98 | | 4. Add the IPv6 / v4 configuration in serverconfig.ini |
99 | | We need a way to determine we should pass in '''{{{0.0.0.0}}}''' or '''{{{::}}}''' as the '''{{{host_name}}}''' parameter when instantizte the '''{{{ACE_INET_Addr}}}''' objects. Although passing the ip address seems to be the right way to determine the protocol version at runtime, adding a new configuration parameter in '''{{{serverconfig.ini}}}''' is a much simpler and more reliable solution – the machine IP is specified by the '''{{{MachineIp}}}''' parameter, but it can happen that the user doesn’t input any ip address at all in '''{{{serverconfig.ini'''}}}. So adding one more parameter is a better idea. The parameter will be added into '''{{{GeneralProperties}}}''' section following the '''{{{MachineIp}}}''' parameter. |
| 98 | 4. '''Add the IPv6 / v4 configuration in serverconfig.ini''' |
| 99 | We need a way to determine we should pass in '''{{{0.0.0.0}}}''' or '''{{{::}}}''' as the '''{{{host_name}}}''' parameter when instantizte the '''{{{ACE_INET_Addr}}}''' objects. Although passing the ip address seems to be the right way to determine the protocol version at runtime, adding a new configuration parameter in '''{{{serverconfig.ini}}}''' is a much simpler and more reliable solution – the machine IP is specified by the '''{{{MachineIp}}}''' parameter, but it can happen that the user doesn’t input any ip address at all in '''{{{serverconfig.ini}}}'''. So adding one more parameter is a better idea. The parameter will be added into '''{{{GeneralProperties}}}''' section following the '''{{{MachineIp}}}''' parameter. |
