Changes between Version 2 and Version 3 of MapGuideRfc17
- Feb 26, 2007, 9:03:25 AM (17 years ago)
MapGuideRfc17
v2 v3 35 35 === Layer Definition Schema Modifications === 36 36 37 The layer definition schema contains numerous <!ExtendedData1> elements that allow the schema to be extended without breaking forward or backward compatibility. The changes proposed in this RFC would initially be added into one of these elements, and would eventually be moved to the main part of the schema whenever the next schema version update is carried out. See [http://wiki.osgeo.org/index.php/MapGuide_RFC_10_-_Make_Schemas_More_Amenable_to_Interim_Enhancements MapGuide RFC 10] for more details.37 The schema modifications could be made forward/backward compatible by adding them to the <!ExtendedData1> elements that already exist in the schema. See [wiki:MapGuideRfc10 MapGuide RFC 10] for details on extended data. However, it seems likely that [wiki:MapGuideRfc14 MapGuide RFC 14] will require a schema version update, in which case the modifications from this RFC (and [wiki:MapGuideRfc16 MapGuide RFC 16]) can be rolled into the same update. The schema changes described below assume we are not using extended data. 38 38 39 The affected section of the original schema looks likethis:39 The element type that specifies the style of polylines and polygon edges in the layer definition schema is <StrokeType>. It would be modified from this: 40 40 41 41 {{{ 42 <xs:complexType name="VectorScaleRangeType"> 42 <xs:complexType name="StrokeType"> 43 <xs:annotation> 44 <xs:documentation>Encapsulates the stylization of a line. 45 </xs:documentation> 46 </xs:annotation> 43 47 <xs:sequence> 44 <xs:element name="MinScale" type="xs:double" minOccurs="0">... 45 <xs:element name="MaxScale" type="xs:double" minOccurs="0">... 46 <xs:choice minOccurs="0" maxOccurs="unbounded"> 47 <xs:element name="AreaTypeStyle" type="AreaTypeStyleType">... 48 <xs:element name="LineTypeStyle" type="LineTypeStyleType">... 49 <xs:element name="PointTypeStyle" type="PointTypeStyleType">... 50 </xs:choice> 48 <xs:element name="LineStyle" type="xs:string"/> 49 <xs:element name="Thickness" type="xs:string"/> 50 <xs:element name="Color" type="xs:string"/> 51 <xs:element name="Unit" type="LengthUnitType"> 52 <xs:annotation> 53 <xs:documentation>Unit of measurement that the thickness is specified in</xs:documentation> 54 </xs:annotation> 55 </xs:element> 51 56 <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0" /> 52 57 </xs:sequence> … … 54 59 }}} 55 60 56 With the proposed changes, it would look likethis:61 to this: 57 62 58 63 {{{ 59 <xs:complexType name="VectorScaleRangeType"> 64 <xs:complexType name="StrokeType"> 65 <xs:annotation> 66 <xs:documentation>Encapsulates the stylization of a line. 67 </xs:documentation> 68 </xs:annotation> 60 69 <xs:sequence> 61 <xs:element name="MinScale" type="xs:double" minOccurs="0">... 62 <xs:element name="MaxScale" type="xs:double" minOccurs="0">... 63 <xs:choice minOccurs="0" maxOccurs="unbounded"> 64 <xs:element name="AreaTypeStyle" type="AreaTypeStyleType">... 65 <xs:element name="LineTypeStyle" type="LineTypeStyleType">... 66 <xs:element name="PointTypeStyle" type="PointTypeStyleType">... 67 </xs:choice> 68 <xs:element name="ExtendedData1" minOccurs="0" > 69 <xs:complexType> 70 <xs:sequence> 71 <xs:element name="ElevationSettings" type="ElevationSettingsType" minOccurs="0" /> 72 <xs:element name="ExtendedData2" type="ExtendedDataType" minOccurs="0" /> 73 </xs:sequence> 74 </xs:complexType> 70 <xs:element name="LineStyle" type="xs:string"/> 71 <xs:element name="Thickness" type="xs:string"/> 72 <xs:element name="Color" type="xs:string"/> 73 <xs:element name="Unit" type="LengthUnitType"> 74 <xs:annotation> 75 <xs:documentation>Unit of measurement that the thickness is specified in</xs:documentation> 76 </xs:annotation> 75 77 </xs:element> 76 </xs:sequence> 77 </xs:complexType> 78 <xs:complexType name="ElevationSettingsType"> 79 <xs:sequence> 80 <xs:element name="ZOffset" type="xs:string" minOccurs="0" /> 81 <xs:element name="ZExtrusion" type="xs:string" minOccurs="0" /> 82 <xs:element name="ZOffsetType" type="ElevationTypeType" minOccurs="0" /> 78 <xs:element name="SizeContext" type="SizeContextType"> 79 <xs:annotation> 80 <xs:documentation>Whether the sizes are with respect to the earth or the user's display device.</xs:documentation> 81 </xs:annotation> 82 </xs:element> 83 83 <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0" /> 84 84 </xs:sequence> 85 85 </xs:complexType> 86 <xs:simpleType name="ElevationTypeType">87 <xs:annotation>88 <xs:documentation>The possible interpretations of a ZOffset value.</xs:documentation>89 </xs:annotation>90 <xs:restriction base="xs:string">91 <xs:enumeration value="RelativeToGround"/>92 <xs:enumeration value="Absolute"/>93 </xs:restriction>94 </xs:simpleType>95 86 }}} 96 87 97 Descriptions of the key parameters are given below: 98 99 ||ZOffset||An expression that evaluates to the height of the base of the feature in meters|| 100 ||ZExtrusion||An expression that evaluates to the desired vertical extrusion (in meters) to be applied to the feature|| 101 ||ZOffsetType||A string value, either "!RelativeToGround" or "Absolute", that indicates how to interpret the ZOffset value|| 102 103 Additional !ExtendedData elements have been added to allow for future extensions to this part of the schema. 88 The SizeContextType type already exists in the layer definition schema, and is used to specify the size context for symbols and labels. 104 89 105 90 ==== Example === 106 91 107 The following XML snippet is taken from the layer definition used to generate the screenshot above:92 The following XML snippet represents a polyline line style using the new schema: 108 93 {{{ 109 <VectorLayerDefinition>110 ...111 ...112 <VectorScaleRange>113 ...114 ...115 <ExtendedData1>116 <ElevationSettings>117 <ZOffset>0</ZOffset>118 <ZExtrusion>HEIGHT_AGL</ZExtrusion>119 <ZOffsetType>RelativeToGround</ZOffsetType>120 </ElevationSettings>121 </ExtendedData1>122 </VectorScaleRange>123 </VectorLayerDefinition>124 </LayerDefinition>125 94 }}} 126 95 127 96 === MDF Model and Parser Modifications === 128 97 129 The MDF Model would require the addition of two new classes: '''!ElevationSettings''' and '''!VectorScaleRangeExtendedData1''', corresponding to the <!ElevationSettings> and custom <!ExtendedData1> elements respectively. Similarly, the MDF Parser would require two new classes: '''IOElevationSettings''' and '''IOVectorScaleRangeExtendedData1'''.98 The MDF Model uses the '''Stroke''' class to store line style information. This class would require new methods to get and set the size context. These would be identical to the corresponding existing methods in the '''Symbol''' class that serve the same purpose. 130 99 131 The parser classes would be responsible for reading and writing the elevation settings to and from XML. The model classes would be used to store and access those settings. The methods implemented by each class would be very simple get/set or read/write functions.100 The MDF Parser uses the '''IOStroke''' class to read and write the XML stroke definitions. It would be updated to handle reading and writing of the new SizeContext element. 132 101 133 102 === Stylization Modifications === 134 103 135 The Stylization project would be modified to make the necessary elevation settings available to the !KmlRenderer class that generates KML output for the KML Service. This class would be updated to set the Z coordinate of the generated geometries to be equal to (zOffset + zExtrusion). Also, if zExtrusion > 0, we would write out the KML element <extrude>1</extrude> to indicate that the features should be extruded down to the ground. If zOffset > 0, we will stil extrude the features down to the ground level, since Google Earth does not currently provide a means for rendering floating extruded objects.104 The Stylization project would make use of the new accessor method in the MdfModel::Stroke class to determine the required size context, and render any lines with the correct width. The logic to determine line width in pixels based on thickness, units, and size context already exists in the symbol stylization code. 136 105 137 106 == Implications == 138 107 139 This RFC does not describe any modifications to the GUI tools used to create layer definitions. The elevation settings would need to be configured by manual modification of the layer definition XML files.[[BR]]108 This RFC does not describe any modifications to the GUI tools used to create layer definitions. The line style size context settings would need to be configured by manual modification of the layer definition XML files, until these tools are updated. [[BR]] 140 109 There are no changes to the existing public API. 141 110 142 111 == Test Plan == 143 112 144 Unit tests should include KML generation for layers that contain elevation settings113 Unit tests should include stylization of lines using map space widths. 145 114 146 115 == Funding/Resources ==
