Changes between Version 29 and Version 30 of wxGUIDevelopment/SingleWindow
- May 20, 2022, 8:23:07 AM (2 years ago)
v29 v30 27 27 After significant improvements of the Data Catalog [https://trac.osgeo.org/grass/wiki/GSoC/2020/StartupWindow], which led to the creation of a new startup mechanism and the removal of the startup screen, another topic enhancing the user experience comes into consideration - a Single-Window User Interface. 28 28 All historical versions of GRASS GIS are spread across multiple screens. It can be beneficial for some, but it can be a bit annoying as well - e.g. tabs in Layer Manager can cause trouble to new users. The new design would therefore assume that all panels would be visible immediately after startup. 29 The fact that a Single Window layout would really be appreciated by users can also be deduced from the surveys conducted in my master thesis [https://github.com/ctu-geoforall- 29 The fact that a Single Window layout would really be appreciated by users can also be deduced from the surveys conducted in my master thesis [https://github.com/ctu-geoforall-lab-projects/dp-kladivova-2021/blob/master/text/linda-kladivova-dp-2021.pdf]. 30 30 Of course, especially long-term users can prefer the existing multi-window layout, so the original option will be retained. The Single-Window GUI will be built "next to" the existing Multi-Window GUI. As an example, the GIMP software works similarly. It is also left to the user the option to switch to multi-layout, but by default, it starts in a single layout. 31 31
