Changes between Version 10 and Version 11 of Release/8.0.0-News
- Dec 17, 2021, 1:25:22 PM (3 years ago)
Release/8.0.0-News
v10 v11 86 86 * wxGUI: address digitizer backround map issue (PR:467) by @petrasovaa in (PR:494) 87 87 * wxGUI: Add temporary files for Non-Interactive Display by @chaedri in (PR:1727) 88 * Allow delete on multiple locations in data catalog by @lindakladivova in (PR:875) 89 * catalog: first load and display tree with locations for responsiveness, then load everything by @petrasovaa in (PR:1043) 90 91 88 * wxGUI: Change default color for rendering vectors (gray->blue) [news] by @wenzeslaus in (PR:1166) 89 * wxGUI: Allow delete on multiple locations in data catalog by @lindakladivova in (PR:875) 90 * wxGUI: catalog: first load and display tree with locations for responsiveness, then load everything by @petrasovaa in (PR:1043) 91 * wxGUI: error message has appeared in the console tab/cmd after close any module dialog by @tmszi in (PR:249) 92 * wxGUI: Fix an error when exporting csv file from g.gui.tplot by @lbartoletti in (PR:690) 93 94 * change sponsor link to opencollective by @veroandreo in (PR:1865) 92 95 93 96 * Add zsh history change by @nilason in (PR:975) … … 99 102 * Allow to use a fixed random seed via SOURCE_DATE_EPOCH by @bmwiedemann in (PR:251) 100 103 101 102 * Change default color for rendering vectors (gray->blue) [news] by @wenzeslaus in (PR:1166)103 * changed natural earth dataset archive from zip to tarball by @baharmon in (PR:867)104 104 * Change is/is not to ==/!= for literal comparisons by @HuidaeCho in (PR:264) 105 * Change local variable names to lowercase by @HuidaeCho in (PR:273) 106 * change sponsor link to opencollective by @veroandreo in (PR:1865) 105 107 106 * Check for gislock and other issues when deleting/renaming/editing mapset and location in catalog by @lindakladivova in (PR:904) 108 * Cleanup .swp files too by @sebastic in (PR:97)109 107 * Code quality fixes for grass package (lib/python) by @wenzeslaus in (PR:576) 110 108 111 * copy libs into bin directory after running make distclean by @landam in (PR:172) 112 113 * Data catalog: double click on map from different location fails by @lindakladivova in (PR:886) 114 * datacatalog: fix when no watchdog is present, fix pasting map by @petrasovaa in (PR:1099) 109 PROJ 115 110 * datum: add support for D_Rauenberg_1983 by @neteler in (PR:1331) 116 111 * datum.table: added SIRGAS 1995 by @neteler in (PR:464) 117 112 * datum.table: add RGFG95 by @neteler in (PR:813) 118 * Define MIN() and MAX() correctly and exactly once. by @infrastation in (PR:1795) 119 * delete ctypesgencore/parser/lextab.py by @neteler in (PR:95) 120 * delete unused function toolboxes._encode_string() by @pesekon2 in (PR:234) 121 * demolocation: update by @petrasovaa in (PR:1285) 122 * disable module check since svn keywords are not maintained by git by @landam in (PR:117) 123 * Distinguish mapsets by ownership and lock in Data tab by @lindakladivova in (PR:849) 124 * Docstring improvements by @chaedri in (PR:1800) 125 * Do not install config.status by @bmwiedemann in (PR:263) 126 * Do not show Flags: in help if there are no flags by @wenzeslaus in (PR:105) 113 114 Portability: 127 115 * env.bat.tmpl: Deal with blanks in OSGEO4W_ROOT by @jef-n in (PR:859) 128 * Error message has appeared in the console tab/cmd after close any module dialog by @tmszi in (PR:249) 116 117 129 118 * fix 3D rendering in animation tool by @petrasovaa in (PR:293) 130 119 * fix #411: closing Map Display and layer tree from different places by @petrasovaa in (PR:427) 131 * Fix an error when exporting csv file from g.gui.tplot by @lbartoletti in (PR:690) 132 * fix band references assignment by @landam in (PR:132) 133 * Fix Cairo for Windows by @nilason in (PR:1697) 134 * Fix Cartographic Composer Add graphic tool (Line/Rectangle), Add Image/North Arrow dialog wx FloatSpin widget size by @tmszi in (PR:310) 135 * Fix Cartographic Composer wxPython deprecation warning by @tmszi in (PR:309) 136 * Fix check wxGUI Set vector output format native format dsn by @tmszi in (PR:450) 120 137 121 * Fix copy-to-clipboard key binding for console (trac#3008) by @nilason in (PR:393) 138 122 * Fix dbmgr for Python3 by @petrasovaa in (PR:344) 139 123 * Fix decoding stderr after render layer fail by @tmszi in (PR:407) 140 * fix deprecated call warning for FutureCall by @petrasovaa in (PR:294) 141 * fix deprecated wx.NewId() by @neteler in (PR:150) 142 * Fix destroy open wxGUI Vector Network Analysis Tool dialog when wxGUI is closed by @tmszi in (PR:432) 143 * fix double string encoding with EncodeString() by @pesekon2 in (PR:241) 144 * Fixed the pygrass rpc server to avoid wrong restart warnings by @huhabla in (PR:100) 145 * Fix failing vector digitizer on mac, trac#3487 by @nilason in (PR:456) 146 * Fix fixed-width CJK formatting by @HuidaeCho in (PR:523) 124 125 code quality 147 126 * Fix Flake8 errors in temporal modules by @wenzeslaus in (PR:573) 148 127 * Fix flake8 pep8 errors by @neteler in (PR:986) 149 * Fix g.extension -i (compile), -d (download) flag by @tmszi in (PR:496) 150 * fix g.extension -l ValueError by @landam in (PR:1849) 151 * fix g.extension test by @petrasovaa in (PR:1364) 128 129 130 * G80:g.extension -i (compile), -d (download) flag by @tmszi in (PR:496) 131 * G80:g.extension -l ValueError by @landam in (PR:1849) 132 * G80:g.extension test by @petrasovaa in (PR:1364) 152 133 * fix init_dbif() returned values better interpretation by @pesekon2 in (PR:1008) 153 134 * fix Iterable import in pygrass/vector by @lrntct in (PR:734) … … 159 140 * fix position of null cells by @ninsbl in (PR:389) 160 141 * fix py3-numpy-dev package name by @neteler in (PR:112) 161 * Fixr.fillnulls to run in python 3 by @mwort in (PR:85)142 * G80:r.fillnulls to run in python 3 by @mwort in (PR:85) 162 143 * Fix set up sampling and analysis framework wizard relative import by @tmszi in (PR:409) 163 144 * Fix show layer inside the layer subgroup by @tmszi in (PR:400) … … 166 147 * Fix SyntaxError issues with Python 3. by @sebastic in (PR:549) 167 148 * fix the renaming of wx.Event variables by @pesekon2 in (PR:128) 168 * fix typo in databaseintro.html by @jentjr in (PR:650)169 * Fix typo in v.distance fatal msg by @wenzeslaus in (PR:163)170 149 * Fix unable to open file from python editor by @aroche in (PR:288) 171 150 * fix usage of vector cats in constraint by @metzm in (PR:262) 172 151 * Fix use wxGUI Raster Digitizer input raster map layer temporary region by @tmszi in (PR:470) 173 152 * Fix valid location check, sync with other functions by @wenzeslaus in (PR:1777) 174 * Fix v.in.pdalcompilation on mac, #475 by @nilason in (PR:479)153 * G80:v.in.pdal fix compilation on mac, #475 by @nilason in (PR:479) 175 154 176 155 * Format YAML in GH workflows by @wenzeslaus in (PR:1367) 177 156 * geos-config: Rename --libs to --clibs (configure uses --clibs) by @HuidaeCho in (PR:177) 178 * __getattr__ shortcut for calling GRASS display modules by @chaedri in (PR:1723)179 157 * get rid of wx.insertStringItem deprecation warnings by @pesekon2 in (PR:120) 180 * GIS_H_DATE: switch to date -Iseconds format by @landam in (PR:485) 181 * GIS_H_VERSION: use git hash by @metzm in (PR:325) 158 182 159 * gislib/dox: Refine the command line parsing doc. by @infrastation in (PR:1010) 183 * gitignore: Add testreport directory by @nilason in (PR:852)184 160 * GRASS GIS 8.0 changes by @neteler in (PR:1597) 185 161 * wxGUI: do not fail on invalid RC file (empty) by @landam in (PR:185) … … 188 164 * libimagery: move signatures to subdirs by @marisn in (PR:1850) 189 165 * images2gif: PILLOW_VERSION is obsolete by @petrasovaa in (PR:899) 190 * Improve G_open|find _misc function documentation by @marisn in (PR:1760) 191 * infrastructure doc: converted to MD by @neteler in (PR:715) 192 * infrastructure.md: add latest updates by @neteler in (PR:863) 166 * libimagery: Improve G_open|find _misc function documentation by @marisn in (PR:1760) 167 193 168 * init: Add --tmp-mapset option by @wenzeslaus in (PR:313) 194 169 * init: Apply Black to the init script by @wenzeslaus in (PR:1359) … … 205 180 * init: Use argparse instead of custom parsing for CLI by @wenzeslaus in (PR:1239) 206 181 * install: check lowercased prefix by @nilason in (PR:949) 207 * Integrate band references into portable signature files by @marisn in (PR:1501) 182 * libimagery: Integrate band references into portable signature files by @marisn in (PR:1501) 183 * libimagery: Make band references optional to simplify generation of signatures by @marisn in (PR:1866) 184 * libimagery: Simplify raster band reference management by @marisn in (PR:1272) 185 186 docker: 208 187 * introduce docker multistage build to alpine image by @mmacata in (PR:276) 209 188 * Keep module_items.xml in docker alpine by @mmacata in (PR:330) 210 * Lazy imports and work without import numpy by @wenzeslaus in (PR:511) 189 * Read the ubuntu based Dockerfile by @hwbllmnn in (PR:143) 190 211 191 * libsymbol: fix bad argument order by @nilason in (PR:1820) 212 * Make band references optional to simplify generation of signatures by @marisn in (PR:1866) 192 213 193 * Make Data tab the default in GUI by @lindakladivova in (PR:756) 214 194 * make python script in gmodeler using items instead of iteritems by @pesekon2 in (PR:340) 215 195 * MapSwipe window has wrong title by @lindakladivova in (PR:1692) 216 * misc: fix indentation for r.series and r.patch by @aaronsms in (PR:1772)217 * misc(r.slope.aspect): reindent C source files by @aaronsms in (PR:1765)218 196 * Misleading lock symbol icon in the in the Data tab toolbar by @lindakladivova in (PR:870) 219 197 * more proofreading for r.geomorphon by @infrastation in (PR:991) … … 229 207 * raster module memory: set new value globally by @neteler in (PR:922) 230 208 * Rast_log_colors: Another attempt to address r.colors -g/-a (#1480) by @HuidaeCho in (PR:1937) 231 * Readd the ubuntu based Dockerfile by @hwbllmnn in (PR:143) 209 232 210 * Reference CONTRIBUTING.md file in README by @wenzeslaus in (PR:283) 233 211 * Reflect grassdb changes in catalog by @petrasovaa in (PR:994) … … 240 218 * replace deprecated inspect function by @petrasovaa in (PR:334) 241 219 * replace obsolete time.clock() in Python 3.3 by @petrasovaa in (PR:244) 242 * Set locale to euc-kr only for Windows by @HuidaeCho in (PR:520) 243 * several fixes related to font dialog by @petrasovaa in (PR:292) 220 244 221 * simplify GRASS_EXECUTABLE handling in package.sh by @landam in (PR:445) 245 * Simplify raster band reference management by @marisn in (PR:1272) 222 246 223 * Start in a demo/startup location by @lindakladivova in (PR:868) 247 224 * Startup: Avoid a race condition by @HuidaeCho in (PR:548) … … 252 229 * Sync Korean translations by @HuidaeCho in (PR:556) 253 230 * tcsh prompt: fix update with change of mapset by @nilason in (PR:765) 254 * Update docs (#360) by @KolesovDmitry in (PR:361)255 * Updated translators.csv file by @lucadelu in (PR:1249)256 * Update from proj.4 to proj (g.version) by @kikislater in (PR:55)257 231 * Update Location Wizard: First page by @lindakladivova in (PR:493) 258 232 * Update of travis configuration for Python 3 by @neteler in (PR:115) 259 233 * Update reference from proj.4 or proj4 to proj (g.version) by @kikislater in (PR:54) 260 * Updates made in the README.md file by @shubhamshah14102 in (PR:1951) 261 * Update to Black 21.5b1 by @wenzeslaus in (PR:1605) 262 * Update to upstream ctypesgen version by @nilason in (PR:1651) 263 * update usage of map() function to Python 3 by @pesekon2 in (PR:114) 234 264 235 * Upgrade tgis db by @landam in (PR:306) 265 * Use ${CC} instead of "cc" for linking on mac by @nilason in (PR:611)266 * use copy instead of git clone in Dockerfiles by @mmacata in (PR:151)267 236 * Use .wxgui_history as history file for the gui (#962) by @susi in (PR:1917) 268 237
