Changes between Version 40 and Version 41 of MapGuideRfc119
08/02/11 19:46:41 (14 years ago)
samwang
  • TabularUnified MapGuideRfc119
    v40 v41
    5050
    5151
    52 Normally, if a feature does not individually override its layer's setting. Then the URL and description of this feature of should be the evaluated value of the FDO expression specified. That is to say, if the ADDRESS property value of this feature is "627 5th Avenue", then the URL of this feature is "map.google.com/location=627 5th Avenue" and respectively description of this feature is "'Feature at location: 627 5th Avenue". Otherwise if user want to use a different URL, he can override this value and store it in URL property and if he wants to use a different URL description, he can store it in DESCRIPTION property.
     52Normally, if a feature does not individually override its layer's setting. Then the URL and description of this feature of should be the evaluated value of the FDO expression specified. That is to say, if the ADDRESS property value of this feature is "627 5th Avenue", then the URL of this feature is "map.google.com/location=627 5th Avenue" and respectively description of this feature is "'Feature at location: 627 5th Avenue". Otherwise if user want to use a different URL, he can override this value and store it in URL property and if he wants to use a different URL description, he can store it in DESCRIPTION property. Both overriden values(specified in "ContentOverride" and "DescriptionOverride") take precedence over layer setting(specified in "Content" and "Description").
    5353
    5454== Proposed Solution ==
