Changes between Version 18 and Version 19 of Release/7.8.0-News
- Sep 6, 2019, 2:07:28 PM (5 years ago)
Release/7.8.0-News
v18 v19 9 9 ==== Stable Release ==== 10 10 11 * tbd 11 * Release date: ''6 Sep 2019'' 12 * Changelog: https://grass.osgeo.org/grass78/source/ChangeLog_7.8.0.gz 13 * Binaries: https://grass.osgeo.org/download/software/#g78x 14 * Source code: 15 * https://github.com/OSGeo/grass/releases/tag/7.8.0 16 * https://grass.osgeo.org/grass78/source/grass-7.8.0.tar.gz ([https://grass.osgeo.org/grass78/source/grass-7.8.0.md5sum md5sum]) 12 17 13 18 ==== Release Candidate 1 (RC1) ==== … … 19 24 * https://github.com/OSGeo/grass/releases/tag/7.8.0RC1 20 25 * https://grass.osgeo.org/grass78/source/grass-7.8.0RC1.tar.gz ([https://grass.osgeo.org/grass78/source/grass-7.8.0RC1.md5sum md5sum]) 26 21 27 === Git Source Code === 22 28 … … 32 38 === Overview of changes === 33 39 34 The most important change is the new Python-3 support. Also new PROJ 6and GDAL 2.5 with substantial changes in the API and CRS handling are supported. A series of new features and stability fixes, manual improvements, and a more language translations have been added. Importantly, the new version is backward compatible with older 7.x releases.40 The most important change is the new Python-3 support. Also new PROJ 5 and GDAL 2.5 with substantial changes in the API and CRS handling are supported. A series of new features and stability fixes, manual improvements, and a more language translations have been added. Importantly, the new version is backward compatible with older 7.x releases. 35 41 36 42 The GRASS GIS 7.8.0 release provides '''more than XXX fixes and improvements''' with respect to the stable release 7.6.x. … … 41 47 ==== New modules ==== 42 48 43 * G78:...44 * parser: added --json output, useful for REST API output (needed e.g. for actinia) 49 * parser: added --json output, useful for REST API output (needed e.g. for [https://github.com/mundialis/actinia_core actinia]) 50 45 51 ==== Major module changes ==== 46 52 … … 124 130 125 131 * wxGUI data catalog: allow to perform actions on multiple layers (e.g. deleting, moving, reprojection, display, metadata) 132 * wxGUI/animation: fixes for Python 3 126 133 * wxGUI/digitizer: fixes for Python 3 134 * wxGUI/modeller: fixes for Python 3 127 135 * wxGUI: add function to LM interface to programmatically change layer 128 136 * wxGUI: add !GeoPackage as known raster/vector format … … 144 152 ==== Database support ==== 145 153 146 * postgres driver: create index if not exists for PG server versions 9.5+154 * postgresql driver: create index if not exists for PG server versions 9.5+ 147 155 148 156 ==== Library changes ==== … … 186 194 === New Addons since GRASS 7.6.0 === 187 195 188 * G7A:... 196 * G7A:i.sar.speckle - Remove speckle from SAR image 197 * G7A:r.fill.category - Replaces the values of pixels of a given category with values of the surrounding pixels 198 * G7A:r.object.thickness - Evaluates minimum, maximum and mean thickness of objects of a given category on a raster map 199 * G7A:r.out.kde - Exports raster with variable transparency into an image file 200 * G7A:r.out.legend - Create an image file showing the legend of a raster map 201 * G7A:r.random.weight - Generates a binary raster layer with a random selection of raster cells depending on the weight of each cell in the input weight layer. 202 * G7A:r.sample.category - Create sampling points from each category in a raster map 203 * G7A:r.series.diversity - Compute diversity indici over input layers 189 204 190 205 === Closed tickets ===
