Changes between Version 14 and Version 15 of Release/7.8.1-News
- Nov 9, 2019, 3:28:47 AM (5 years ago)
Release/7.8.1-News
v14 v15 61 61 (see also below for closed bugs) 62 62 63 * G78:i.zc: avoid integer overflow with large maps 63 64 * G78:r.to.vect: break line when value changes 64 * G78:v.digit: fix digitizing on Windows65 * G78:v.digit: fix digitizing on MS Windows 65 66 66 67 ==== Minor module changes ==== … … 69 70 70 71 Modules: 71 * G78:g.extension: #3902 multiple metadata entries 72 * G78:g.extension: #3902 multiple metadata entries; quick fix of g.extension on MS Windows 72 73 * G78:i.vi: red band not required and GUI section modified 73 * G78:i.zc: avoid integer overflow with large maps74 74 * G78:r.fillnulls fix to run in Python 3 75 75 * G78:r.slope.aspect: fix -e flag to calculate values at edges … … 85 85 * wxGUI/animation: fix deprecation warnings 86 86 * get rid of wx.insertStringItem deprecation warnings 87 * wxGUI: added install "no translation" function 88 * wxGUI: fix d.mon rendering #3896, caused by garbage collection of maplayer resulting in deleting mapfile 87 89 88 90 ==== Python scripting ==== … … 92 94 ==== Projection support ==== 93 95 94 * libproj: PROJ 6 support added 96 * libproj: PROJ 6 support added: 97 * convert lowercase epsg to uppercase EPSG 98 * axis order of a CRS is no longer always easting, northing, it can also be northing, easting, e.g. EPSG:4326. If source and target CRS are available, axis order is adjusted using proj_normalize_for_visualization() to easting, northing if needed. 99 * previously, GRASS GIS did conversions of degress to/from radians and meters from/to map units. Now PROJ6+ might do these conversions itself, or not. GRASS GIS is now doing the conversions only if needed. 100 * in PROJ6+, there can be several different operations to transform coordinates from one CRS to another CRS. If more than one operation is available, information is provided about these different operations. The current region is used by PROJ to select an appropriate operation. 95 101 * libproj: fix treatment of proj extension in wkt 102 103 ==== GDAL support ==== 104 105 * GDAL 3 support added 96 106 97 107 ==== Database support ==== 98 108 99 109 * n/a 100 101 ==== Graphical User Interface ====102 103 * wxGUI: added install "no translation" function104 * wxGUI: fix d.mon rendering #3896, caused by garbage collection of maplayer resulting in deleting mapfile105 110 106 111 ==== Library changes ====
