Changes between Version 2 and Version 3 of MapGuideRfc122
- Sep 30, 2011, 4:01:46 AM (13 years ago)
MapGuideRfc122
v2 v3 44 44 3. Check the library status of the catalog. Throw an exception if the library status is not initialized. Note that there is a current defect where the library status is not re-evaluated when SetDictionaryDir() is called. A patch (#1821) has been made for this particular issue. 45 45 46 The installer will be updated to write the proper CS-Map dictionary paths to serverconfig.ini and webconfig.ini. The mandatory reboot requirement for certain versions of windows will be removed. 47 46 48 == Implications == 47 49
