Changes between Version 1 and Version 2 of TracInterfaceCustomization
06/10/10 13:36:26 (15 years ago)
  • TabularUnified TracInterfaceCustomization
    v1 v2
    4040}}}
    4141
    42 == Site Header & Footer ==
    43
    44 In the environment folder for each Trac project there should be a directory called {{{templates}}}.  This folder contains files {{{site_header.cs}}} and {{{site_footer.cs}}}.  Users can customize their Trac site by adding the required HTML markup to these files.  The content of these two files will be placed immediately following the opening {{{<body>}}} tag and immediately preceding the closing {{{</body>}}} tag of each page in the site, respectively.
    45
    46 These files may contain static HTML, though if users desire to have dynamically generated content they can make use of the [http://www.clearsilver.net/ ClearSilver] templating language from within the pages as well. When you need to see what variables are available to the template, append the query string `?hdfdump=1` to the URL of your Trac site. This will display a structured view of the template data.
    47
    48 == Site CSS ==
    49 The primary means to adjust the layout of a Trac site is to add [http://www.w3.org/TR/REC-CSS2/ CSS] style rules that overlay the default rules. This is best done by editing the `site_css.cs` file in the enviroment's `templates` directory. The content of that template gets inserted into a `<style type="text/css"></style>` element on every HTML page generated by Trac.
    50
    51 While you can add your custom style rules directly to the `site_css.cs` file, it is recommended that you simply reference an external style sheet, thereby enabling browsers to cache the CSS file instead of transmitting the rules with every response.
    52
    53 The following example would import a style sheet located in the `style` root directory of your host:
    54 {{{
    55 @import url(/style/mytrac.css);
    56 }}}
    57
    58 You can use a !ClearSilver variable to reference a style sheet stored in the project environment's `htdocs` directory:
    59 {{{
    60 @import url(<?cs var:chrome.href ?>/site/style.css);
    61 }}}
    62
    63 == Project List ==
    64 You can use a custom ClearSilver template to display the list of projects if you are using Trac with multiple projects.
     42== Custom Navigation Entries ==
     43The new [mainnav] and [metanav] can now be used to customize the text and link used for the navigation items, or even to disable them (but not for adding new ones).
     44
     45In the following example, we rename the link to the Wiki start "Home", and hide the "Help/Guide". We also make the "View Tickets" entry link to a specific report .
     46{{{
     47[mainnav]
     48wiki.label = Home
     49tickets.href = /report/24
     50
     51[metanav]
     52help = disabled
     53}}}
     54
     55See also TracNavigation for a more detailed explanation of the mainnav and metanav terms.
     56
     57== Site Appearance == #SiteAppearance
     58
     59Trac is using [http://genshi.edgewall.org Genshi] as the templating engine. Documentation is yet to be written, in the meantime the following tip should work.
     60
     61Say you want to add a link to a custom stylesheet, and then your own
     62header and footer. Save the following content as 'site.html' inside your projects templates directory (each Trac project can have their own site.html), e.g. {{{/path/to/env/templates/site.html}}}:
     63
     64{{{
     65#!xml
     66<html xmlns="http://www.w3.org/1999/xhtml"
     67      xmlns:py="http://genshi.edgewall.org/"
     68      py:strip="">
     69
     70  <!--! Add site-specific style sheet -->
     71  <head py:match="head" py:attrs="select('@*')">
     72    ${select('*|comment()|text()')}
     73    <link rel="stylesheet" type="text/css"
     74          href="${href.chrome('site/style.css')}" />
     75  </head>
     76
     77  <body py:match="body" py:attrs="select('@*')">
     78    <!--! Add site-specific header -->
     79    <div id="siteheader">
     80      <!--! Place your header content here... -->
     81    </div>
     82
     83    ${select('*|text()')}
     84
     85    <!--! Add site-specific footer -->
     86    <div id="sitefooter">
     87      <!--! Place your footer content here... -->
     88    </div>
     89  </body>
     90</html>
     91}}}
     92
     93Those who are familiar with XSLT may notice that Genshi templates bear some similarities. However, there are some Trac specific features - for example '''${href.chrome('site/style.css')}''' attribute references template placed into environment's ''htdocs/''  In a similar fashion '''${chrome.htdocs_location}''' is used to specify common ''htdocs/'' directory from Trac installation.
     94
     95site.html is one file to contain all your modifications. It usually works by the py:match (element of attribute), and it allows you to modify the page as it renders - the matches hook onto specific sections depending on what it tries to find
     96and modify them. A site.html can contain any number of such py:match sections for whatever you need to modify. This is all [http://genshi.edgewall.org/ Genshi], so the docs on the exact syntax can be found there.
     97
     98
     99Example snippet of adding introduction text to the new ticket form (hide when preview):
     100
     101{{{
     102#!xml
     103<form py:match="div[@id='content' and @class='ticket']/form" py:attrs="select('@*')">
     104  <py:if test="req.environ['PATH_INFO'] == '/newticket' and (not 'preview' in req.args)">
     105    <p>Please make sure to search for existing tickets before reporting a new one!</p>
     106  </py:if>
     107  ${select('*')}
     108</form>
     109}}}
     110
     111This example illustrates a technique of using '''`req.environ['PATH_INFO']`''' to limit scope of changes to one view only. For instance, to make changes in site.html only for timeline and avoid modifying other sections - use  ''`req.environ['PATH_INFO'] == '/timeline'`'' condition in <py:if> test.
     112
     113If the environment is upgraded from 0.10 and a `site_newticket.cs` file already exists, it can actually be loaded by using a workaround - providing it contains no ClearSilver processing. In addition, as only one element can be imported, the content needs some sort of wrapper such as a `<div>` block or other similar parent container. The XInclude namespace must be specified to allow includes, but that can be moved to document root along with the others:
     114{{{
     115#!xml
     116<form py:match="div[@id='content' and @class='ticket']/form" py:attrs="select('@*')"
     117        xmlns:xi="http://www.w3.org/2001/XInclude">
     118  <py:if test="req.environ['PATH_INFO'] == '/newticket' and (not 'preview' in req.args)">
     119    <xi:include href="site_newticket.cs"><xi:fallback /></xi:include>
     120  </py:if>
     121  ${select('*')}
     122</form>
     123}}}
     124
     125Also note that the `site.html` (despite its name) can be put in a common templates directory - see the `[inherit] templates_dir` option. This could provide easier maintainence (and a migration path from 0.10 for larger installations) as one new global `site.html` file can be made to include any existing header, footer and newticket snippets.
     126
     127== Project List == #ProjectList
     128
     129You can use a custom Genshi template to display the list of projects if you are using Trac with multiple projects.
    65130
    66131The following is the basic template used by Trac to display a list of links to the projects.  For projects that could not be loaded it displays an error message. You can use this as a starting point for your own index template.
    68133{{{
    69134#!text/html
    70 <html>
    71 <head><title>Available Projects</title></head>
    72 <body>
    73  <h1>Available Projects</h1>
    74  <ul><?cs
    75  each:project = projects ?><li><?cs
    76   if:project.href ?>
    77    <a href="<?cs var:project.href ?>" title="<?cs var:project.description ?>">
    78     <?cs var:project.name ?></a><?cs
    79   else ?>
    80    <small><?cs var:project.name ?>: <em>Error</em> <br />
    81    (<?cs var:project.description ?>)</small><?cs
    82   /if ?>
    83   </li><?cs
    84  /each ?>
    85  </ul>
    86 </body>
     135<!DOCTYPE html
     136    PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
     137    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
     138<html xmlns="http://www.w3.org/1999/xhtml"
     139      xmlns:py="http://genshi.edgewall.org/"
     140      xmlns:xi="http://www.w3.org/2001/XInclude">
     141  <head>
     142    <title>Available Projects</title>
     143  </head>
     144  <body>
     145    <h1>Available Projects</h1>
     146    <ul>
     147      <li py:for="project in projects" py:choose="">
     148        <a py:when="project.href" href="$project.href"
     149           title="$project.description">$project.name</a>
     150        <py:otherwise>
     151          <small>$project.name: <em>Error</em> <br /> ($project.description)</small>
     152        </py:otherwise>
     153      </li>
     154    </ul>
     155  </body>
    87156</html>
    88157}}}
    89158
    90 Once you've created your custom template you will need to configure the webserver to tell Trac where the template is located:
     159Once you've created your custom template you will need to configure the webserver to tell Trac where the template is located (pls verify ... not yet changed to 0.11):
    91160
    92161For [wiki:TracFastCgi FastCGI]:
    98167For [wiki:TracModPython mod_python]:
    99168{{{
     169PythonOption TracEnvParentDir /parent/dir/of/projects
    100170PythonOption TracEnvIndexTemplate /path/to/template
    101171}}}
    106176}}}
    107177
    108
    109 == Main Templates ==
    110
    111 It is also possible to use your own modified versions of the Trac [http://www.clearsilver.net/ ClearSilver] templates. Note though that this technique is not recommended because it makes upgrading Trac rather problematic: there are unfortunately several dependencies between the templates and the application code, such as the name of form fields and the structure of the template data, and these are likely to change between different versions of Trac.
    112
    113 If you absolutely need to use modified templates, copy the template files from the default templates directory (usually in found in `$prefix/share/trac/templates`) into the `templates` directory of the project environment. Then modify those copies to get the desired results.
    114
     178For [wiki:TracStandalone], you'll need to set up the `TRAC_ENV_INDEX_TEMPLATE` environment variable in the shell used to launch tracd:
     179 - Unix
     180   {{{
     181#!sh
     182$ export TRAC_ENV_INDEX_TEMPLATE=/path/to/template
     183   }}}
     184 - Windows
     185   {{{
     186#!sh
     187$ set TRAC_ENV_INDEX_TEMPLATE=/path/to/template
     188   }}}
     189
     190== Project Templates ==
     191
     192The appearance of each individual Trac environment (that is, instance of a project) can be customized independently of other projects, even those hosted by the same server. The recommended way is to use a `site.html` template (see [#SiteAppearance]) whenever possible. Using `site.html` means changes are made to the original templates as they are rendered, and you should not normally need to redo modifications whenever Trac is upgraded. If you do make a copy of `theme.html` or any other Trac template, you need to migrate your modifiations to the newer version - if not, new Trac features or bug fixes may not work as expected.
     193
     194With that word of caution, any Trac template may be copied and customized. The default Trac templates are located inside the installed Trac egg (`/usr/lib/pythonVERSION/site-packages/Trac-VERSION.egg/trac/templates, .../trac/ticket/templates, .../trac/wiki/templates, ++`). The [#ProjectList] template file is called `index.html`, while the template responsible for main layout is called `theme.html`. Page assets such as images and CSS style sheets are located in the egg's `trac/htdocs` directory.
     195
     196However, do not edit templates or site resources inside the Trac egg - installing Trac again can completely delete your modifications. Instead use one of two alternatives:
     197 * For a modification to one project only, copy the template to project `templates` directory.
     198 * For a modification shared by several projects, copy the template to a shared location and have each project point to this location using the `[inherit] templates_dir =` trac.ini option.
     199
     200Trac resolves requests for a template by first looking inside the project, then in any inherited templates location, and finally inside the Trac egg.
     201
     202Trac caches templates in memory by default to improve performance. To apply a template you need to restart the server.
    115203----
    116204See also TracGuide, TracIni
