Changes between Initial Version and Version 1 of TracIni
Mar 15, 2007, 11:14:53 AM (17 years ago)
  • TracIni
     1= The Trac Configuration File =
     2[[TracGuideToc]]
     4Trac configuration is done by editing the '''`trac.ini`''' config file, located in `<projectenv>/conf/trac.ini`.
     6== Global Configuration ==
     8Since version 0.9, Trac can also read the configuration from a global `trac.ini` file. These global options will then be merged with the environment-specific options, where local options override global options.
     10The global configuration is by default localted in `$prefix/share/trac/conf/trac.ini`. It can be moved to a different location (for example, `/etc/trac.ini`), but that requires changing the file `trac/siteconfig.py` which gets created when Trac is installed.
     12== Reference ==
     13
     14This is a brief reference of available configuration options.
     15
     16[[TracIni]]
     17
     18== [components] ==
     19(''since 0.9'')
     20
     21This section is used to enable or disable components provided by plugins, as well as by Trac itself. The component to enable/disable is specified via the name of the option. Whether its enabled is determined by the option value; setting the value to `enabled` or `on` will enable the component, any other value (typically `disabled` or `off`) will disable the component.
     23The option name is either the fully qualified name of the components or the module/package prefix of the component. The former enables/disables a specific component, while the latter enables/disables any component in the specified package/module.
     25Consider the following configuration snippet:
     26{{{
     27[components]
     28trac.ticket.report.ReportModule = disabled
     29webadmin.* = enabled
     30}}}
     31
     32The first option tells Trac to disable the [wiki:TracReports report module]. The second option instructs Trac to enable all components in the `webadmin` package. Note that the trailing wildcard is required for module/package matching.
     34See the ''Plugins'' page on ''About Trac'' to get the list of active components (requires `CONFIG_VIEW` [wiki:TracPermissions permissions].)
     35
     36See also: TracPlugins
     37
     38  ''Note that prior to Trac r2335 (that applies to 0.9b1 and 0.9b2), you would use a `[disabled_components]` section instead. See a [http://projects.edgewall.com/trac/wiki/TracIni?version=42 previous version] of this page for the details.''
     39
     40----
     41See also: TracGuide, TracAdmin, TracEnvironment
     42
