Changes between Version 43 and Version 44 of wxGUIDevelopment/RedesigningStatusbar
- Mar 2, 2022, 9:47:20 AM (2 years ago)
v43 v44 294 294 || '''Title''' || '''Pull Request''' || '''Issue''' || 295 295 || wxGUI: Projection checkbox from Map Display statusbar moved to Map Display Settings || https://github.com/OSGeo/grass/pull/2087 || - || MERGED || 296 || wxGUI: Move SbMask widget to main window statusbar || https://github.com/OSGeo/grass/pull/2089 || - || MERGED ||296 || wxGUI: Move !SbMask widget to main window statusbar || https://github.com/OSGeo/grass/pull/2089 || - || MERGED || 297 297 || wxGUI: Fix the error when statusbar does know statusbarItem property "region" || https://github.com/OSGeo/grass/pull/2106 || - || MERGED || 298 298 || wxGUI: Statusbar settings as a part of Map Display Settings || https://github.com/OSGeo/grass/pull/2153 || - || MERGED || 299 299 || wxGUI: Use Map Display settings in other Map Display applications || https://github.com/OSGeo/grass/pull/2155 || - || MERGED || 300 300 || wxGUI: update statusbar when projection settings checkbox has been toggled || https://github.com/OSGeo/grass/pull/2178 || - || MERGED || 301 || wxGUI: Fix statusbar mode index for GetMode method || https://github.com/OSGeo/grass/pull/2190 || - || MERGED ||301 || wxGUI: Fix statusbar mode index for !GetMode method || https://github.com/OSGeo/grass/pull/2190 || - || MERGED || 302 302 || wxGUI: New toolbar icon for accessing Map Display settings dialog || https://github.com/OSGeo/grass/pull/2214 || - || MERGED || 303 303
