Changes between Initial Version and Version 1 of CompilingMapGuide22Ubuntu910
02/03/10 12:11:20 (15 years ago)
trevorwekel
  • TabularUnified CompilingMapGuide22Ubuntu910
     1= Ubuntu 9.1 Compilation Guide =
     3'''Note:  The compilation steps for Ubuntu 9.1 are incomplete.  More work is required.'''
     5Ubuntu 9.1 uses GCC 4.4 as its native compiler.  !MapGuide 2.2 does not compile cleanly against GCC 4.4.  Further work will be required to support native GCC 4.4 compilation.
     7Compilation is more successful if Ubuntu 9.1 is set up to use GCC 4.1 by grabbing additional packages
     8{{{
     9apt-get install gcc-4.1 g++-4.1 autoconf automake automake1.7 libtool bison
     10apt-get install zliblg zlib1g-dev zlibc libjpeg62-dev libxml2-dev
     11}}}
     12and exporting CC, CPP, and CXX as follows:
     13{{{
     14export CC=gcc-4.1
     15export CPP='gcc-4.1 -E'
     16export CXX=g++-4.1
     17}}}
     18
     19However, there is at least one Oem build script which hardcodes CC, CPP, and CXX.  Additional work is required.
