| 83 | ==== UNSORTED FIXME ==== |
| 84 | |
| 85 | * wxGUI: Add rename and delete of Location and Mapset in Datacatalog by @lindakladivova in (PR:771) |
| 86 | * wxGUI: address digitizer backround map issue #467 by @petrasovaa in (PR:494) |
| 87 | * wxGUI: Add temporary files for Non-Interactive Display by @chaedri in (PR:1727) |
| 88 | * Allow delete on multiple locations in data catalog by @lindakladivova in (PR:875) |
| 89 | * catalog: first load and display tree with locations for responsiveness, then load everything by @petrasovaa in (PR:1043) |
| 90 | |
| 91 | |
| 92 | |
| 93 | * Add zsh history change by @nilason in (PR:975) |
| 94 | * Add zsh terminal prompt support by @nilason in (PR:722) |
| 95 | |
| 96 | * allow larger maps in r.terraflow by @ninsbl in (PR:265) |
| 97 | * Allow parsing long GISDBASE paths by @attilaolah in (PR:1376) |
| 98 | * allow to overwrite command history by @ninsbl in (PR:272) |
| 99 | * Allow to use a fixed random seed via SOURCE_DATE_EPOCH by @bmwiedemann in (PR:251) |
| 100 | |
| 101 | |
| 102 | * Change default color for rendering vectors (gray->blue) [news] by @wenzeslaus in (PR:1166) |
| 103 | * changed natural earth dataset archive from zip to tarball by @baharmon in (PR:867) |
| 104 | * Change is/is not to ==/!= for literal comparisons by @HuidaeCho in (PR:264) |
| 105 | * Change local variable names to lowercase by @HuidaeCho in (PR:273) |
| 106 | * change sponsor link to opencollective by @veroandreo in (PR:1865) |
| 107 | * Check for gislock and other issues when deleting/renaming/editing mapset and location in catalog by @lindakladivova in (PR:904) |
| 108 | * Cleanup .swp files too by @sebastic in (PR:97) |
| 109 | * Code quality fixes for grass package (lib/python) by @wenzeslaus in (PR:576) |
| 110 | |
| 111 | * copy libs into bin directory after running make distclean by @landam in (PR:172) |
| 112 | |
| 113 | * Data catalog: double click on map from different location fails by @lindakladivova in (PR:886) |
| 114 | * datacatalog: fix when no watchdog is present, fix pasting map by @petrasovaa in (PR:1099) |
| 115 | * datum: add support for D_Rauenberg_1983 by @neteler in (PR:1331) |
| 116 | * datum.table: added SIRGAS 1995 by @neteler in (PR:464) |
| 117 | * datum.table: add RGFG95 by @neteler in (PR:813) |
| 118 | * Define MIN() and MAX() correctly and exactly once. by @infrastation in (PR:1795) |
| 119 | * delete ctypesgencore/parser/lextab.py by @neteler in (PR:95) |
| 120 | * delete unused function toolboxes._encode_string() by @pesekon2 in (PR:234) |
| 121 | * demolocation: update by @petrasovaa in (PR:1285) |
| 122 | * disable module check since svn keywords are not maintained by git by @landam in (PR:117) |
| 123 | * Distinguish mapsets by ownership and lock in Data tab by @lindakladivova in (PR:849) |
| 124 | * Docstring improvements by @chaedri in (PR:1800) |
| 125 | * Do not install config.status by @bmwiedemann in (PR:263) |
| 126 | * Do not show Flags: in help if there are no flags by @wenzeslaus in (PR:105) |
| 127 | * env.bat.tmpl: Deal with blanks in OSGEO4W_ROOT by @jef-n in (PR:859) |
| 128 | * Error message has appeared in the console tab/cmd after close any module dialog by @tmszi in (PR:249) |
| 129 | * fix 3D rendering in animation tool by @petrasovaa in (PR:293) |
| 130 | * fix #411: closing Map Display and layer tree from different places by @petrasovaa in (PR:427) |
| 131 | * Fix an error when exporting csv file from g.gui.tplot by @lbartoletti in (PR:690) |
| 132 | * fix band references assignment by @landam in (PR:132) |
| 133 | * Fix Cairo for Windows by @nilason in (PR:1697) |
| 134 | * Fix Cartographic Composer Add graphic tool (Line/Rectangle), Add Image/North Arrow dialog wx FloatSpin widget size by @tmszi in (PR:310) |
| 135 | * Fix Cartographic Composer wxPython deprecation warning by @tmszi in (PR:309) |
| 136 | * Fix check wxGUI Set vector output format native format dsn by @tmszi in (PR:450) |
| 137 | * Fix copy-to-clipboard key binding for console (trac#3008) by @nilason in (PR:393) |
| 138 | * Fix dbmgr for Python3 by @petrasovaa in (PR:344) |
| 139 | * Fix decoding stderr after render layer fail by @tmszi in (PR:407) |
| 140 | * fix deprecated call warning for FutureCall by @petrasovaa in (PR:294) |
| 141 | * fix deprecated wx.NewId() by @neteler in (PR:150) |
| 142 | * Fix destroy open wxGUI Vector Network Analysis Tool dialog when wxGUI is closed by @tmszi in (PR:432) |
| 143 | * fix double string encoding with EncodeString() by @pesekon2 in (PR:241) |
| 144 | * Fixed the pygrass rpc server to avoid wrong restart warnings by @huhabla in (PR:100) |
| 145 | * Fix failing vector digitizer on mac, trac#3487 by @nilason in (PR:456) |
| 146 | * Fix fixed-width CJK formatting by @HuidaeCho in (PR:523) |
| 147 | * Fix Flake8 errors in temporal modules by @wenzeslaus in (PR:573) |
| 148 | * Fix flake8 pep8 errors by @neteler in (PR:986) |
| 149 | * Fix g.extension -i (compile), -d (download) flag by @tmszi in (PR:496) |
| 150 | * fix g.extension -l ValueError by @landam in (PR:1849) |
| 151 | * fix g.extension test by @petrasovaa in (PR:1364) |
| 152 | * fix init_dbif() returned values better interpretation by @pesekon2 in (PR:1008) |
| 153 | * fix Iterable import in pygrass/vector by @lrntct in (PR:734) |
| 154 | * Fix linker flags on FreeBSD. by @MikaelUrankar in (PR:1936) |
| 155 | * Fix missing checkboxes in ListCtrl by @petrasovaa in (PR:204) |
| 156 | * fix newid in psmap by @petrasovaa in (PR:154) |
| 157 | * fix NULL values for very small areas address in v.rast.stats by @ninsbl in (PR:402) |
| 158 | * Fix osgeo4w workflow by @agiudiceandrea in (PR:1757) |
| 159 | * fix position of null cells by @ninsbl in (PR:389) |
| 160 | * fix py3-numpy-dev package name by @neteler in (PR:112) |
| 161 | * Fix r.fillnulls to run in python 3 by @mwort in (PR:85) |
| 162 | * Fix set up sampling and analysis framework wizard relative import by @tmszi in (PR:409) |
| 163 | * Fix show layer inside the layer subgroup by @tmszi in (PR:400) |
| 164 | * Fix source code URL when addon path starts with root path by @HuidaeCho in (PR:1645) |
| 165 | * Fix spelling in comments esp. in GUI code by @wenzeslaus in (PR:1357) |
| 166 | * Fix SyntaxError issues with Python 3. by @sebastic in (PR:549) |
| 167 | * fix the renaming of wx.Event variables by @pesekon2 in (PR:128) |
| 168 | * fix typo in databaseintro.html by @jentjr in (PR:650) |
| 169 | * Fix typo in v.distance fatal msg by @wenzeslaus in (PR:163) |
| 170 | * Fix unable to open file from python editor by @aroche in (PR:288) |
| 171 | * fix usage of vector cats in constraint by @metzm in (PR:262) |
| 172 | * Fix use wxGUI Raster Digitizer input raster map layer temporary region by @tmszi in (PR:470) |
| 173 | * Fix valid location check, sync with other functions by @wenzeslaus in (PR:1777) |
| 174 | * Fix v.in.pdal compilation on mac, #475 by @nilason in (PR:479) |
| 175 | |
| 176 | * Format YAML in GH workflows by @wenzeslaus in (PR:1367) |
| 177 | * geos-config: Rename --libs to --clibs (configure uses --clibs) by @HuidaeCho in (PR:177) |
| 178 | * __getattr__ shortcut for calling GRASS display modules by @chaedri in (PR:1723) |
| 179 | * get rid of wx.insertStringItem deprecation warnings by @pesekon2 in (PR:120) |
| 180 | * GIS_H_DATE: switch to date -Iseconds format by @landam in (PR:485) |
| 181 | * GIS_H_VERSION: use git hash by @metzm in (PR:325) |
| 182 | * gislib/dox: Refine the command line parsing doc. by @infrastation in (PR:1010) |
| 183 | * gitignore: Add testreport directory by @nilason in (PR:852) |
| 184 | * GRASS GIS 8.0 changes by @neteler in (PR:1597) |
| 185 | * wxGUI: do not fail on invalid RC file (empty) by @landam in (PR:185) |
| 186 | * wxGUI: use %d instead of %s for integers by @HuidaeCho in (PR:554) |
| 187 | * wxGUI iclass + iscatt: fixes for Python3 by @petrasovaa in (PR:316) |
| 188 | * libimagery: move signatures to subdirs by @marisn in (PR:1850) |
| 189 | * images2gif: PILLOW_VERSION is obsolete by @petrasovaa in (PR:899) |
| 190 | * Improve G_open|find _misc function documentation by @marisn in (PR:1760) |
| 191 | * infrastructure doc: converted to MD by @neteler in (PR:715) |
| 192 | * infrastructure.md: add latest updates by @neteler in (PR:863) |
| 193 | * init: Add --tmp-mapset option by @wenzeslaus in (PR:313) |
| 194 | * init: Apply Black to the init script by @wenzeslaus in (PR:1359) |
| 195 | * init: Change the history file according to the current mapset for Bash by @wenzeslaus in (PR:930) |
| 196 | * init: Clean up Flake8 config by @wenzeslaus in (PR:1508) |
| 197 | * init: Create demolocation in grass.py, not wxGUI gis_set.py by @wenzeslaus in (PR:1208) |
| 198 | * init: Default to Bash, fallback to sh by @wenzeslaus in (PR:1836) |
| 199 | * init: ensure zsh environment variable SAVEHIST is set by @nilason in (PR:805) |
| 200 | * init: Solve most of Flake8 issues in grass.py by @wenzeslaus in (PR:1536) |
| 201 | * init: Start in last used mapset with --gui like --text by @wenzeslaus in (PR:767) |
| 202 | * init: Start shell only with TTY by @wenzeslaus in (PR:768) |
| 203 | * init: Update doc for non-interactive jobs by @wenzeslaus in (PR:1753) |
| 204 | * init: Update mapset and simplify shell prompts by @wenzeslaus in (PR:923) |
| 205 | * init: Use argparse instead of custom parsing for CLI by @wenzeslaus in (PR:1239) |
| 206 | * install: check lowercased prefix by @nilason in (PR:949) |
| 207 | * Integrate band references into portable signature files by @marisn in (PR:1501) |
| 208 | * introduce docker multistage build to alpine image by @mmacata in (PR:276) |
| 209 | * Keep module_items.xml in docker alpine by @mmacata in (PR:330) |
| 210 | * Lazy imports and work without import numpy by @wenzeslaus in (PR:511) |
| 211 | * libsymbol: fix bad argument order by @nilason in (PR:1820) |
| 212 | * Make band references optional to simplify generation of signatures by @marisn in (PR:1866) |
| 213 | * Make Data tab the default in GUI by @lindakladivova in (PR:756) |
| 214 | * make python script in gmodeler using items instead of iteritems by @pesekon2 in (PR:340) |
| 215 | * MapSwipe window has wrong title by @lindakladivova in (PR:1692) |
| 216 | * misc: fix indentation for r.series and r.patch by @aaronsms in (PR:1772) |
| 217 | * misc(r.slope.aspect): reindent C source files by @aaronsms in (PR:1765) |
| 218 | * Misleading lock symbol icon in the in the Data tab toolbar by @lindakladivova in (PR:870) |
| 219 | * more proofreading for r.geomorphon by @infrastation in (PR:991) |
| 220 | * Move grass package content to directory named grass by @wenzeslaus in (PR:1356) |
| 221 | * Move headers from include to include/grass by @wenzeslaus in (PR:1350) |
| 222 | * New color table: percentage of forest cover by @neteler in (PR:894) |
| 223 | * Number of bands relevant only to strds by @landam in (PR:1447) |
| 224 | * open_stds: check for unknown band references by @landam in (PR:1844) |
| 225 | * os.newline should not be used when writing in text mode by @petrasovaa in (PR:387) |
| 226 | * perlcritic: fix perlcritic errors by @ocsmit in (PR:1431) |
| 227 | * PS Driver: Write data to a tempfile before closing by @HuidaeCho in (PR:1451) |
| 228 | * rasterlib: Explain missing header file in get_cellhd by @wenzeslaus in (PR:933) |
| 229 | * raster module memory: set new value globally by @neteler in (PR:922) |
| 230 | * Rast_log_colors: Another attempt to address r.colors -g/-a (#1480) by @HuidaeCho in (PR:1937) |
| 231 | * Readd the ubuntu based Dockerfile by @hwbllmnn in (PR:143) |
| 232 | * Reference CONTRIBUTING.md file in README by @wenzeslaus in (PR:283) |
| 233 | * Reflect grassdb changes in catalog by @petrasovaa in (PR:994) |
| 234 | * register.py: allow registering from io objects by @ninsbl in (PR:1929) |
| 235 | * Remove colouring of standard buttons by @nilason in (PR:744) |
| 236 | * remove deprecated py 'PIL' module 'fromstring', 'tostring' method call by @tmszi in (PR:1223) |
| 237 | * Remove redundant encode string call in the error message string interpolation by @tmszi in (PR:308) |
| 238 | * Removing map layer crashes wxGUI (trac.osgeo.org/grass/ticket/3607) by @petrasovaa in (PR:462) |
| 239 | * render: Fix .legrow file existence check by @tmszi in (PR:691) |
| 240 | * replace deprecated inspect function by @petrasovaa in (PR:334) |
| 241 | * replace obsolete time.clock() in Python 3.3 by @petrasovaa in (PR:244) |
| 242 | * Set locale to euc-kr only for Windows by @HuidaeCho in (PR:520) |
| 243 | * several fixes related to font dialog by @petrasovaa in (PR:292) |
| 244 | * simplify GRASS_EXECUTABLE handling in package.sh by @landam in (PR:445) |
| 245 | * Simplify raster band reference management by @marisn in (PR:1272) |
| 246 | * Start in a demo/startup location by @lindakladivova in (PR:868) |
| 247 | * Startup: Avoid a race condition by @HuidaeCho in (PR:548) |
| 248 | * Store list of databases in settings by @lindakladivova in (PR:858) |
| 249 | * switch environment: also change mapset by @metzm in (PR:286) |
| 250 | * Switch to another mapset when in use (aka force remove lock) by @lindakladivova in (PR:906) |
| 251 | * Switch to debian 10.1 as dockerfile base image (master) by @hwbllmnn in (PR:140) |
| 252 | * Sync Korean translations by @HuidaeCho in (PR:556) |
| 253 | * tcsh prompt: fix update with change of mapset by @nilason in (PR:765) |
| 254 | * Update docs (#360) by @KolesovDmitry in (PR:361) |
| 255 | * Updated translators.csv file by @lucadelu in (PR:1249) |
| 256 | * Update from proj.4 to proj (g.version) by @kikislater in (PR:55) |
| 257 | * Update Location Wizard: First page by @lindakladivova in (PR:493) |
| 258 | * Update of travis configuration for Python 3 by @neteler in (PR:115) |
| 259 | * Update reference from proj.4 or proj4 to proj (g.version) by @kikislater in (PR:54) |
| 260 | * Updates made in the README.md file by @shubhamshah14102 in (PR:1951) |
| 261 | * Update to Black 21.5b1 by @wenzeslaus in (PR:1605) |
| 262 | * Update to upstream ctypesgen version by @nilason in (PR:1651) |
| 263 | * update usage of map() function to Python 3 by @pesekon2 in (PR:114) |
| 264 | * Upgrade tgis db by @landam in (PR:306) |
| 265 | * Use ${CC} instead of "cc" for linking on mac by @nilason in (PR:611) |
| 266 | * use copy instead of git clone in Dockerfiles by @mmacata in (PR:151) |
| 267 | * Use .wxgui_history as history file for the gui (#962) by @susi in (PR:1917) |
| 268 | |
| 269 | |
305 | | * Add numpy and other Python pkgs to CI by @wenzeslaus in (PR:585) |
306 | | * Add python3-wxgtk deb package in the Dockerfile by @tmszi in (PR:243) |
307 | | * add python-grass.bat for Python initialization by @landam in (PR:436) |
308 | | * Add rename and delete of Location and Mapset in Datacatalog by @lindakladivova in (PR:771) |
309 | | * address digitizer backround map issue #467 by @petrasovaa in (PR:494) |
310 | | * Add soname on FreeBSD by @lbartoletti in (PR:301) |
311 | | * Add temporary files for Non-Interactive Display by @chaedri in (PR:1727) |
312 | | * add text snippet and how to add band references by @veroandreo in (PR:1887) |
313 | | * Add -Werror to "GCC C/C++ standards check" CI builds by @nilason in (PR:1804) |
314 | | * Add zsh history change by @nilason in (PR:975) |
315 | | * Add zsh terminal prompt support by @nilason in (PR:722) |
316 | | * Allow delete on multiple locations in data catalog by @lindakladivova in (PR:875) |
317 | | * allow larger maps in r.terraflow by @ninsbl in (PR:265) |
318 | | * Allow parsing long GISDBASE paths by @attilaolah in (PR:1376) |
319 | | * allow to overwrite command history by @ninsbl in (PR:272) |
320 | | * Allow to use a fixed random seed via SOURCE_DATE_EPOCH by @bmwiedemann in (PR:251) |
321 | | * Band references implementation by @landam in (PR:63) |
322 | | * Binder button by @chaedri in (PR:1628) |
323 | | * catalog: first load and display tree with locations for responsiveness, then load everything by @petrasovaa in (PR:1043) |
324 | | * catalog: use natural sort by @petrasovaa in (PR:1012) |
325 | | * change alpine docker to alpine version 3.12 by @anikaweinmann in (PR:711) |
326 | | * Change default color for rendering vectors (gray->blue) [news] by @wenzeslaus in (PR:1166) |
327 | | * changed natural earth dataset archive from zip to tarball by @baharmon in (PR:867) |
328 | | * Change is/is not to ==/!= for literal comparisons by @HuidaeCho in (PR:264) |
329 | | * Change local variable names to lowercase by @HuidaeCho in (PR:273) |
330 | | * change Python shebang to python3 by @neteler in (PR:75) |
331 | | * change Python shebang to python3 by @neteler in (PR:82) |
332 | | * change python to python3 by @neteler in (PR:98) |
333 | | * change sponsor link to opencollective by @veroandreo in (PR:1865) |
334 | | * Check for gislock and other issues when deleting/renaming/editing mapset and location in catalog by @lindakladivova in (PR:904) |
335 | | * Cleanup .swp files too by @sebastic in (PR:97) |
336 | | * Code quality fixes for grass package (lib/python) by @wenzeslaus in (PR:576) |
337 | | * config.guess + config.sub: updated by @neteler in (PR:1155) |
338 | | * configure, config.sub, config.guess: updated by @neteler in (PR:1585) |
339 | | * configure update by @neteler in (PR:89) |
340 | | * configure: upgrade to autoconf 2.69 by @nilason in (PR:1845) |
341 | | * configure: use pkg-config for FreeType 2 by @infrastation in (PR:1719) |
342 | | * CONTRIBUTING.md: intro added for newcomers by @neteler in (PR:1566) |
343 | | * copy libs into bin directory after running make distclean by @landam in (PR:172) |
344 | | * Cross compilation by @HuidaeCho in (PR:257) |
345 | | * crosscompile enhancements by @HuidaeCho in (PR:1947) |
346 | | * crosscompile: Fix python.exe search by @HuidaeCho in (PR:1945) |
347 | | * crosscompile: More enhancements by @HuidaeCho in (PR:1948) |
348 | | * crosscompile: Sorting env vars more logically by @HuidaeCho in (PR:1954) |
349 | | * crosscompile: Support for BusyBox for Windows by @HuidaeCho in (PR:1946) |
350 | | * Cross-platform version of date -Iseconds in configure by @HuidaeCho in (PR:568) |
351 | | * CRS management by @metzm in (PR:976) |
352 | | * ctypes: fix Callable for Python 3.10 by @neteler in (PR:1672) |
353 | | * ctypes: Fix ctypesgencore for Python 3 by @wenzeslaus in (PR:379) |
354 | | * ctypes: move directory out of python/grass by @nilason in (PR:1898) |
355 | | * Data catalog: double click on map from different location fails by @lindakladivova in (PR:886) |
356 | | * datacatalog: fix when no watchdog is present, fix pasting map by @petrasovaa in (PR:1099) |
357 | | * datum: add support for D_Rauenberg_1983 by @neteler in (PR:1331) |
358 | | * datum.table: added SIRGAS 1995 by @neteler in (PR:464) |
359 | | * datum.table: add RGFG95 by @neteler in (PR:813) |
360 | | * Define MIN() and MAX() correctly and exactly once. by @infrastation in (PR:1795) |
361 | | * delete ctypesgencore/parser/lextab.py by @neteler in (PR:95) |
362 | | * delete unused function toolboxes._encode_string() by @pesekon2 in (PR:234) |
363 | | * demolocation: update by @petrasovaa in (PR:1285) |
364 | | * disable module check since svn keywords are not maintained by git by @landam in (PR:117) |
365 | | * Distinguish mapsets by ownership and lock in Data tab by @lindakladivova in (PR:849) |
366 | | * Docstring improvements by @chaedri in (PR:1800) |
367 | | * Document r.external issues with r.null by @mankoff in (PR:91) |
368 | | * Do not install config.status by @bmwiedemann in (PR:263) |
369 | | * Do not show Flags: in help if there are no flags by @wenzeslaus in (PR:105) |
370 | | * Drop wx.ALIGN_CENTER_HORIZONTAL, wx.ALIGN_CENTER_VERTICAL and wx.ALIGN_RIGHT when wxEXPAND is used by @ggardet in (PR:565) |
371 | | * Duplicate entry of "output" keyword by @kikislater in (PR:1001) |
372 | | * Enable Ctypesgen parsing of non-utf8 files on macOS, fixes trac #3883 by @nilason in (PR:385) |
373 | | * env.bat.tmpl: Deal with blanks in OSGEO4W_ROOT by @jef-n in (PR:859) |
374 | | * Error message has appeared in the console tab/cmd after close any module dialog by @tmszi in (PR:249) |
375 | | * Example notebooks by @chaedri in (PR:1787) |
376 | | * Extend keywords for null and mask modules by @wenzeslaus in (PR:239) |
377 | | * feat(misc): set NPROCS environment variable by @aaronsms in (PR:1734) |
378 | | * Fedora SPEC file: updated by @neteler in (PR:256) |
379 | | * fix #3882 by @petrasovaa in (PR:161) |
380 | | * fix 3D rendering in animation tool by @petrasovaa in (PR:293) |
381 | | * fix #411: closing Map Display and layer tree from different places by @petrasovaa in (PR:427) |
382 | | * Fix alpine docker by removing Python3 patch and PDAL by @anikaweinmann in (PR:373) |
383 | | * Fix an error when exporting csv file from g.gui.tplot by @lbartoletti in (PR:690) |
384 | | * fix band references assignment by @landam in (PR:132) |
385 | | * Fix basic Flake8 warnings in scripts by @wenzeslaus in (PR:539) |
386 | | * Fix bug introduced in the issue #466 by @tmszi in (PR:500) |
387 | | * Fix Cairo for Windows by @nilason in (PR:1697) |
388 | | * Fix Cartographic Composer Add graphic tool (Line/Rectangle), Add Image/North Arrow dialog wx FloatSpin widget size by @tmszi in (PR:310) |
389 | | * Fix Cartographic Composer wxPython deprecation warning by @tmszi in (PR:309) |
390 | | * Fix check wxGUI Set vector output format native format dsn by @tmszi in (PR:450) |
391 | | * Fix compiler warnings, part 10 by @nilason in (PR:1395) |
392 | | * Fix compiler warnings, part 12 by @nilason in (PR:1406) |
393 | | * Fix compiler warnings, part 5 (rst/interpfl lib & v.surf.rst) by @nilason in (PR:1271) |
394 | | * Fix compiler warnings, part 9 by @nilason in (PR:1316) |
395 | | * Fix copy-to-clipboard key binding for console (trac#3008) by @nilason in (PR:393) |
396 | | * Fix dbmgr for Python3 by @petrasovaa in (PR:344) |
397 | | * Fix decoding stderr after render layer fail by @tmszi in (PR:407) |
398 | | * fix deprecated call warning for FutureCall by @petrasovaa in (PR:294) |
399 | | * fix deprecated wx.NewId() by @neteler in (PR:150) |
400 | | * Fix destroy open wxGUI Vector Network Analysis Tool dialog when wxGUI is closed by @tmszi in (PR:432) |
401 | | * fix double string encoding with EncodeString() by @pesekon2 in (PR:241) |
402 | | * Fixed gis parser json implementation by @huhabla in (PR:99) |
403 | | * Fixed the pygrass rpc server to avoid wrong restart warnings by @huhabla in (PR:100) |
404 | | * Fix failing vector digitizer on mac, trac#3487 by @nilason in (PR:456) |
405 | | * Fix fixed-width CJK formatting by @HuidaeCho in (PR:523) |
406 | | * Fix Flake8 errors in temporal modules by @wenzeslaus in (PR:573) |
407 | | * Fix flake8 pep8 errors by @neteler in (PR:986) |
408 | | * Fix g.extension -i (compile), -d (download) flag by @tmszi in (PR:496) |
409 | | * fix g.extension -l ValueError by @landam in (PR:1849) |
410 | | * fix g.extension test by @petrasovaa in (PR:1364) |
411 | | * Fix grass-session installation in alpine docker by @mmacata in (PR:516) |
412 | | * Fix grass-session installation in docker files by @neteler in (PR:517) |
413 | | * fix init_dbif() returned values better interpretation by @pesekon2 in (PR:1008) |
414 | | * fix Iterable import in pygrass/vector by @lrntct in (PR:734) |
415 | | * Fix linker flags on FreeBSD. by @MikaelUrankar in (PR:1936) |
416 | | * Fix macOS gui bug for v.proj and r.proj on, addresses #3502 by @nilason in (PR:363) |
417 | | * Fix missing checkboxes in ListCtrl by @petrasovaa in (PR:204) |
418 | | * fix newid in psmap by @petrasovaa in (PR:154) |
419 | | * fix NULL values for very small areas address in v.rast.stats by @ninsbl in (PR:402) |
420 | | * Fix osgeo4w workflow by @agiudiceandrea in (PR:1757) |
421 | | * fix position of null cells by @ninsbl in (PR:389) |
422 | | * fix py3-numpy-dev package name by @neteler in (PR:112) |
423 | | * Fix r.fillnulls to run in python 3 by @mwort in (PR:85) |
424 | | * Fix set up sampling and analysis framework wizard relative import by @tmszi in (PR:409) |
425 | | * Fix show layer inside the layer subgroup by @tmszi in (PR:400) |
426 | | * Fix some Flake8 for pydispatch by @wenzeslaus in (PR:1808) |
427 | | * Fix some Flake8 warnings in grass package by @wenzeslaus in (PR:540) |
428 | | * Fix source code URL when addon path starts with root path by @HuidaeCho in (PR:1645) |
429 | | * Fix spelling errors. by @sebastic in (PR:1916) |
430 | | * Fix spelling errors. by @sebastic in (PR:561) |
431 | | * Fix spelling errors. by @sebastic in (PR:871) |
432 | | * Fix spelling errors. by @sebastic in (PR:992) |
433 | | * Fix spelling in comments esp. in GUI code by @wenzeslaus in (PR:1357) |
434 | | * Fix SyntaxError issues with Python 3. by @sebastic in (PR:549) |
435 | | * fix the renaming of wx.Event variables by @pesekon2 in (PR:128) |
436 | | * fix typo in databaseintro.html by @jentjr in (PR:650) |
437 | | * Fix typo in v.distance fatal msg by @wenzeslaus in (PR:163) |
438 | | * Fix unable to open file from python editor by @aroche in (PR:288) |
439 | | * fix usage of vector cats in constraint by @metzm in (PR:262) |
440 | | * Fix use wxGUI Raster Digitizer input raster map layer temporary region by @tmszi in (PR:470) |
441 | | * Fix valid location check, sync with other functions by @wenzeslaus in (PR:1777) |
442 | | * Fix v.in.pdal compilation on mac, #475 by @nilason in (PR:479) |
443 | | * Fix wxGUI Field calculator wx.ListBox widget choices argument by @tmszi in (PR:460) |
444 | | * Fix wxGUI g.gui.rlisetup config file open mode for write in text mode by @tmszi in (PR:410) |
445 | | * Fix wxGUI g.gui.vdigit update available vector maps after the frame is show by @tmszi in (PR:465) |
446 | | * Fix wxGUI Graphical Modeler About Dialog import by @tmszi in (PR:438) |
447 | | * Fix wxGUI Graphical Modeler decode string by @tmszi in (PR:441) |
448 | | * Fix wxGUI Graphical Modeler wx widget deprecation warning by @tmszi in (PR:442) |
449 | | * Fix wxGUI Histogramming Tool Plot xSpec, ySpec property value by @tmszi in (PR:422) |
450 | | * Fix wxGUI Histogramming Tool save text settings (font family/style/weight) into the file by @tmszi in (PR:421) |
451 | | * Fix wxGUI Import vector/raster dialog min width by @tmszi in (PR:492) |
452 | | * Fix wxGUI Layer Manager add layer into the empty layer group by @tmszi in (PR:413) |
453 | | * Fix wxGUI Layer Manager add vector map layer Set color table interactively menu item by @tmszi in (PR:472) |
454 | | * Fix wxGUI Layer Manager close the Layers NoteBook Display FlatNotebook page by @tmszi in (PR:411) |
455 | | * Fix wxGUI Manage color rules interactively (vector map) frame by @tmszi in (PR:429) |
456 | | * Fix wxGUI Manage color rules interactively (vector map) number of LoadTable method calls by @tmszi in (PR:444) |
457 | | * Fix wxGUI Manage color rules interactively (vector map) wx.CollapsiblePane widget layout by @tmszi in (PR:449) |
458 | | * Fix wxGUI Set vector output format load profile settings by @tmszi in (PR:451) |
459 | | * Fix wxGUI Set vector output format wx.Choice widget width by @tmszi in (PR:453) |
460 | | * Fix wxGUI Vector Network Analysis Tool close dialog by @tmszi in (PR:419) |
461 | | * Fix wxGUI Vector Network Analysis Tool ComboBox widget deprecation warning by @tmszi in (PR:418) |
462 | | * Fix wxGUI Vector Network Analysis Tool execute analysis by @tmszi in (PR:440) |
463 | | * Fix wxGUI Vector Network Analysis Tool FlatNotebook page small grey square artifact by @tmszi in (PR:425) |
464 | | * Fix wxGUI Vector Network Analysis Tool merge dicts by @tmszi in (PR:417) |
465 | | * Format YAML in GH workflows by @wenzeslaus in (PR:1367) |
466 | | * GDAL/OGR import: check projection of input data by @metzm in (PR:317) |
467 | | * GDAL/OGR import: report XY location when comparing projections by @metzm in (PR:368) |
468 | | * geos-config: Rename --libs to --clibs (configure uses --clibs) by @HuidaeCho in (PR:177) |
469 | | * __getattr__ shortcut for calling GRASS display modules by @chaedri in (PR:1723) |
470 | | * get rid of wx.insertStringItem deprecation warnings by @pesekon2 in (PR:120) |
471 | | * GIS_H_DATE: switch to date -Iseconds format by @landam in (PR:485) |
472 | | * GIS_H_VERSION: use git hash by @metzm in (PR:325) |
473 | | * gislib/dox: Refine the command line parsing doc. by @infrastation in (PR:1010) |
474 | | * GitHub action CI: drop ubuntu-16.04 by @neteler in (PR:1254) |
475 | | * GitHub Action: Completion of security analysis with CodeQL by @mmacata in (PR:1300) |
476 | | * gitignore: Add testreport directory by @nilason in (PR:852) |
477 | | * Git: Un-ignore locale directory by @wenzeslaus in (PR:1512) |
478 | | * gmodeler: fix python export - main() by @landam in (PR:336) |
479 | | * GRASS GIS 8.0 changes by @neteler in (PR:1597) |
480 | | * grass.jupyter: add property filename to GrassRenderer by @petrasovaa in (PR:1846) |
481 | | * grass.jupyter: more flexible region handling for rendering by @petrasovaa in (PR:1871) |
482 | | * grass.py: Evaluate ^export lines only and expand variables in double/non-quoted values by @HuidaeCho in (PR:170) |
483 | | * grass.py: fix typo in info_text, svn -> dev by @landam in (PR:78) |
484 | | * grass.py: Match.__getitem__ is new from version 3.6, we need to use g… by @petrasovaa in (PR:253) |
485 | | * grass.py: used space as delimiter to get GRASS_VERSION_STRING by @ninsbl in (PR:405) |
486 | | * grass.sh: enforce Python 3 by @neteler in (PR:345) |
487 | | * grass startup: added support for google-chrome and chromium by @neteler in (PR:201) |
488 | | * GUI: do not fail on invalid RC file (empty) by @landam in (PR:185) |
489 | | * GUI: use %d instead of %s for integers by @HuidaeCho in (PR:554) |
490 | | * gunittest: CalledModuleError constructor accepts module, code, returncode, and errors by @HuidaeCho in (PR:1788) |
491 | | * gunittest: Deduplicate output decoding code by @wenzeslaus in (PR:1539) |
492 | | * gunittest docs: fix broken links by @neteler in (PR:934) |
493 | | * gunittest: Exclude broken tests by @wenzeslaus in (PR:1587) |
494 | | * gunittest: Fix stdout used instead of stderr by @wenzeslaus in (PR:1707) |
495 | | * gunittest: init super() to initialise 'errors' attribute by @nilason in (PR:1685) |
496 | | * gunittest: Non-zero return code on certian percetage of tests failing by @wenzeslaus in (PR:377) |
497 | | * gunittest: update module interface doctest by @nilason in (PR:1699) |
498 | | * iclass + iscatt: fixes for Python3 by @petrasovaa in (PR:316) |
499 | | * Ignore current errors from wxGUI, scripts, temporal by @wenzeslaus in (PR:537) |
500 | | * Ignore paths in CodeQL by @wenzeslaus in (PR:1778) |
501 | | * imagery/i.image.mosaic: fix encode, decode string by @tmszi in (PR:1035) |
502 | | * Imagery lib: Add notes to documentation about I_get_*2() functions by @marisn in (PR:1250) |
503 | | * Imagery: move signatures to subdirs by @marisn in (PR:1850) |
504 | | * images2gif: PILLOW_VERSION is obsolete by @petrasovaa in (PR:899) |
505 | | * Improve G_open|find _misc function documentation by @marisn in (PR:1760) |
506 | | * infrastructure doc: converted to MD by @neteler in (PR:715) |
507 | | * infrastructure.md: add latest updates by @neteler in (PR:863) |
508 | | * init: Add --tmp-mapset option by @wenzeslaus in (PR:313) |
509 | | * init: Apply Black to the init script by @wenzeslaus in (PR:1359) |
510 | | * init: Change the history file according to the current mapset for Bash by @wenzeslaus in (PR:930) |
511 | | * init: Clean up Flake8 config by @wenzeslaus in (PR:1508) |
512 | | * init: Create demolocation in grass.py, not wxGUI gis_set.py by @wenzeslaus in (PR:1208) |
513 | | * init: Default to Bash, fallback to sh by @wenzeslaus in (PR:1836) |
514 | | * init: ensure zsh environment variable SAVEHIST is set by @nilason in (PR:805) |
515 | | * init: Solve most of Flake8 issues in grass.py by @wenzeslaus in (PR:1536) |
516 | | * init: Start in last used mapset with --gui like --text by @wenzeslaus in (PR:767) |
517 | | * init: Start shell only with TTY by @wenzeslaus in (PR:768) |
518 | | * init: Update doc for non-interactive jobs by @wenzeslaus in (PR:1753) |
519 | | * init: Update mapset and simplify shell prompts by @wenzeslaus in (PR:923) |
520 | | * init: Use argparse instead of custom parsing for CLI by @wenzeslaus in (PR:1239) |
521 | | * install: check lowercased prefix by @nilason in (PR:949) |
522 | | * Integrate band references into portable signature files by @marisn in (PR:1501) |
523 | | * Interactive vector maps for Jupyter Notebooks by @chaedri in (PR:1710) |
524 | | * introduce docker multistage build to alpine image by @mmacata in (PR:276) |
525 | | * json parser: change + to @ for URLs by @neteler in (PR:175) |
526 | | * json parser: fix mapsets in tokenizing by @neteler in (PR:1252) |
527 | | * jupyter: Add virtual framebuffer X server dependency by @wenzeslaus in (PR:1827) |
528 | | * jupyter: Fix main notebook URL, note grass.jupyter is a preview by @wenzeslaus in (PR:1828) |
529 | | * Jupyter: Non-interactive display by @chaedri in (PR:1668) |
530 | | * jupyter: Render 3D images with m.nviz.image by @wenzeslaus in (PR:1831) |
531 | | * Keep module_items.xml in docker alpine by @mmacata in (PR:330) |
532 | | * keyword 'geometry' added by @neteler in (PR:940) |
533 | | * Lazy imports and work without import numpy by @wenzeslaus in (PR:511) |
534 | | * libsymbol: fix bad argument order by @nilason in (PR:1820) |
535 | | * Mac: converted compile instructions from RTF to markdown by @neteler in (PR:636) |
536 | | * macOS/install: do not install system level docs by @nilason in (PR:1909) |
537 | | * macOS: modernize app bundle info by @nilason in (PR:941) |
538 | | * macOS: use @rpath as dynamic linker by @nilason in (PR:981) |
539 | | * Mac ReadMe: stylistic update by @nilason in (PR:639) |
540 | | * Mac: Update app icon for hi-res support by @nilason in (PR:829) |
541 | | * make: Add support for Makefile variable DESTDIR by @nilason in (PR:1234) |
542 | | * Make band references optional to simplify generation of signatures by @marisn in (PR:1866) |
543 | | * Make Data tab the default in GUI by @lindakladivova in (PR:756) |
544 | | * make python script in gmodeler using items instead of iteritems by @pesekon2 in (PR:340) |
545 | | * MapSwipe window has wrong title by @lindakladivova in (PR:1692) |
546 | | * misc: fix indentation for r.series and r.patch by @aaronsms in (PR:1772) |
547 | | * misc(r.slope.aspect): reindent C source files by @aaronsms in (PR:1765) |
548 | | * Misleading lock symbol icon in the in the Data tab toolbar by @lindakladivova in (PR:870) |
549 | | * more proofreading for r.geomorphon by @infrastation in (PR:991) |
550 | | * Move g.download.location to core, create grass.utils lib by @wenzeslaus in (PR:1715) |
551 | | * Move grass package content to directory named grass by @wenzeslaus in (PR:1356) |
552 | | * Move headers from include to include/grass by @wenzeslaus in (PR:1350) |
553 | | * mswindows: crosscompile under WSL by @HuidaeCho in (PR:1940) |
554 | | * mswindows: Update crosscompile.sh to 8.0 by @HuidaeCho in (PR:1876) |
555 | | * mswindows: Update crosscompile.sh to the master branch of MXE by @HuidaeCho in (PR:1939) |
556 | | * NC full sample dataset: new URL by @neteler in (PR:1463) |
557 | | * Needed version updates for GRASS GIS 7.9 by @neteler in (PR:77) |
558 | | * New color table: percentage of forest cover by @neteler in (PR:894) |
559 | | * New Python subpackage for working with locations and mapsets by @wenzeslaus in (PR:837) |
560 | | * Number of bands relevant only to strds by @landam in (PR:1447) |
561 | | * NVIZ: Fix a typo by @HuidaeCho in (PR:553) |
562 | | * NVIZ: Fix a typo (cont'ed) by @neteler in (PR:557) |
563 | | * open_stds: check for unknown band references by @landam in (PR:1844) |
564 | | * OSGeo4W BAT files review by @landam in (PR:437) |
565 | | * OSGeo4W workflow for GitHub Actions by @HuidaeCho in (PR:692) |
566 | | * os.newline should not be used when writing in text mode by @petrasovaa in (PR:387) |
567 | | * perlcritic: fix perlcritic errors by @ocsmit in (PR:1431) |
568 | | * postgres: Assign 1000 to TEXT field length by @HuidaeCho in (PR:412) |
569 | | * PS Driver: Write data to a tempfile before closing by @HuidaeCho in (PR:1451) |
570 | | * pygrass: Add update parameters method to Module by @wenzeslaus in (PR:1712) |
571 | | * pygrass: call centroid function when buffering areas by @ninsbl in (PR:1655) |
572 | | * pygrass: remove failing test as not useful by @petrasovaa in (PR:1411) |
573 | | * pygrass: Remove usage of bare except by @wenzeslaus in (PR:1544) |
574 | | * python gunittest: Add a new assertion for raster equivalence by @marisn in (PR:1148) |
575 | | * pythonlib: add env variables to all relevant functions in script lib by @petrasovaa in (PR:677) |
576 | | * pythonlib: allow wkt to be also string in create_location() by @petrasovaa in (PR:723) |
577 | | * pythonlib: Enable ambiguous variable name warning by @wenzeslaus in (PR:1538) |
578 | | * pythonlib: Enable bare except warning by @wenzeslaus in (PR:1549) |
579 | | * pythonlib: Enable escape sequence warning by @wenzeslaus in (PR:1529) |
580 | | * pythonlib: Enable unused var warning by @wenzeslaus in (PR:1509) |
581 | | * pythonlib: fix pygrass Module tests by making it picklable by @petrasovaa in (PR:1407) |
582 | | * pythonlib: Fix stylistic Flake8 warnings by @wenzeslaus in (PR:1486) |
583 | | * pythonlib/grassdb: on Windows we can't simply get file owner by @petrasovaa in (PR:945) |
584 | | * pythonlib/grassdb: replace unix only function for file owner name by @petrasovaa in (PR:896) |
585 | | * pythonlib: Reduce usage of bare except in script by @wenzeslaus in (PR:1543) |
586 | | * pythonlib: Remove star imports by @wenzeslaus in (PR:1546) |
587 | | * pythonlib: return None from run_command() by @wenzeslaus in (PR:165) |
588 | | * pythonlib: safer mechanism for switching dbs in create_location by @petrasovaa in (PR:804) |
589 | | * pythonlib: Use more specific language in CalledModuleError by @wenzeslaus in (PR:1525) |
590 | | * python scripting lib: fix run_command(error='status') not returning 0 by @petrasovaa in (PR:1839) |
591 | | * python/script/raster.py: Fix encode string by @tmszi in (PR:738) |
592 | | * Python scripts: remove UTF-8 coding line by @neteler in (PR:1461) |
593 | | * python verbosity docs: minor layout fixes by @neteler in (PR:1004) |
594 | | * Quick-fix for d.correlate.py by @NikosAlexandris in (PR:1149) |
595 | | * quick fix of g.extension on MS Windows by @landam in (PR:176) |
596 | | * rasterlib: Explain missing header file in get_cellhd by @wenzeslaus in (PR:933) |
597 | | * raster module memory: set new value globally by @neteler in (PR:922) |
598 | | * Raster Support for Interactive Jupyter maps with folium by @chaedri in (PR:1769) |
599 | | * Rast_log_colors: Another attempt to address r.colors -g/-a (#1480) by @HuidaeCho in (PR:1937) |
600 | | * Readd the ubuntu based Dockerfile by @hwbllmnn in (PR:143) |
601 | | * README: more CI status badges added by @neteler in (PR:764) |
602 | | * README refactoring by @pesekon2 in (PR:231) |
603 | | * Reduce Flake8 config to one file by @wenzeslaus in (PR:1807) |
604 | | * Reference CONTRIBUTING.md file in README by @wenzeslaus in (PR:283) |
605 | | * Reflect grassdb changes in catalog by @petrasovaa in (PR:994) |
606 | | * Refs by S Gebbert added by @neteler in (PR:121) |
607 | | * register.py: allow registering from io objects by @ninsbl in (PR:1929) |
608 | | * Remove colouring of standard buttons by @nilason in (PR:744) |
609 | | * remove deprecated py 'PIL' module 'fromstring', 'tostring' method call by @tmszi in (PR:1223) |
610 | | * remove @# from GRASS_VERSION_STRING by @landam in (PR:528) |
611 | | * remove now unneeded Python 3 shebang trick by @neteler in (PR:90) |
612 | | * Remove __pycache__ directories before release. by @sebastic in (PR:182) |
613 | | * remove python3-3.8.1 patch by @mmacata in (PR:383) |
614 | | * Remove redundant encode string call in the error message string interpolation by @tmszi in (PR:308) |
615 | | * Removing map layer crashes wxGUI (trac.osgeo.org/grass/ticket/3607) by @petrasovaa in (PR:462) |
616 | | * Rename the master branch to main by @wenzeslaus in (PR:1806) |
617 | | * Rename tools directory to utils by @wenzeslaus in (PR:1348) |
618 | | * render: Fix .legrow file existence check by @tmszi in (PR:691) |
619 | | * replace deprecated inspect function by @petrasovaa in (PR:334) |
620 | | * replace obsolete time.clock() in Python 3.3 by @petrasovaa in (PR:244) |
621 | | * REQUIREMENTS.html: numerous URLs updated by @neteler in (PR:202) |
622 | | * scripts: Enable ambiguous variable name warning by @wenzeslaus in (PR:1515) |
623 | | * scripts: Enable bare except warning by @wenzeslaus in (PR:1517) |
624 | | * scripts: Enable import not at top warning by @wenzeslaus in (PR:1510) |
625 | | * scripts: Fix stylistic Flake8 warnings by @wenzeslaus in (PR:1487) |
626 | | * scripts: Remove unused vars or ignore in Flake8 by @wenzeslaus in (PR:1498) |
627 | | * scripts/r.plane/r.plane.py:fixed bare except by @ShubhamSwati in (PR:1608) |
628 | | * Session initiations functions for Jupyter Notebooks by @chaedri in (PR:1629) |
629 | | * Set locale to euc-kr only for Windows by @HuidaeCho in (PR:520) |
630 | | * several fixes related to font dialog by @petrasovaa in (PR:292) |
631 | | * simplify GRASS_EXECUTABLE handling in package.sh by @landam in (PR:445) |
632 | | * Simplify raster band reference management by @marisn in (PR:1272) |
633 | | * Small code fixes for d.legend and Cairo_Text by @wenzeslaus in (PR:1076) |
634 | | * Sort file lists by @bmwiedemann in (PR:247) |
635 | | * standardization of Markdown files by @pesekon2 in (PR:346) |
636 | | * Start in a demo/startup location by @lindakladivova in (PR:868) |
637 | | * Startup: Avoid a race condition by @HuidaeCho in (PR:548) |
638 | | * Stop ignoring .git folder for docker builds by @mmacata in (PR:1182) |
639 | | * Store list of databases in settings by @lindakladivova in (PR:858) |
640 | | * Support Korean (ko) language settings from g.gui for Windows by @HuidaeCho in (PR:519) |
641 | | * svn refs changed to git by @neteler in (PR:93) |
642 | | * Switch alpine docker to alpine 3.11 and compiled pdal by @mmacata in (PR:399) |
643 | | * switch environment: also change mapset by @metzm in (PR:286) |
644 | | * Switch to another mapset when in use (aka force remove lock) by @lindakladivova in (PR:906) |
645 | | * Switch to debian 10.1 as dockerfile base image (master) by @hwbllmnn in (PR:140) |
646 | | * Sync Korean translations by @HuidaeCho in (PR:556) |
647 | | * tcsh prompt: fix update with change of mapset by @nilason in (PR:765) |
648 | | * temporal: fix TGIS broken in 61b8d40 (#306) by @petrasovaa in (PR:504) |
649 | | * Test Module for Non-interactive display in Jupyter Notebooks by @chaedri in (PR:1739) |
650 | | * tests: Output more text and sort files by @wenzeslaus in (PR:1362) |
651 | | * testsuite example: info updated by @neteler in (PR:831) |
652 | | * testsuite: fix libgis/parser_json.c and r.fillnull by @neteler in (PR:1346) |
653 | | * testsuite: minor fixes by @neteler in (PR:855) |
654 | | * testsuite: r.blend quoting test by @neteler in (PR:347) |
655 | | * tplot/frame.py: fixes for Matplotlib 3.3+ by @neteler in (PR:1191) |
656 | | * Update docs (#360) by @KolesovDmitry in (PR:361) |
657 | | * Updated translators.csv file by @lucadelu in (PR:1249) |
658 | | * Update from proj.4 to proj (g.version) by @kikislater in (PR:55) |
659 | | * Update Location Wizard: First page by @lindakladivova in (PR:493) |
660 | | * Update of travis configuration for Python 3 by @neteler in (PR:115) |
661 | | * Update reference from proj.4 or proj4 to proj (g.version) by @kikislater in (PR:54) |
662 | | * Updates made in the README.md file by @shubhamshah14102 in (PR:1951) |
663 | | * Update to Black 21.5b1 by @wenzeslaus in (PR:1605) |
664 | | * Update to upstream ctypesgen version by @nilason in (PR:1651) |
665 | | * update usage of map() function to Python 3 by @pesekon2 in (PR:114) |
666 | | * update wingrass installer to osgeo4w v2 + drop 32bit by @landam in (PR:1904) |
667 | | * Upgrade tgis db by @landam in (PR:306) |
668 | | * Use ${CC} instead of "cc" for linking on mac by @nilason in (PR:611) |
669 | | * use copy instead of git clone in Dockerfiles by @mmacata in (PR:151) |
670 | | * Use gs as alias for grass.script in doc by @wenzeslaus in (PR:282) |
671 | | |
672 | | * Use .wxgui_history as history file for the gui (#962) by @susi in (PR:1917) |
673 | | * Using JSON for GUI settings by @petrasovaa in (PR:1015) |
674 | | * utils: Small fixes of Bash util scripts by @wenzeslaus in (PR:1363) |
675 | | |
676 | | ==== GUI: Improvements in the Graphical User Interface ==== |
677 | | |
678 | | * **NEW: entire rewrite of GRASS GIS startup** |
990 | | ==== Projection support ==== |
991 | | |
992 | | * PROJ6+ + WKT2 support by @metzm in (PR:118), (PR:183), (PR:1240) |
993 | | |
994 | | ==== GDAL support ==== |
995 | | |
996 | | * ... |
997 | | |
998 | | ==== Database support ==== |
999 | | |
1000 | | * n/a |
1001 | | |
1002 | | ==== Library changes ==== |
1003 | | |
1004 | | * libgis parser: Add angle brackets to a single option/flag rule by @HuidaeCho in (PR:1399) |
1005 | | * libgis parser: Show error for option file by @wenzeslaus in (PR:1433) |
1006 | | * libgis parser: Use #-space-% to allow writing PEP8-compliant Python code by @wenzeslaus in (PR:1287) |
1007 | | * libgis parser: Add a standard option for nprocs= (G_OPT_M_NPROCS) by @HuidaeCho in (PR:1644) |
1008 | | * libgis: add missing return keyword to G__make_mapset_element_misc() by @nilason in (PR:1751) |
1009 | | * libgis: add test for invalid value to parser by @metzm in (PR:1459) |
1010 | | * libgis: Advancing va_list manually after calling ovprintf() by @HuidaeCho in (PR:725) |
1011 | | * libgis: Distinguish dirs and objects in dir creation by @wenzeslaus in (PR:1681) |
1012 | | * libgis: More clear comments for aprintf by @HuidaeCho in (PR:726) |
1013 | | * libgis parser: an empty string is not an answer by @metzm in (PR:958) |
1014 | | * libgis: Use the full string length in strncmp() calls. by @infrastation in (PR:1060) |
1015 | | * lib/init: fix run py script with CRLF line terminators ('grass --exec file_with_CRLF.py') by @tmszi in (PR:860) |
1016 | | * lib/init/grass.py: Updated bash history setting from 3000 to unlimite… by @cwhite911 in (PR:1026) |
1017 | | * lib/init: set HISTSIZE to empty string for unlimited size by @nilason in (PR:1526) |
1018 | | * libproj: added alias for ITRF92 by @neteler in (PR:1460) |
1019 | | * libproj: change warning to debug message by @neteler in (PR:1337) |
1020 | | * libproj: fix crs modification with PROJ6+ by @metzm in (PR:1007) |
1021 | | * libproj: fix for PROJ6+ to get the ll equivalent of a CRS by @metzm in (PR:939) |
1022 | | * libproj: fix lookup mechanism for datum grids with all versions of PROJ by @metzm in (PR:252) |
1023 | | * libproj: fix results for ll equivalents by @metzm in (PR:1444) |
1024 | | * libproj: fix test for PJ_TYPE_BOUND_CRS by @metzm in (PR:1013) |
1025 | | * libproj: fix treatment of proj extension in wkt by @metzm in (PR:187) |
1026 | | * libpython: Add helper library for benchmarking by @wenzeslaus in (PR:1670) |
1027 | | * libpython: Add plot nprocs to benchmark CLI by @wenzeslaus in (PR:1761) |
1028 | | * libpython: Avoid race condition when reading region in use_temp_region() by @wenzeslaus in (PR:638) |
1029 | | * libpython: explain verbosity levels by @neteler in (PR:998) |
1030 | | * libpython: relax requirements for band names by @metzm in (PR:1081) |
1031 | | * libpython: Resolve path to mapset in setup.init by @wenzeslaus in (PR:1829) |
1032 | | * libpython: Save and load benchmark results by @wenzeslaus in (PR:1711) |
1033 | | * libpython/script: fix tests by @petrasovaa in (PR:1381) |
1034 | | * libpython: Support non-parallel runs better by @wenzeslaus in (PR:1733) |
1035 | | * libraster: add strerror(errno) to write failures by @metzm in (PR:1722) |
1036 | | * libraster by @metzm in (PR:463) |
1037 | | * libraster: change Rast_legal_bandref() return value to bool by @nilason in (PR:1897) |
1038 | | * libraster: fix Rast_legal_bandref() by @metzm in (PR:1796) |
1039 | | * libraster / gdal.c: add recent GDAL dlls by @ninsbl in (PR:1874) |
1040 | | * Lib: Speed up listing a lot of mapsets by 20%. by @marisn in (PR:281) |
1041 | | |
1042 | | ==== JSON / REST support ==== |
1043 | | |
1044 | | * ... |
1045 | | |
1046 | | ==== Code quality ==== |
1047 | | |
1048 | | * Add list of commits for git blame to ignore by @wenzeslaus in (PR:1391) |
1049 | | * Apply Black to all scripts by @wenzeslaus in (PR:1347) |
1050 | | * Apply Black to doc utils in man by @wenzeslaus in (PR:1366) |
1051 | | * Apply Black to grass package, use Python 3 style everywhere by @wenzeslaus in (PR:1382) |
1052 | | * Apply Black to helpers, examples, doc, and others by @wenzeslaus in (PR:1386) |
1053 | | * Apply Black to locale by @wenzeslaus in (PR:1513) |
1054 | | * Apply Black to Python utils by @wenzeslaus in (PR:1365) |
1055 | | * Apply Black to temporal modules by @wenzeslaus in (PR:1388) |
1056 | | * Apply Black to tests by @wenzeslaus in (PR:1387) |
1057 | | * Apply Black to wxGUI by @wenzeslaus in (PR:1527) |
1058 | | * Apply Mega-Linter fixes to GH workflow scripts by @wenzeslaus in (PR:1369) |
1059 | | * Flake8 fixes for docs and others by @wenzeslaus in (PR:1511) |
1060 | | * Flake8 fixes for utils and man by @wenzeslaus in (PR:1379) |
1061 | | * flake8: fix F401 (unused import) and F821 (undefined name) in scripts and lib by @petrasovaa in (PR:1314) |
1062 | | |
1063 | | |
1064 | | ==== Unit tests / CI ==== |
1065 | | |
1066 | | * Add C and C++ versions to CI by @wenzeslaus in (PR:596) |
1067 | | * Add CentOS build check to CI by @wenzeslaus in (PR:604) |
1068 | | * Add GitHub Action to build, run tests, and Python static code analysis by @wenzeslaus in (PR:525) |
1069 | | * Add github workflow for docker build and push by @mmacata in (PR:1790) |
1070 | | * Add label to new GitHub issue by @nilason in (PR:527) |
1071 | | * CI: Add Flake8 check for grass.py by @wenzeslaus in (PR:1311) |
1072 | | * CI: Add GH Super Linter for a subset of secondary files by @wenzeslaus in (PR:752) |
1073 | | * CI: Add matplotlib to apt deps by @wenzeslaus in (PR:1703) |
1074 | | * CI: add PDAL support by @neteler in (PR:1638) |
1075 | | * CI: add proj-bin to have cs2cs for tests by @petrasovaa in (PR:1410) |
1076 | | * CI: Do not run Docker job on forks by @wenzeslaus in (PR:1915) |
1077 | | * CI: Enable Perl in Super-Linter by @wenzeslaus in (PR:1493) |
1078 | | * CI: Fix ifs for jobs and rename master to main by @wenzeslaus in (PR:1813) |
1079 | | * CI: Handpick C/C++ version combos for GCC tests by @wenzeslaus in (PR:1288) |
1080 | | * CI: Make test report available as artifact by @wenzeslaus in (PR:1290) |
1081 | | * CI: Make test report available even on failure by @wenzeslaus in (PR:1702) |
1082 | | * CI: Print version info for Ubuntu and CentOS runs by @wenzeslaus in (PR:1832) |
1083 | | * CI: Remove duplication in Ubuntu workflow by @wenzeslaus in (PR:1749) |
1084 | | * CI: Remove notifications comming from Travis CI by @wenzeslaus in (PR:663) |
1085 | | * CI: Run Docker for all release branches by @wenzeslaus in (PR:1975) |
1086 | | * CI: Switch Travis to Ubuntu 20.04 (focal) by @wenzeslaus in (PR:1384) |
1087 | | * CI: Update Flake8 by @wenzeslaus in (PR:1932) |
1088 | | * CI: Update setting env vars, use 20.04, C gnu17 by @wenzeslaus in (PR:1092) |
1089 | | * CI: Use a specific Flake8 version by @wenzeslaus in (PR:626) |
1090 | | * CI: Use matrix and increase versions for Flake8 by @wenzeslaus in (PR:1309) |
| 853 | ==== Jupyter Notebooks ==== |
| 854 | |
| 855 | * Raster Support for Interactive Jupyter maps with folium by @chaedri in (PR:1769) |
| 856 | * Interactive vector maps for Jupyter Notebooks by @chaedri in (PR:1710) |
| 857 | * grass.jupyter: add property filename to GrassRenderer by @petrasovaa in (PR:1846) |
| 858 | * grass.jupyter: more flexible region handling for rendering by @petrasovaa in (PR:1871) |
| 859 | * jupyter: Add virtual framebuffer X server dependency by @wenzeslaus in (PR:1827) |
| 860 | * jupyter: Fix main notebook URL, note grass.jupyter is a preview by @wenzeslaus in (PR:1828) |
| 861 | * jupyter: Non-interactive display by @chaedri in (PR:1668) |
| 862 | * jupyter: Render 3D images with m.nviz.image by @wenzeslaus in (PR:1831) |
| 863 | * Session initiations functions for Jupyter Notebooks by @chaedri in (PR:1629) |
| 926 | ==== Projection support ==== |
| 927 | |
| 928 | * PROJ6+ + WKT2 support by @metzm in (PR:118), (PR:183), (PR:1240) |
| 929 | * CRS management by @metzm in (PR:976) |
| 930 | |
| 931 | ==== GDAL support ==== |
| 932 | |
| 933 | * GDAL/OGR import: check projection of input data by @metzm in (PR:317) |
| 934 | * GDAL/OGR import: report XY location when comparing projections by @metzm in (PR:368) |
| 935 | |
| 936 | ==== Database support ==== |
| 937 | |
| 938 | * postgres driver: Assign 1000 to TEXT field length by @HuidaeCho in (PR:412) |
| 939 | |
| 940 | ==== Library changes ==== |
| 941 | |
| 942 | * configure: upgrade to autoconf 2.69 by @nilason in (PR:1845) |
| 943 | * configure: use pkg-config for FreeType 2 by @infrastation in (PR:1719) |
| 944 | * ctypes: fix Callable for Python 3.10 by @neteler in (PR:1672) |
| 945 | * ctypes: Fix ctypesgencore for Python 3 by @wenzeslaus in (PR:379) |
| 946 | * ctypes: move directory out of python/grass by @nilason in (PR:1898) |
| 947 | * libgis parser: Add angle brackets to a single option/flag rule by @HuidaeCho in (PR:1399) |
| 948 | * libgis parser: Show error for option file by @wenzeslaus in (PR:1433) |
| 949 | * libgis parser: Use #-space-% to allow writing PEP8-compliant Python code by @wenzeslaus in (PR:1287) |
| 950 | * libgis parser: Add a standard option for nprocs= (G_OPT_M_NPROCS) by @HuidaeCho in (PR:1644) |
| 951 | * libgis: add missing return keyword to G__make_mapset_element_misc() by @nilason in (PR:1751) |
| 952 | * libgis: add test for invalid value to parser by @metzm in (PR:1459) |
| 953 | * libgis: Advancing va_list manually after calling ovprintf() by @HuidaeCho in (PR:725) |
| 954 | * libgis: Distinguish dirs and objects in dir creation by @wenzeslaus in (PR:1681) |
| 955 | * libgis: More clear comments for aprintf by @HuidaeCho in (PR:726) |
| 956 | * libgis parser: an empty string is not an answer by @metzm in (PR:958) |
| 957 | * libgis: Use the full string length in strncmp() calls. by @infrastation in (PR:1060) |
| 958 | * lib/init: fix run py script with CRLF line terminators ('grass --exec file_with_CRLF.py') by @tmszi in (PR:860) |
| 959 | * lib/init/grass.py: Updated bash history setting from 3000 to unlimite… by @cwhite911 in (PR:1026) |
| 960 | * lib/init: set HISTSIZE to empty string for unlimited size by @nilason in (PR:1526) |
| 961 | * libproj: added alias for ITRF92 by @neteler in (PR:1460) |
| 962 | * libproj: change warning to debug message by @neteler in (PR:1337) |
| 963 | * libproj: fix crs modification with PROJ6+ by @metzm in (PR:1007) |
| 964 | * libproj: fix for PROJ6+ to get the ll equivalent of a CRS by @metzm in (PR:939) |
| 965 | * libproj: fix lookup mechanism for datum grids with all versions of PROJ by @metzm in (PR:252) |
| 966 | * libproj: fix results for ll equivalents by @metzm in (PR:1444) |
| 967 | * libproj: fix test for PJ_TYPE_BOUND_CRS by @metzm in (PR:1013) |
| 968 | * libproj: fix treatment of proj extension in wkt by @metzm in (PR:187) |
| 969 | * libpython: Add helper library for benchmarking by @wenzeslaus in (PR:1670) |
| 970 | * libpython: Add plot nprocs to benchmark CLI by @wenzeslaus in (PR:1761) |
| 971 | * libpython: Avoid race condition when reading region in use_temp_region() by @wenzeslaus in (PR:638) |
| 972 | * libpython: explain verbosity levels by @neteler in (PR:998) |
| 973 | * libpython: relax requirements for band names by @metzm in (PR:1081) |
| 974 | * libpython: Resolve path to mapset in setup.init by @wenzeslaus in (PR:1829) |
| 975 | * libpython: Save and load benchmark results by @wenzeslaus in (PR:1711) |
| 976 | * libpython/script: fix tests by @petrasovaa in (PR:1381) |
| 977 | * libpython: Support non-parallel runs better by @wenzeslaus in (PR:1733) |
| 978 | * libraster: add strerror(errno) to write failures by @metzm in (PR:1722) |
| 979 | * libraster: Band references implementation by @landam in (PR:63) |
| 980 | * libraster: change Rast_legal_bandref() return value to bool by @nilason in (PR:1897) |
| 981 | * libraster: fix Rast_legal_bandref() by @metzm in (PR:1796) |
| 982 | * libraster / gdal.c: add recent GDAL dlls by @ninsbl in (PR:1874) |
| 983 | * Lib: Speed up listing a lot of mapsets by 20% by @marisn in (PR:281) |
| 984 | |
| 985 | ==== JSON / REST support ==== |
| 986 | |
| 987 | * Fixed gis parser json implementation by @huhabla in (PR:99) |
| 988 | * json parser: change + to @ for URLs by @neteler in (PR:175) |
| 989 | * json parser: fix mapsets in tokenizing by @neteler in (PR:1252) |
| 990 | |
| 991 | ==== Code quality ==== |
| 992 | |
| 993 | * Add list of commits for git blame to ignore by @wenzeslaus in (PR:1391) |
| 994 | * Apply Black to all python scripts by @wenzeslaus in (PR:1347) |
| 995 | * Apply Black to doc utils in man by @wenzeslaus in (PR:1366) |
| 996 | * Apply Black to grass package, use Python 3 style everywhere by @wenzeslaus in (PR:1382) |
| 997 | * Apply Black to helpers, examples, doc, and others by @wenzeslaus in (PR:1386) |
| 998 | * Apply Black to locale by @wenzeslaus in (PR:1513) |
| 999 | * Apply Black to Python utils by @wenzeslaus in (PR:1365) |
| 1000 | * Apply Black to temporal modules by @wenzeslaus in (PR:1388) |
| 1001 | * Apply Black to tests by @wenzeslaus in (PR:1387) |
| 1002 | * Apply Black to wxGUI by @wenzeslaus in (PR:1527) |
| 1003 | * Apply Mega-Linter fixes to GH workflow scripts by @wenzeslaus in (PR:1369) |
| 1004 | * Fix compiler warnings, part 1 by @nilason in (PR:1248) |
| 1005 | * Fix compiler warnings, part 2 by @nilason in (PR:1256) |
| 1006 | * Fix compiler warnings, part 3 by @nilason in (PR:1263) |
| 1007 | * Fix compiler warnings, part 4 by @nilason in (PR:1265) |
| 1008 | * Fix compiler warnings, part 5 by @nilason in (rst/interpfl lib & v.surf.rst) (PR:1271) |
| 1009 | * Fix compiler warnings, part 6 by @nilason in (PR:1274) |
| 1010 | * Fix compiler warnings, part 7 by @nilason in (PR:1275) |
| 1011 | * Fix compiler warnings, part 8 by @nilason in (PR:1276) |
| 1012 | * Fix compiler warnings, part 9 by @nilason in (PR:1316) |
| 1013 | * Fix compiler warnings, part 10 by @nilason in (PR:1395) |
| 1014 | * Fix compiler warnings, part 11 by @nilason in (PR:1405) |
| 1015 | * Fix compiler warnings, part 12 by @nilason in (PR:1406) |
| 1016 | * Flake8 fixes for docs and others by @wenzeslaus in (PR:1511) |
| 1017 | * Flake8 fixes for utils and man by @wenzeslaus in (PR:1379) |
| 1018 | * Flake8: fix F401 (unused import) and F821 (undefined name) in scripts and lib by @petrasovaa in (PR:1314) |
| 1019 | * python PEP8 fixes by @neteler in (PR:1317) |
| 1020 | * pythonlib: Fix stylistic Flake8 warnings by @wenzeslaus in (PR:1486) |
| 1021 | * Remove __pycache__ directories before release. by @sebastic in (PR:182) |
| 1022 | * Fix spelling errors. by @sebastic in (PR:1916), (PR:561), (PR:871), (PR:992) |
| 1023 | |
| 1024 | ==== Unit tests / CI ==== |
| 1025 | |
| 1026 | * Add C and C++ versions to CI by @wenzeslaus in (PR:596) |
| 1027 | * Add CentOS build check to CI by @wenzeslaus in (PR:604) |
| 1028 | * Add GitHub Action to build, run tests, and Python static code analysis by @wenzeslaus in (PR:525) |
| 1029 | * Add github workflow for docker build and push by @mmacata in (PR:1790) |
| 1030 | * Add label to new GitHub issue by @nilason in (PR:527) |
| 1031 | * CI: Add Flake8 check for grass.py by @wenzeslaus in (PR:1311) |
| 1032 | * CI: Add GH Super Linter for a subset of secondary files by @wenzeslaus in (PR:752) |
| 1033 | * CI: Add matplotlib to apt deps by @wenzeslaus in (PR:1703) |
| 1034 | * CI: add PDAL support by @neteler in (PR:1638) |
| 1035 | * CI: add proj-bin to have cs2cs for tests by @petrasovaa in (PR:1410) |
| 1036 | * CI: Do not run Docker job on forks by @wenzeslaus in (PR:1915) |
| 1037 | * CI: Enable Perl in Super-Linter by @wenzeslaus in (PR:1493) |
| 1038 | * CI: Fix ifs for jobs and rename master to main by @wenzeslaus in (PR:1813) |
| 1039 | * CI: Handpick C/C++ version combos for GCC tests by @wenzeslaus in (PR:1288) |
| 1040 | * CI: Make test report available as artifact by @wenzeslaus in (PR:1290) |
| 1041 | * CI: Make test report available even on failure by @wenzeslaus in (PR:1702) |
| 1042 | * CI: Print version info for Ubuntu and CentOS runs by @wenzeslaus in (PR:1832) |
| 1043 | * CI: Remove duplication in Ubuntu workflow by @wenzeslaus in (PR:1749) |
| 1044 | * CI: Remove notifications comming from Travis CI by @wenzeslaus in (PR:663) |
| 1045 | * CI: Run Docker for all release branches by @wenzeslaus in (PR:1975) |
| 1046 | * CI: Switch Travis to Ubuntu 20.04 (focal) by @wenzeslaus in (PR:1384) |
| 1047 | * CI: Update Flake8 by @wenzeslaus in (PR:1932) |
| 1048 | * CI: Update setting env vars, use 20.04, C gnu17 by @wenzeslaus in (PR:1092) |
| 1049 | * CI: Use a specific Flake8 version by @wenzeslaus in (PR:626) |
| 1050 | * CI: Use matrix and increase versions for Flake8 by @wenzeslaus in (PR:1309) |
| 1051 | * gunittest: CalledModuleError constructor accepts module, code, returncode, and errors by @HuidaeCho in (PR:1788) |
| 1052 | * gunittest: Deduplicate output decoding code by @wenzeslaus in (PR:1539) |
| 1053 | * gunittest docs: fix broken links by @neteler in (PR:934) |
| 1054 | * gunittest: Exclude broken tests by @wenzeslaus in (PR:1587) |
| 1055 | * gunittest: Fix stdout used instead of stderr by @wenzeslaus in (PR:1707) |
| 1056 | * gunittest: init super() to initialise 'errors' attribute by @nilason in (PR:1685) |
| 1057 | * gunittest: Non-zero return code on certian percetage of tests failing by @wenzeslaus in (PR:377) |
| 1058 | * gunittest: update module interface doctest by @nilason in (PR:1699) |
| 1059 | * tests: Output more text and sort files by @wenzeslaus in (PR:1362) |
| 1060 | * testsuite example: info updated by @neteler in (PR:831) |
| 1061 | * testsuite: fix libgis/parser_json.c and r.fillnull by @neteler in (PR:1346) |
| 1062 | * testsuite: minor fixes by @neteler in (PR:855) |
| 1063 | * testsuite: r.blend quoting test by @neteler in (PR:347) |
| 1064 | |
