Changes between Version 46 and Version 47 of wxGUIDevelopment/RedesigningStatusbar
- Mar 3, 2022, 1:26:44 AM (2 years ago)
v46 v47 266 266 Especially for Single-Window GUI, the Map Display status bar needs to be lightened up a bit since in the case of opening more Map Display notebook pages the check box on the right side of the status bar gets shrunk. The solution is to remove the combo box in the status bar occupying too much space and implement a new Map Display settings dialog accessible from the top map display toolbar. 267 267 268 **The state of the art BEFORE the start of Mini -project:**\\268 **The state of the art BEFORE the start of Mini project:**\\ 269 269 At this moment, the status bar at the bottom of the Map Display window consists of the text/widget section, the combo box, the mask and the check box. For the Single-Window GUI, the number of widgets must be reduced so that the check box on the right side of the status bar is not shrunk. 270 270 271 **The state of the art AFTER Mini -project:**\\271 **The state of the art AFTER Mini project:**\\ 272 272 The new Map Display settings dialog is introduced. The main task of this dialog is to manage General Map Display settings and status bar settings. It implies that the status bar combobox is not needed anymore because we can find all Map Display settings including status bar customization in the new dialog. 273 273
