Changes between Version 5 and Version 6 of TracUpgrade
- 09/05/24 07:03:42 (8 months ago)
TabularUnified TracUpgrade
v5 v6 84 84 85 85 === 7. Steps specific to a given Trac version #VersionSpecificSteps 86 87 ==== Upgrading from Trac 1.4 to 1.5 #to1.5 88 89 ===== Python 2.7 no longer supported 90 91 Upgrade Python to 3.5 or later. 86 92 87 93 ==== Upgrading from Trac 1.2 to 1.4 #to1.4 … … 235 241 Prior to 1.0, the owner field of new tickets always defaulted to `[ticket] default_owner` when the value was not empty. If the value was empty, the owner field defaulted to to the Component's owner. In 1.0 and later, the `default_owner` must be set to `< default >` to make new tickets default to the Component's owner. This change allows the `default_owner` to be set to an empty value if no default owner is desired. 236 242 243 ===== Behavior of `* -> *` workflow transition 244 245 The workflow transition `* -> *` must have the operation 246 `leave_status`. Due to a defect in Trac < 1.0.18 247 `leave_status` was not required, so it may be necessary 248 to add the operation when upgrading. The action will not 249 display for a `* -> *` transition if the action does 250 not have the `leave_status` operation. 251 237 252 ==== Upgrading from older versions of Trac #OlderVersions 238 253
