Changes between Initial Version and Version 1 of CompilingMapGuideVCExpress
Aug 12, 2010, 1:24:10 AM (14 years ago)
jng
  • CompilingMapGuideVCExpress
     1= Building MapGuide trunk with Visual C++ Express Edition =
     3== Environment Setup ==
     5 * [http://www.microsoft.com/express/Downloads/Download-2008.aspx Microsoft Visual C++ 2008 Express Edition]
     6 * [http://www.microsoft.com/downloads/details.aspx?FamilyID=e6e1c3df-a74f-4207-8586-711ebe331cdc&displaylang=en Windows SDK for Windows Server 2008 and .NET Framework 3.5]
     8The Windows SDK provides us with the x64 native/cross compilers if you want to build MapGuide in 64-bit.
     10== Setting up x64 compilers ==
     12If you don't intend to build 64-bit MapGuide you can skip this section.
     13
     14== Build Oem ==
     15
     16=== Manual ===
     17
     18Open Oem.sln in Visual C++ Express and build the solution using your configuration of choice. You will get an error about a particular project not loading (SQLiteGUI). This is because VS express doesn't support solutions with mixed project types. Fortunately, this project is not required and the error can be safely ignored.
     19
     20=== Automated ===
     21
     22...
     23
     24== A note about building CS-Map in 64-bit ==
     25
     26When building the OpenSource.sln in a 32-bit system using the 64-bit cross compiler, you will get a post-build error. This is because the Compiler project has a post-build step that runs the compiled executable to compile the Coordinate System dictionaries. The compiled executable being a 64-bit binary, will not run on a 32-bit system.
     27
     28To workaround this, build the OpenSource.sln (Compiler and Library) in 32-bit first, this will trigger the post-build event and compile your CS dictionaries. Then only build the Library project in 64-bit.
     29
     30== Build Server ==
     31
     32=== Manual ===
     34Open Server.sln in Visual C++ Express and build the solution using your configuration of choice.
     35
     36=== Automated ===
     37
     38...
     39
     40== Build WebTier ==
     41
     42=== Manual ===
     43
     44Open WebTier.sln in Visual C++ Express and build the solution using your configuration of choice.
     45
     46=== Automated ===
     47
     48...
