Changes between Version 30 and Version 31 of HttpApi/RenderingService
- Apr 28, 2010, 2:29:39 PM (14 years ago)
v30 v31 345 345 == !QueryMapFeatures == 346 346 === Overview === 347 !QueryMapFeatures operation identifies features that meet the specified spatial selection criteria. These features can be persisted as selected features in a map. !QueryMapFeatures returns an XML document describing the set of selected features. If a single feature is selected, the XML contains the tooltip, hyperlink, and properties of the feature. 348 {{{ 349 <?xml version="1.0" encoding="UTF-8"?> 350 <FeatureInformation> 351 <FeatureSet> 352 <Layer> 353 <id></id> 354 <Class> 355 <id></id> 356 <ID></ID> 357 </Class> 358 </Layer> 359 </FeatureSet> 360 <Tooltip>Some tooltip text</Tooltip> 361 <Hyperlink>http://www.website.com</Hyperlink> 362 <Property name="Owner" value="John Doe"/> 363 <Property name="MarketAssessment" value="700000"/> 364 </FeatureInformation> 365 }}} 366 347 367 === Parameters === 348 368 || '''Name''' || '''Value''' || '''Required''' || '''Description''' || … … 378 398 * 4 - Layer has a tooltip defined 379 399 380 Combinations of one or more attributes 400 Combinations of one or more attributes are allowed. 381 401 382 402 ==== FEATUREFILTER Parameter ==== #FeatureFilter1.0 383 XML filter describing a set of previously selected features. This paramter is useful for obtaining the attribute values for a set of selected features. The XML text can be retrieved from !MgSelection.!ToXml().384 385 === Usage === 386 === Technical Notes === 403 XML filter describing a set of previously selected features. This paramter is useful for obtaining the attribute values of a previously selected feature. The XML text can be retrieved from !MgSelection.!ToXml(). 404 405 === Usage === 406 === Technical Notes ===
