Changes between Version 15 and Version 16 of ConfigureGuide22Windows
- Aug 4, 2010, 10:01:33 PM (14 years ago)
v15 v16 5 5 Under windows, you have the options to deploy mapguide web application to either Apache, or Tomcat, or IIS 6 6 7 Basic knowledge of 32bit vs 64bit machine: 32bit applications work s on 64bit machine, not vice versa. 32bit application does not get along with 64bit application if they have to work together. So when downloading Apache or other applications, bear in mind they have to be compatible with either hardware or software. Confused? then ignore what I say :)7 Basic knowledge of 32bit vs 64bit machine: 32bit applications work on 64bit machine, not the other way. 32bit application does not get along with 64bit application if they have to work together. So when downloading Apache or other applications, bear in mind they have to be compatible with either hardware or software. Confused? then ignore what I say :) 8 8 9 9 == Apache2 ==
