Changes between Version 4 and Version 5 of InstallSideBySide1.2and2.0IIS
- Jan 8, 2008, 5:55:31 AM (17 years ago)
v4 v5 23 23 }}} 24 24 == Install !MapGuide Web Extensions 2.0 == 25 We need to use the bundled Apache install because MGOS 2.0 uses the same IIS virtual directory as MGOS 1.2 and so two IIS installs will not work. If you know how to change the virtual directory in IIS, then side-by-side IIS installs should also work if you take some of the appropriate steps below.25 We need to use the bundled Apache install because MGOS 2.0 uses the same IIS virtual directory as MGOS 1.2 and so two IIS installs will not work. 26 26 27 27 The MGOS 2.0 installer currently sets some registry keys incorrectly. Before proceeding, export the HKEY_LOCAL_MACHINE\SOFTWARE\FASTCGI key using the registry editor.
