Changes between Version 5 and Version 6 of TracTicketsCustomFields
- 09/05/24 06:59:05 (7 months ago)
TabularUnified TracTicketsCustomFields
v5 v6 62 62 * `reference` to treat the content as a queryable value 63 63 * `list` to interpret the content as a list of queryable values, separated by whitespace 64 * ticketlink_query: Query for linkifying ticket values. 65 Not applicable for format `plain` and `wiki`. 64 66 * '''checkbox''': A boolean value check box. 65 67 * label: Descriptive label. 66 68 * value: Default value, 0 or 1. 67 69 * order: Sort order placement. 70 * ticketlink_query: Query for linkifying ticket values. 68 71 * '''select''': Drop-down select box. Uses a list of values. 69 72 * label: Descriptive label. … … 71 74 * value: Default value (one of the values from options). 72 75 * order: Sort order placement. 76 * ticketlink_query: Query for linkifying ticket values. 73 77 * '''radio''': Radio buttons. Essentially the same as '''select'''. 74 78 * label: Descriptive label. … … 76 80 * value: Default value, one of the values from options. 77 81 * order: Sort order placement. 82 * ticketlink_query: Query for linkifying ticket values. 78 83 * '''textarea''': Multi-line text area. 79 84 * label: Descriptive label. … … 95 100 96 101 Macros will be expanded when rendering `textarea` fields with format `wiki`, but not when rendering `text` fields with format `wiki`. 102 103 For applicable fields, the `ticketlink_query` option 104 overrides [[TracIni#query-ticketlink_query-option|"[query] ticketlink_query"]], and the format is the same as 105 that option. When the `ticketlink_query` option 106 is not specified, `[query]` `ticketlink_query` is used to 107 linkify the field. 97 108 98 109 === Sample Configuration
