Changes between Version 16 and Version 17 of Release/7.8.6-News
- Jun 23, 2021, 4:56:44 AM (3 years ago)
Release/7.8.6-News
v16 v17 58 58 59 59 * NC full sample dataset: new URL (PR:1463) 60 * G78:d.mon: Do not clear an existing output file on fatal error (PR:1475)60 * G78:d.mon: do not clear an existing output file on fatal error (PR:1475) 61 61 * G78:g.extension: ignore cruft __pycache__ files (PR:1496) 62 62 * G78:g.proj: fix segfault issue #1163 (PR:1170) … … 65 65 * G78:i.vi: fix the check for the existence of the 'redchan' variable (PR:1378) 66 66 * G78:m.proj: fix PROJ URL in error message 67 * G78:psdriver: Write data to a tempfile before closing (rel78) (PR:1506)67 * G78:psdriver: write data to a tempfile before closing (rel78) (PR:1506) 68 68 * G78:r.in.wms: enable !CreateOptions for GDAL driver 69 69 * G78:r.out.gdal: fix xy export (PR:1564) … … 71 71 * G78:v.colors: fix v.colors cannot properly copy color table (#1297, PR:1429) 72 72 * G78:v.colors: Fix color inversion (PR:1478, PR:1479) 73 * G78:v.import: Add layer to the projection check (PR:1328)73 * G78:v.import: add layer to the projection check (PR:1328) 74 74 * G78:v.net.visibility: fix coordinates parameter (PR:1336) 75 75 * G78:v.out.ogr: fix xy export (PR:1564) … … 106 106 * wxGUI/tplot: fix x, y coordinates validation (PR:1199) 107 107 * wxGUI/vselect: fix delete row from selected features list (PR:1231) 108 * wxGUI/WMS: replace broken URLs with alternative WMS (PR:1674) 108 109 109 110 ==== Python scripting ==== 110 111 111 112 * remove deprecated py 'PIL' module 'fromstring', 'tostring' method call (removed from 'PIL' module version >= 8.0.0) (PR:1223) 113 * pygrass: backport #1407 Module fix (PR:1606) 114 * ctypes: fix Callable for Python 3.10 (PR:1673) 112 115 113 116 ==== Projection support ==== … … 129 132 ==== Library changes ==== 130 133 131 * make: Add support for Makefile variable DESTDIR (PR:1234) 132 * libgis: Add test for invalid value to parser (PR:1459) 133 * libgis: Enable the C99 bool type (PR:1567) 134 * libgis: Fix reading of WKT and SRID 135 * libgis: Add read/write functions for WKT and srid (PR:976) 136 * parser: Accept `#-space-%` to allow writing PEP8-compliant Python code (PR:1446) 134 * make: add support for Makefile variable DESTDIR (PR:1234) 135 * libgis: add test for invalid value to parser (PR:1459) 136 * libgis: enable the C99 bool type (PR:1567) 137 * libgis: fix reading of WKT and SRID 138 * libgis: add read/write functions for WKT and srid (PR:976) 139 * parser: accept `#-space-%` to allow writing PEP8-compliant Python code (PR:1446) 140 * parser: add a standard option for nprocs= (G_OPT_M_NPROCS) (PR:1648, PR:1652) 137 141 138 142 ==== JSON / REST support ==== … … 148 152 ==== Unit tests / CI ==== 149 153 150 * CI: Make test report available as artifact (PR:1484)154 * CI: make test report available as artifact (PR:1484) 151 155 * !GitHub action CI: drop ubuntu-16.04 (PR:1254) 152 156 * testsuite: fix libgis/parser_json.c and r.fillnull (PR:1346) … … 160 164 * G78:r.out.gdal manual: added COG example (PR:1554), fix LZW export example 161 165 * G78:r.series: manual update (PR:1246) 162 * G78:r.stream.extract: Fix typos in the manual (PR:1352) (PR:1383)166 * G78:r.stream.extract: fix typos in the manual (PR:1352) (PR:1383) 163 167 * G78:t.register manual: add link to r.timestamp 164 168 * G78:t.select manual: add scientific paper ref … … 176 180 177 181 * i18N: sync from Transifex (https://www.transifex.com/grass-gis/grass7/dashboard/) (PR:1520) 182 * i18n: Sync from Transifex for rel78 (PR:1340, PR:1466, PR:1593) 178 183 * i18n: Remove duplicate messages from po files (PR:1397) 179 * i18n: Sync from Transifex for rel78 (PR:1466)180 * i18n: sync from Transifex (PR:1340)181 184 * Sync Transifex; labelcolumn => label_column for v.to.rast (PR:1385) 182 185 * Updated translators.csv file (PR:1249)
