Changes between Version 19 and Version 20 of Release/7.4.1-News
- May 4, 2018, 2:07:32 PM (6 years ago)
Release/7.4.1-News
v19 v20 69 69 ==== Minor module changes ==== 70 70 71 * raster and vector export (G74:r.out.gdal, G74:r.external.out, G74:v.out.ogr, G74:v.external.out) now includes a CRS EPSG code if available72 71 (see also below for closed bugs) 72 73 * raster and vector export (G74:r.out.gdal, G74:r.external.out, G74:v.out.ogr, G74:v.external.out) now includes the CRS EPSG code if available 74 * G74:r.cross: create categories for output value 0, it is a valid result 75 * G74:r.contour: avoid tracing back of contour lines 73 76 * G74:r.import: use auto-adjustment for lat/lon 74 77 * G74:r.in.gdal: fix column offset and column mapping when limiting import to the current region 78 * G74:r.in.gdal: print only proj comparision when -j flag is given (r.in.gdal -j is mostly used in scripts) 79 * G74:r.texture: Fatal error if one of the requested output maps exists 80 * G74:t.info: activate -h flag 81 * G74:t.rast.series: Fixed bug #3223 wrong time stamp for raster map in case where condition was used 75 82 * G74:v.db.dropcolumn: preserve field length for field type CHARACTER 76 * G74:r.cross: create categories for output value 0, it is a valid result 77 * G74:r.texture: Fatal error if one of the requested output maps exists 83 * G74:v.in.ogr: fix duplicate column names 78 84 * G74:v.random restrict wrong categories assigned, see #3524 79 * G74:t.rast.series: Fixed bug #3223 wrong time stamp for raster map in case where condition was used80 * G74:i.ortho.transform: do not overwrite transformed coordinates81 * G74:t.info: activate -h flag82 * G74:r.in.gdal: print only proj comparision when -j flag is given (r.in.gdal -j is mostly used in scripts)83 * G74:v.in.ogr: fix duplicate column names84 85 85 ==== Improvements in the Graphical User Interface ==== 86 86
