Changes between Version 45 and Version 46 of wxGUIDevelopment/RedesigningStatusbar
- Mar 2, 2022, 10:12:53 AM (2 years ago)
v45 v46 264 264 265 265 **Abstract:**\\ 266 Especially for Single-Window GUI the Map Display statusbar needs to be lightened up a bit since in case of opening more Map Display notebook pages the check box on the right side of the statusbar is shrunk. The solution is to cancel the combo box in the statusbar occupying too much space and implement a new Map Display settings dialog accessible from the top map display toolbar.266 Especially for Single-Window GUI, the Map Display status bar needs to be lightened up a bit since in the case of opening more Map Display notebook pages the check box on the right side of the status bar gets shrunk. The solution is to remove the combo box in the status bar occupying too much space and implement a new Map Display settings dialog accessible from the top map display toolbar. 267 267 268 268 **The state of the art BEFORE the start of Mini-project:**\\ 269 At th e moment, the status bar at the bottom of the map display window consists of a text section, a combo box, a mask and a check box. For the Single-Window GUI, the number of widgets must be reduced so that the check box on the right side of the status bar is not shrunk.269 At this moment, the status bar at the bottom of the Map Display window consists of the text/widget section, the combo box, the mask and the check box. For the Single-Window GUI, the number of widgets must be reduced so that the check box on the right side of the status bar is not shrunk. 270 270 271 271 **The state of the art AFTER Mini-project:**\\ 272 The new Map Display settings is introduced. The main task od this dialog is to manage General Map Display settings and statusbar settings. It implies that the statusbar combobox is not needed anymore. We can find all Map Display settings including statusbar customization in the new dialog.272 The new Map Display settings dialog is introduced. The main task of this dialog is to manage General Map Display settings and status bar settings. It implies that the status bar combobox is not needed anymore because we can find all Map Display settings including status bar customization in the new dialog. 273 273 274 274 **Next Steps:**\\ … … 313 313 https://twitter.com/GRASSGIS/status/1494289478999019523?s=20&t=IxQDRvpI0Cb82I4DfCEiBA 314 314 315 == Brand new Screenshots of Map Display Settings dialog and statusbar after changes==315 == Brand new Screenshots of Map Display Settings dialog == 316 316 [[Image(general_settings.png, 1200px, title=Figure 2: General page of Map Display Settings dialog, align=left)]] 317 317 [[Image(radiobox.png, 1200px, title=Figure 3: Radiobox in Map Display settings for statusbar customization, align=center)]]
