Changes between Version 31 and Version 32 of wxGUIDevelopment/RedesigningStatusbar
Feb 21, 2022, 2:29:22 AM (2 years ago)
lindakladivova
  • wxGUIDevelopment/RedesigningStatusbar
    v31 v32
    236236
    237237'''2) What am I going to achieve for next week?'''\\
    238 The main task for the next week is to finish the PR https://github.com/OSGeo/grass/pull/2153. The one chapter about combobox removal (and statusbar redesign) will be finished then. However, there are still many things missing. The Projection page from GUI settings should be moved to Map Display settings, for instance.
    239
    240 '''3) Is there any blocking issue?'''\\
    241 No, it isn't.
     238The main task for the next week is to finish the PR https://github.com/OSGeo/grass/pull/2153. The one chapter about combobox removal (statusbar redesign) will be finished then. However, there are still many things missing. The Projection page from GUI settings should be moved to Map Display settings, for instance, or EPSG text widget could be added to the main statusbar etc..
     239
     240'''3) Is there any blocking issue?'''\\
     241No, it isn't.
