Changes between Version 4 and Version 5 of InterWiki
- 05/08/22 15:11:46 (3 years ago)
TabularUnified InterWiki
v4 v5 1 1 = Support for InterWiki links 2 [[PageOutline(2-5,Contents,pullout)]] 2 3 3 4 == Definition … … 5 6 An InterWiki link can be used for referring to a Wiki page located in another Wiki system, and by extension, to any object located in any other Web application, provided a simple URL mapping can be done. 6 7 7 InterWiki prefixes can even be used to simplyintroduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].8 InterWiki prefixes can even be used to introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn]. 8 9 9 10 == Link Syntax … … 16 17 Note that, as for InterTrac prefixes, '''InterWiki prefixes are case insensitive'''. 17 18 18 The target Wiki URL is looked up in the `[interwiki]` section of TracIni orin the InterMapTxt wiki page, modeled after MeatBall:InterMapTxt. If a prefix is defined in both the `[interwiki]` section and InterMapTxt, the `[interwiki]` section takes precedence.19 The target Wiki URL is looked up in the [TracIni#interwiki-section "[interwiki]"] section of TracIni and in the InterMapTxt wiki page, modeled after MeatBall:InterMapTxt. If a prefix is defined in both the `[interwiki]` section and InterMapTxt, the `[interwiki]` section takes precedence. 19 20 20 In addition to traditional InterWiki links, where the target is simply ''appended'' to the URL, Trac supports parametricInterWiki URLs:21 In addition to traditional !InterWiki links, where the target is simply ''appended'' to the URL, Trac supports parametric !InterWiki URLs: 21 22 identifiers `$1`, `$2`, ... in the URL will be replaced by corresponding arguments. 22 23 The argument list is formed by splitting the page identifier using the ":" separator. 23 24 24 == = [interwiki]25 == [TracIni#interwiki-section "[interwiki]"] 25 26 26 27 Every option in the `[interwiki]` section in TracIni defines one InterWiki prefix. The option name defines the prefix. The option value defines the URL, optionally followed by a description separated from the URL by whitespace. Parametric URLs are supported as well. … … 36 37 == Examples 37 38 38 If the following is anexcerpt of the InterMapTxt page:39 For the following excerpt of the InterMapTxt page: 39 40 40 41 {{{ … … 48 49 ---- 49 50 {{{ 50 PEP http://www.python.org/peps/pep-$1.html # Python Enhancement Proposal $1 51 PEP http://www.python.org/peps/pep-$1.html # Python Enhancement Proposal $1 51 52 Trac-ML http://thread.gmane.org/gmane.comp.version-control.subversion.trac.general/$1 # Message $1 in Trac Mailing List 52 53 … … 61 62 }}} 62 63 63 Then, 64 * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap and the ''title'' for that link would be "!InterWikiMap in !MoinMoin". 65 * `Trac-ML:4346` should be rendered as Trac-ML:4346 and the ''title'' for that link would be "Message 4346 in Trac Mailing List". 64 Then, 65 * `MoinMoin:InterWikiMap` will be rendered as MoinMoin:InterWikiMap and the ''title'' for that link will be "!InterWikiMap in !MoinMoin". 66 * `Trac-ML:4346` will be rendered as Trac-ML:4346 and the ''title'' for that link will be "Message 4346 in Trac Mailing List". 67 68 == List of Active Prefixes 69 70 [[InterWiki]] 66 71 67 72 ----
