Changes between Version 13 and Version 14 of MapGuideArchitecture
11/26/08 12:33:24 (16 years ago)
tomfukushima
Put ! in front of bogus hyperlink so that it is not live
  • TabularUnified MapGuideArchitecture
    v13 v14
    6363
    6464==== SITE ADMINISTRATOR ====
    65 The !MapGuide Site Administrator is an application for managing your site and its servers. This application uses a web-based interface that you can access from any web browser. To start the program, open a browser and enter: http://servername:port/mapguide/mapadmin/login.php, using the name of the site server and port that you specified during installation. You use the !MapGuide Site Administrator to add and remove servers, take servers offline for maintenance, modify the configuration of a server, assign services to the servers, and monitor the status of any server. The !MapGuide Site Administrator is not a separate product component, but it is installed as a part of the !MapGuide Web Server Extensions.
     65The !MapGuide Site Administrator is an application for managing your site and its servers. This application uses a web-based interface that you can access from any web browser. To start the program, open a browser and enter: !http://servername:port/mapguide/mapadmin/login.php, using the name of the site server and port that you specified during installation. You use the !MapGuide Site Administrator to add and remove servers, take servers offline for maintenance, modify the configuration of a server, assign services to the servers, and monitor the status of any server. The !MapGuide Site Administrator is not a separate product component, but it is installed as a part of the !MapGuide Web Server Extensions.
    6666
    6767=== Web Tier View ===
