Changes between Version 6 and Version 7 of MapGuideRfc138
09/05/13 21:03:16 (12 years ago)
jng
  • TabularUnified MapGuideRfc138
    v6 v7
    8686These environment variables must be set (manually or by setenvironment.bat/setenvironment64.bat) before any of the aforementioned projects can be built in the Visual Studio IDE. This is already the case with the JavaApi and JavaApiEx projects in the WebTier (which require JAVA_HOME to be set), so this should not be anything new.
    8787
    88 With everything in the MapGuide stack (including FDO) now built under the same compiler, we should also now be able to stop bundling and requiring installation of the Visual C++ 2008 and 2010 runtime libraries as pre-requisite installations for smaller installer size. Further testing will reveal if this is the case.
     88With everything in the MapGuide stack (including FDO) now built under the same compiler, we should also now be able to stop bundling and requiring installation of the Visual C++ 2008 and 2010 runtime libraries as pre-requisite installations for smaller installer size. This will be done once FDO has completed its VS 2012 migration, ensuring everything is on the same compiler.
    8989
    9090== Implications ==
    9494Developers of MapGuide PHP applications that are using custom/external PHP 5.3 extensions (ie. Not included with the MapGuide installer) will need to look for PHP 5.5 supported equivalents.
    9595
    96 PHP developers should be mindful about what has changed in the PHP platform itself since 5.3 and make any changes in their application code. Migration guides for (5.3 to 5.4) and (5.4 to 5.5) are included below for reference:
     96PHP developers should be mindful about what has changed in the PHP platform itself and its extensions since 5.3 and make any changes in their application code. Migration guides for (5.3 to 5.4) and (5.4 to 5.5) are included below for reference:
    9797
    9898 * http://php.net/manual/en/migration54.php
    102102
    103103 * https://httpd.apache.org/docs/2.4/upgrading.html
     104
     105The httpd.conf template that we bundle with the installer has already been updated to ensure there are no incompatible settings or directives.
    104106
    105107== Test Plan ==
