Changes between Version 5 and Version 6 of ConfigureGuide24Windows
02/04/13 00:46:41 (12 years ago)
davidwilhelmsson
  • ConfigureGuide24Windows
    v5 v6
    99For Windows 7:
    1010
    11  1. Open Start -> Control Panel -> Programs and Features -> Turn Windows features on or off
    12  1. Install Internet Information Services, which also selects several default components
    13  1. Install Internet Information Services -> World Wide Web Services -> Application Development Features -> .NET Extensibility
    14  1. Install Internet Information Services -> World Wide Web Services -> Application Development Features -> ASP.NET, which also selects ISAPI Extensions and ISAPI Filters
    15  1. Install Internet Information Services -> World Wide Web Services -> Application Development Features -> CGI
     11 1. Open Start -> Control Panel -> Programs -> Programs and Features -> Turn Windows features on or off
     12 1. Install:
     13 * Internet Information Services, which also selects several default components
     14 * Internet Information Services -> World Wide Web Services -> Application Development Features -> .NET Extensibility
     15 * Internet Information Services -> World Wide Web Services -> Application Development Features -> ASP.NET, which also selects ISAPI Extensions and ISAPI Filters
     16 * Internet Information Services -> World Wide Web Services -> Application Development Features -> CGI
    1617
    1718[[Image(screenshot.1.jpg)]]
    2526=== Install MapGuide ===
    2627
    27 For Windows 7/Windows Server 2008 R2 and below, use the installer and select the IIS configuration to automatically configure IIS.
     28For Windows 7/Windows Server 2008 R2 and below, use the installer and select IIS configuration to automatically configure IIS.
    2829
    2930For Windows 8/Windows Server 2012, use the installer and select manual configuration. IIS will need to be manually configured.
    3031
    31  * [http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-on-Azure-Windows-Server-2012-NET-4-5-td5007390.html MapGuide 2.4 on Azure Windows Server 2012 .NET 4.5]
     32=== Manual configuration: IIS ===
     34If MapGuide has been installed with a manual configuration, IIS will need to be manually configured.
     35
     36 1. For Windows 7, open Start -> Control Panel -> System and Security -> Administrative Tools -> Internet Information Services (IIS) Manager
     37 1. Open [root]\Application Pools -> Actions -> Add Application Pool...
     38 * Name: MapGuide24AppPool
     39 * .NET Framework version: .NET Framework v4.0.30319
     40 * Managed pipeline mode: Integrated
     41 * Start application pool immediately: True
     42
     43=== Links ===
     44
     45 * [http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-on-Azure-Windows-Server-2012-NET-4-5-td5007390.html MapGuide 2.4 on Azure Windows  Server 2012 .NET 4.5]
    3246
    3347== Previous releases ==
