Changes between Version 4 and Version 5 of TracModWSGI
- 09/05/24 07:03:41 (8 months ago)
TabularUnified TracModWSGI
v4 v5 260 260 }}} 261 261 262 Note 1: This is the case where the LDAP search will get around the multiple OUs, con ecting to the Global Catalog Server portion of AD. Note the port is 3268, not the normal LDAP 389. The GCS is basically a "flattened" tree which allows searching for a user without knowing to which OU they belong.262 Note 1: This is the case where the LDAP search will get around the multiple OUs, connecting to the Global Catalog Server portion of AD. Note the port is 3268, not the normal LDAP 389. The GCS is basically a "flattened" tree which allows searching for a user without knowing to which OU they belong. 263 263 264 264 Note 2: You can also require the user be a member of a certain LDAP group, instead of just having a valid login:
