Changes between Version 9 and Version 10 of MapGuideRfc110
04/21/11 23:20:34 (14 years ago)
liuar
  • TabularUnified MapGuideRfc110
    v9 v10
    198198
    199199Solution 1.
    200 Copy the implementation of profiling related APIs to !MgServerProfilingService and add profiling code into the copied version, for example, copy the implementation of !RenderMap in !MgServerRenderingService(and all other MG server APIs invoked in !RenderMap) to !MgServerProfilingService. The advantage and disadvantage of this implementation is obvious: less influence on the origial implementation but heavy maintainence to do in the future.
     200Copy the implementation of profiling related APIs to !MgServerProfilingService and add profiling code into the copied version, for example, copy the implementation of !RenderMap in !MgServerRenderingService(and all other MG server APIs invoked in !RenderMap) to !MgServerProfilingService. The advantage and disadvantage of this implementation is obvious: less influence on the original implementation but heavy maintenance to do in the future.
    201201
    202202Solution 2.
    203203Inject the profiling code into the functions being profiled, which means !MgServerServices should be extended to accept a !ProfileResult and the implementation of some APIs will updated to support profiling. For example, to support profiling !RenderMap, all the !MgServerServices in the !RenderMap workflow will be affected - !MgServerRenderingService, !MgServerResourceService, !MgServerFeatureService, !MgServerDescribeSchema, !MgServerSelectFeatures, etc.
    204204
    205 For both solustions, how many code should be copied or updated will be decided by how detailed information would be gathered.
     205For both solutions, how many code should be copied or updated will be decided by how detailed information would be gathered.
    206206
    207207== Test Plan ==
