetResourceHeader (3) [[BR]]
     64# !EnumerateResourceData (3) [[BR]]
     65# !GetResourceData (3) [[BR]]
     66# !EnumerateUnmanagedData (3) [[BR]]
    7267
    7368Feature
    7469
    75 # !GetFeatureProviders (3)
    76
    77 # !GetCapabilities (3)
    78
    79 # !GetConnectPropertyValues (1)
    80
    81 # !DescribeSchema (4)
    82
    83 # !SelectFeatures (2)
    84
    85 # !SelectAggregates (1)
    86
    87 # !GetSpatialContexts (1)
    88
    89 # !GetLongTransactions (1)
    90
    91 # !EnumerateDataStores (3)
    92
    93 # !GetSchemaMapping (3)
    94
    95 # !GetSchemas (1)
    96
    97 # !GetClasses (1)
    98
    99 # !GetClassDefinition (2)
    100
    101 # !GetIdentityProperties (1)
    102
    103 # !ExecuteSqlQuery (1)
    104
    105 # !GetFdoCacheInfo (4)
     70# !GetFeatureProviders (3) [[BR]]
     71# !GetCapabilities (3) [[BR]]
     72# !GetConnectPropertyValues (1) [[BR]]
     73# !DescribeSchema (4) [[BR]]
     74# !SelectFeatures (2) [[BR]]
     75# !SelectAggregates (1) [[BR]]
     76# !GetSpatialContexts (1) [[BR]]
     77# !GetLongTransactions (1) [[BR]]
     78# !EnumerateDataStores (3) [[BR]]
     79# !GetSchemaMapping (3) [[BR]]
     80# !GetSchemas (1) [[BR]]
     81# !GetClasses (1) [[BR]]
     82# !GetClassDefinition (2) [[BR]]
     83# !GetIdentityProperties (1) [[BR]]
     84# !ExecuteSqlQuery (1) [[BR]]
     85# !GetFdoCacheInfo (4) [[BR]]
    10686
    10787Rendering
    10888
    109 # !GetVisibleMapExtent (1)
     89# !GetVisibleMapExtent (1) [[BR]]
    11090
    11191where the appended labeling scheme indicates the different implementation considerations:
    112
    113 (1) Web-tier changes -- every !ToXml function is matched with an !ToJson function implementation that creates a JSON document in place,
    114
    115 (2) Web-tier changes -- utilizes the !MgXmlJsonConvert class to convert XML documents to JSON documents.
    116
    117 (3) Server changes -- an extra parameter "CREFSTRING format" has been added to the respective API call; the !MgXmlJsonConvert class is used if format equals to the JSON MIME type.
    118
     92(1) Web-tier changes -- every !ToXml function is matched with an !ToJson function implementation that creates a JSON document in place, [[BR]]
     93(2) Web-tier changes -- utilizes the !MgXmlJsonConvert class to convert XML documents to JSON documents. [[BR]]
     94(3) Server changes -- an extra parameter "CREFSTRING format" has been added to the respective API call; the !MgXmlJsonConvert class is used if format equals to the JSON MIME type. [[BR]]
    11995(4) Server changes -- an extra API has been added matching the respective API call (e.g. !DescribeSchemaAsXml has !DescribeSchemaAsJson as the JSON version, and !GetFDOCacheInfo has !GetFDOCacheInfoAsJson as its JSON specific implementation); this is because the original APIs return "STRING" and could not be efficiently adapted by the conversion process within the !MgXmlJsonConvert class implementation; and for the affected APIs, the !MgByteReader* is returned instead.
    120
    12196
    12297== Implications ==
