Changes between Version 4 and Version 5 of WikiDeletePage
05/08/22 15:11:46 (3 years ago)
  • TabularUnified WikiDeletePage
    v4 v5
    77Deleting specific versions or even complete pages can make sense to remove spam or other abusive submissions.
    88
    9 However, if you want to delete a page because you re-created a new page with the same content but a different name, it is recommended to keep the page and use it as a redirection page instead of completely deleting it. This will avoid frustrating the visitor with broken links, particularly when coming to the site from a search engine.
     9However, if you want to delete a page because you re-created a new page with the same content but a different name, it is recommended to keep the page and use it as a redirection page instead of completely deleting it. This will avoid frustrating the visitor with broken links, particularly when coming to the site from a search engine.
    1010
    11 In this situation, chances are that you actually wanted to [[WikiNewPage#renaming|rename]] the page instead of doing a copy and delete.
     11In this situation, chances are that you actually wanted to [[WikiNewPage#renaming|rename]] the page instead of doing a copy and delete.
    1212The //Rename// operation offers you the possibility to create a redirection page.
    13 A redirection page is a short page that  contains a link such as  “See !SomeOtherPage”.
     13A redirection page is a short page that  contains a link such as  “See !SomeOtherPage”.
    1414
    1515----
