Changes between Version 17 and Version 18 of wxGUIDevelopment/ImprovingSingleWindowUX
Jan 9, 2023, 7:57:09 AM (19 months ago)
lindakladivova
  • wxGUIDevelopment/ImprovingSingleWindowUX
    v17 v18
    230230'''3) Is there any blocking issue?'''
    231231No, it isn't.
     232
     233== Week 5 ==
     234'''1) What did I complete this week?'''
     235The PR https://github.com/OSGeo/grass/pull/2682 implementing the Export history button in the Console pane was merged.
     236
     237The first part of the week I worked on PR https://github.com/OSGeo/grass/pull/2718 which adds an input prompt sign to the command prompt widget. However, although it was our suggestion from https://github.com/OSGeo/grass/issues/2585, the intervention into the command prompt showed programmatically as very unfortunate - it was really hard to cover all cases of how the text in the command prompt could be managed. So, we decided to implement the task differently by showing a hint in the case that the command prompt is not focused. I think it is an even more user-friendly solution. It is already prepared for merging (see https://github.com/OSGeo/grass/pull/2728).
     238
     239Meanwhile, I worked on adding "isDocked" parameter to workspace handling in the PR https://github.com/OSGeo/grass/pull/2667 dealing with dock/undock map display functionality. It was the thing I forget to consider. However, the workspace issue revealed another error in https://github.com/OSGeo/grass/pull/2667 related to closing undocked map display frame.
     240
     241'''2) What am I going to achieve for next week?'''
     242
     243The goal for the next week is to merge both - https://github.com/OSGeo/grass/pull/2728 and https://github.com/OSGeo/grass/pull/2667. Then I plan to create a PR on the Console reorganization according to the suggestion in https://github.com/OSGeo/grass/issues/2585.
     244
     245'''3) Is there any blocking issue?'''
     246There is one blocking error in https://github.com/OSGeo/grass/pull/2667 related to the erroneous closing of undocked map display frame (wrapped C/C++ object of type MapPageFrame has been deleted). I have already spent several hours to fix it but unsuccessfully. I will probably put it off now and go back later, with more ideas in my mind.
