Changes between Version 25 and Version 26 of Submitting/C
06/11/14 10:28:08 (11 years ago)
martinl
  • Submitting/C
    v25 v26
    210210      -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut main.c
    211211}}}
    212     Existing code should not be re-indented except in extreme cases, as this will make "diff" comparisons with older versions impossible. If indent is needed, do not check in any changes other than the indentation in the same commit! Do add the indent switches and any indent warning messages to the SVN log. Any change or fix mixed in with an indent is very hard to track
    213 making it hard for others to follow the change or fix any new bugs. For your convenience use the src:grass/trunk/tools/grass_indent.sh script.
     212    Existing code should not be re-indented except in extreme cases, as this will make "diff" comparisons with older versions impossible. If indent is needed, do not check in any changes other than the indentation in the same commit! Do add the indent switches and any indent warning messages to the SVN log. Any change or fix mixed in with an indent is very hard to track making it hard for others to follow the change or fix any new bugs. For your convenience use the source:grass/trunk/tools/grass_indent.sh script.
    214213
    215214
