69 | | * ... |
| 69 | * G78:Startup: Avoid a race condition (#548) |
| 70 | * G78:wxGUI Add web service layer: Fix dialog layout (#627) |
| 71 | * G78:wxGUI AddWSDialog: fix 'Access window out of range in RasterIO()' error (#693) |
| 72 | * G78:wxGUI AddWSDialog: fix render WMTS layer with OGC:CRS84 coor system (#674) |
| 73 | * G78:wxGUI AddWSDialog: fix setting output layer name, after selecting another layer (#667) |
| 74 | * G78:wxGUI AddWSDialog RenderWMSMgr: fix render WMS jpeg source format (#640) |
| 75 | * G78:wxGUI/animation: add export output animation file validation, before export file (#839) |
| 76 | * G78:wxGUI/animation: fix export (run as background thread) output animation file to avi format (#840) |
| 77 | * G78:wxGUI/animation: fix 'RuntimeError: dictionary changed size during iteration' (#908) |
| 78 | * G78:wxGUI/animation: fix validation of extension of exported file (#907) |
| 79 | * G78:wxGUI/animation: fix wxPyDeprecationWarning (#854) |
| 80 | * G78:wxGUI/animation: fix wxPyDeprecationWarning (#910) |
| 81 | * G78:wxGUI/animation: set default export file type choice option (#838) |
| 82 | * G78:wxGUI: avoid flush clipboard if not opened (#819) |
| 83 | * G78:wxGUI/composer: use integers instead of wx id, which can't be pickled and cause error (#641) |
| 84 | * G78:wxGUI/datacatalog: fix display 3D raster (#889) |
| 85 | * G78:wxGUI/datacatalog: Fix error after right click on grass database tree item (#736) |
| 86 | * G78:wxGUI/datacatalog: Fix layout flag in reprojection dialog for wx 4.1.0 (#806) |
| 87 | * G78:wxGUI dbmgr: Fix dbmgr widgets layout on the wxMSW (#637) |
| 88 | * G78:wxGUI d.histogram: Set default font (#695) |
| 89 | * G78:wxGUI d.mon: Fix launch light-weight wx monitor without toolbars and statusbar (#678) |
| 90 | * G78:wxGUI, d.rast.edit: remove 'wxversion' module (#713) |
| 91 | * G78:wxGUI: fix atexit error in debug mode when exiting GUI (#772) |
| 92 | * G78:wxGUI: fix bad indentation (#784) |
| 93 | * G78:wxGUI: fixes incomplete map display when opening from gxw workspace (#500) |
| 94 | * G78:wxGUI: fix g.gui.vdigit on windows #530 (#572) |
| 95 | * G78:wxGUI: fix inconsistent layer sizes during rendering (#552) |
| 96 | * G78:wxGUI: fix layout flags for wx 4.1.0 |
| 97 | * G78:wxGUI: Fix layout flags in vector field statistics dialog for wx 4.1.0 (#821) |
| 98 | * G78:wxGUI: fix RunCommand to decode also empty string to return unicode (#702) |
| 99 | * G78:wxGUI: fix wx4.1 support for About GRASS GIS dialog (#901) |
| 100 | * G78:wxGUI/gcp: adding the option/show overwrite confirm dialog to overwrite the result map (#912) |
| 101 | * G78:wxGUI gcp: fix adding vector map to group when no vector maps exist (#685) |
| 102 | * G78:wxGUI gcp: fix checking vector map existence in the group (#680) |
| 103 | * G78:wxGUI/gcp: fix launch add vector map to group dialog (#924) |
| 104 | * G78:wxGUI g.gui.animation: fix wx.CheckBox widget deprecation warning (#718) |
| 105 | * G78:wxGUI g.gui.rlisetup: fix get rectangle sample units size (#633) |
| 106 | * G78:wxGUI GroupDialog: fix StaticText widget existence check (#647) |
| 107 | * G78:wxGUI lmgr: fix cancel save workspace dialog (#628) |
| 108 | * G78:wxGUI lmgr: Fix position of layer image button overlaid map layer name (#669) |
| 109 | * G78:wxGUI lmgr: fix remove both selected parent/children group layer (#642) |
| 110 | * G78:wxGUI/lmgr: fix return 'Layer' class str value if map layer name is None (#820) |
| 111 | * G78:wxGUI location wizard: fix title layout, bug introduced in changes for wxPython 4.1 (#661) |
| 112 | * G78:wxGUI locdownload: fix missing flush method (#634) |
| 113 | * G78:wxGUI: macOS use default output font dialog (#760) |
| 114 | * G78:wxGUI/mapdisp: fix double click on the overlays in the 3D view (#872) |
| 115 | * G78:wxGUI/mapswipe: call dialog Uninit only when dialog was actually created, fix for #833 (#836) |
| 116 | * G78:wxGUI/mapswipe: fix wx.CheckListBox widget wxPyDeprecationWarning (#773) |
| 117 | * G78:wxGUI/mapwin: fix saving the position of overlays after changing their position with the mouse pointer tool (#817) |
| 118 | * G78:wxGUI mapwin: fix show/hide vdigit toolbar (#578) |
| 119 | * G78:wxGUI/nviz: fix failed map centring on mac with pre-wx4.1 (#895) |
| 120 | * G78:wxGUI/nviz: fix relative import from 'wxnviz' module (#887) |
| 121 | * G78:wxGUI/nviz: fix reopening 3D by reloading layers (#953) |
| 122 | * G78:wxGUI/nviz: fix update list of surface in vector page during delete constant surface (#881) |
| 123 | * G78:wxGUI/nviz: SetMaskColour causes problems on macos with wx 4.1.0 (#787) |
| 124 | * G78:wxGUI rdigit: fix quitting behavior when no map edited (#594) |
| 125 | * G78:wxGUI rdigit: update list of available raster map layers, when map layers tree changed (#707) |
| 126 | * G78:wxGUI rendering: when deleting layer check if .legrow file exists (#691) |
| 127 | * G78:wxGUI r.li.setup: Show message dialog if removed config file isn't selected from the list (#631) |
| 128 | * G78:wxGUI/startup: fix terminate location download dialog download thread (#832) (#873) |
| 129 | * G78:wxGUI tplot: fix an error when exporting csv file from g.gui.tplot (#690) |
| 130 | * G78:wxGUI: update wx4.1.0 support for FlatNotebook (#856) |
| 131 | * G78:wxGUI vdigit: fix Undo/Redo tool when no map edited (#586) |
| 132 | * G78:wxGUI vdigit: fix wx.CheckBox widget deprecation warning (#700) |
| 133 | * G78:wxGUI vdigit: update list of available vector map layers, when map layers tree changed (launch 'd.vect map=mapname' from the wxGUI Console page) (#708) |
| 134 | * G78:wxGUI vnet: fix ctypes c_char_p arg type (bytes object) (#687) |
| 135 | * G78:wxGUI WSPropertiesDialog: fix applying ws panel widgets updates, after panel is the shown (#665) |
| 136 | * G78:wxGUI WSPropertiesDialog: fix closing dialog (#684) |
| 137 | * G78:wxGUI WSPropertiesDialog: Fix showing selected layer in wms layer tree (#666) |
| 138 | * G78:wxGUI WSPropertiesDialog: fix updating ws map layer if map layer changed (#668) |
| 139 | * G78:wxGUI/wxpyimgview: Fix wxpyimgview for Python3/wxPython4 (#735) |
