| 74 | ////////////////////////////////////////////////////////////////// |
| 75 | /// \brief |
| 76 | /// Constructs a MgGeoJsonWriter object |
| 77 | /// |
| 78 | /// <!-- Syntax in .Net, Java, and PHP --> |
| 79 | /// \htmlinclude DotNetSyntaxTop.html |
| 80 | /// MgGeoJsonWriter(); |
| 81 | /// \htmlinclude SyntaxBottom.html |
| 82 | /// \htmlinclude JavaSyntaxTop.html |
| 83 | /// MgGeoJsonWriter(); |
| 84 | /// \htmlinclude SyntaxBottom.html |
| 85 | /// \htmlinclude PHPSyntaxTop.html |
| 86 | /// MgGeoJsonWriter(); |
| 87 | /// \htmlinclude SyntaxBottom.html |
| 88 | /// |
| 91 | ////////////////////////////////////////////////////////////////// |
| 92 | /// \brief |
| 93 | /// Converts the current feature in the given feature reader to GeoJSON |
| 94 | /// |
| 95 | /// \remarks |
| 96 | /// The id and geometry properties are inferred from the class definition returned by the feature reader |
| 97 | /// |
| 98 | /// <!-- Syntax in .Net, Java, and PHP --> |
| 99 | /// \htmlinclude DotNetSyntaxTop.html |
| 100 | /// string FeatureToGeoJson(MgFeatureReader featureReader, MgTransform transform); |
| 101 | /// \htmlinclude SyntaxBottom.html |
| 102 | /// \htmlinclude JavaSyntaxTop.html |
| 103 | /// String FeatureToGeoJson(MgFeatureReader featureReader, MgTransform transform); |
| 104 | /// \htmlinclude SyntaxBottom.html |
| 105 | /// \htmlinclude PHPSyntaxTop.html |
| 106 | /// string FeatureToGeoJson(MgFeatureReader featureReader, MgTransform transform); |
| 107 | /// \htmlinclude SyntaxBottom.html |
| 108 | /// |
| 109 | /// \param featureReader (MgFeatureReader) |
| 110 | /// The feature reader |
| 111 | /// |
| 112 | /// \param transform (MgTransform) |
| 113 | /// An optional transform |
| 114 | /// |
| 115 | /// \return |
| 116 | /// Returns the GeoJSON output as a string. |
| 117 | /// |
| 120 | ////////////////////////////////////////////////////////////////// |
| 121 | /// \brief |
| 122 | /// Converts the current feature in the given feature reader to GeoJSON |
| 123 | /// |
| 124 | /// <!-- Syntax in .Net, Java, and PHP --> |
| 125 | /// \htmlinclude DotNetSyntaxTop.html |
| 126 | /// string FeatureToGeoJson(MgFeatureReader featureReader, MgTransform transform, string idPropertyName, string geomPropName); |
| 127 | /// \htmlinclude SyntaxBottom.html |
| 128 | /// \htmlinclude JavaSyntaxTop.html |
| 129 | /// String FeatureToGeoJson(MgFeatureReader featureReader, MgTransform transform, String idPropertyName, String geomPropName); |
| 130 | /// \htmlinclude SyntaxBottom.html |
| 131 | /// \htmlinclude PHPSyntaxTop.html |
| 132 | /// string FeatureToGeoJson(MgFeatureReader featureReader, MgTransform transform, string idPropertyName, string geomPropName); |
| 133 | /// \htmlinclude SyntaxBottom.html |
| 134 | /// |
| 135 | /// \param featureReader (MgFeatureReader) |
| 136 | /// The feature reader |
| 137 | /// |
| 138 | /// \param transform (MgTransform) |
| 139 | /// An optional transform |
| 140 | /// |
| 141 | /// \param idPropertyName (String/string) |
| 142 | /// The name of the id property. The value of the property specified will be written to the top-level "id" property of the GeoJSON |
| 143 | /// |
| 144 | /// \param geomPropName (String/string) |
| 145 | /// The name of the geometry property. The value of the property specified will be written to the top-level "geometry" property |
| 146 | /// of the GeoJSON. If this property is not specified, no geometry is written. |
| 147 | /// |
| 148 | /// \return |
| 149 | /// Returns the GeoJSON output as a string. |
| 150 | /// |
